| S |
1 |
| 4 |
5 |
8 |
| 11 |
12 |
15 |
| 18 |
19 |
22 |
| 25 |
26 |
29 |
30 |
31 |
07-24-2005, 07:24 PM
NJ
Cobra Make, Engine: B & B
Coil Over Conversion
Hi,
I still have Mustang II suspension front and rear and I have finally make a commitment to convert to coil overs.
From a past post I think I can just bolt in a pair of QA-1 shocks in the front. Any other suggestions?
I am unsure about the rear. What is involved in installing coil overs in the rear?? Admittedly- I am a little naive on suspension so specific info would be appreciated.
Thanks
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
07-25-2005, 08:06 AM
NJ
Some added information:
Does the 4 link need to be changed?
Do I use the same top shock mount for the coil over in the rear?
FYI-The car is just driven on the street.
07-26-2005, 01:08 PM
NJ
All right,
I learned that the rear coil overs can just bolt in place of the standard shock.
Does anyone know the QA1 part # for the rear?
I already have the front Part # 122-ms1365 (365lb spring)
07-26-2005, 02:21 PM
CA
Wow, what a relief. I thought I had answered this post and couldn't find my post. So I thought I had really lost my mind. Now I found it in another forum, All Cobra Talk, I think it is. I thought that I had the papers that came with my set up but I just looked and can't find any. Sorry.
07-26-2005, 02:49 PM
NJ
Thanks for your help Ron. Hopefully someone else can give me the last piece of the puzzle.
07-26-2005, 03:16 PM
SC
Cobra Make, Engine: B&B 351w
Jams, I would give you the # if I could but I built my own coilovers, I got hd shocks for 89 mustang rear, from autozone, about $23 each, 200# springs for $49.95 ea. and coilover kits for about $41.00 ea. Springs and coiloverkits come from speedway motors. web site www.speedwaymotors.com
My rearend is not like anyother in a B&B, it is a shorten chev with 3 link hookup.
Dusty Rhodes
07-27-2005, 12:41 PM
NJ
Dusty,
I was not aware you could build your own coil overs. If I understand it correctly...you take an ordinary shock, buy the conversion kit and spring and you got yourself a coil over shock???
Sounds interesting
08-07-2005, 10:29 AM
NJ
New rear coil overs are in and WOW what a difference. Had I known it would make that much of a differecne in my ride I would have done it 2 years ago. For all those with stock MUstang II consider upgrading!
04-03-2006, 02:51 PM
IL
Cobra Make, Engine: SPF, KC 427
coil over
Jams, I also have an old B&B with Mustang II front and ford 9" rear. So you used Part # 122-ms1365 (365lb spring in the front and it bolted right in? What did you use in the rear. I'm looking for a better ride.
Poolw
04-03-2006, 06:46 PM
NJ
Hi Poolw,
So far I just did the back. and it makes such a big difference. Below are the part #'s from Summit. For the rear the only thing you need to do is fab a 1" spacer to stop the coil from hitting something. Look for a prior post. Someone posted a great picture. The spacer went on the lower mount.
HAL-14-200 14" SPRING EACH $36.95 2 $73.90
HAL-DR8855B REAR SHOCK ALUM ADJ W/HDWE EA $168.69 2 $337.38
HAL-SS110SDM STUD MOUNT CONVERSION $32.99 2 $65.98
I will be ordering the the front coil-over conversion kit very soon. It is going to be my Spring project. From what I know they just bolt right in.
Here is the Summit Part number for the coil over conversion kit....HAL-MS1375
They also have another kit with different weight springs.
Hope that helps.
04-04-2006, 07:09 AM
OK
Sorry Jams,
I read your post a little late but those are the same part numbers I used. If you need additional help let us know.
Clois
"Let's roll"
"Be part of Something Good
04-09-2006, 04:27 PM
NJ
I see they also offer 500lb front Springs. I guess those would be a little too heavy?? Unless you have a big block!
04-09-2006, 05:11 PM
Cobra Make, Engine: B&B 427 Cobra 302 roller
Hi fellow B&B owners . I have been wondering does anyone have a B&B with airride suspenion?
04-09-2006, 07:10 PM
OK
Jams, I was running 500 lb springs in the front of mine with a small block and the ride was excellent. I now run 600 lb spings with my 427. If you need a set of 500 lb springs I will sell you mine for cheap, $50. If you ever decide to road race your Cobra you will be glad you have the 500 lb springs.
Clois
"Let's roll"
04-09-2006, 07:26 PM
NJ
Hi Clois,
The 375 pounders were too soft for you? With the roads in my neck of the woods, I am thinking about a stiffer spring. I will let you know. Trying to make my final decision right now.
Are the 500lb springs the same lengthas the 375lb springs??? Chrome or Powercoated?
04-15-2006, 08:35 AM
IL
Jams, when you replaced the rear on your B&B - -
04-15-2006, 08:38 AM
IL
1. did you remove both the shock and the spring?
2. where did you install the new coil over - in place of the shock or in place of the spring?
Sorry to be such a dummy
Poolw
04-15-2006, 08:55 AM
NJ
There are no dumb questions.
Yes, the shock and spring were removed. Bottom of coil over mounts to original shock mount. You will probably need about an 1" spacer so it doesn't rub. I fabbed the spacer out of a piece of weightlifting bar. Just cut it to lengthe and drilled a hole in the middle. A friend with a machine shop can make it in 5 min. As far as the upper mount goes there is an upper angle iron piece with a hole in it. The upper shock stud(I think it is called) is in-line with the shock not perpendicular. Depending on your shock you might have to convert. I had to, it cost about 30 bucks. I guess I left that out of the parts list.
There is a good picture in a prior post that helped me. I will do a search if I can't find it, I have one on my Desktop computer. I am laptopping right now.
Best of luck...keep posting if you have questions.
04-15-2006, 08:59 AM
NJ
