Old 05-06-2015, 11:43 AM
Cobra Make, Engine: Backdraft 1048
Default Backdraft Ride height
What is the recommended ride height for a backdraft cobra with 17 inch wheels measured from the ground to the fender well lip. are all 4 the same?
Gary
Backdraft 1048
Old 05-06-2015, 12:52 PM
Grey 65's Avatar
Cobra Make, Engine: BDR #888, Keith Craft 408
That would all depend on the tires you are running... Mudders are taller than 30 series tires.....
Kevin...
Old 05-06-2015, 12:57 PM
Cobra Make, Engine: Backdraft #832
I was told by the good guys in Boyton Beach that a couple of finger widths above the tire is adequate. Hope this helps.
Old 05-06-2015, 03:03 PM
It's really got to do with the spring rates, not really the tires...
RH should be measured from the frames rails to the ground on a flat, level surface. Factors such as fuel, driver, etc. need to be compensated for when checking.
If you don't rub your tires on the body, which I doubt, and you want to level the car, that's the way to set it. You don't know how level that body is on the car.
The fronts are easy, rears are a biatch.
These cars have pretty much the correct springs for street driving, so don't sweat it too much.
