| 29 |
06-24-2020, 04:10 PM
NJ
Trunk lid lift kit.
Another Backdraft owner sent me this info. A gentleman designed and is manufacturing this kit that allows the trunk lid to open fully and utilizes a piston that makes it possible to open and stay in any position. I ordered one today. Here is his Facebook video explaining it. I have his email address if anyone is interested.
https://www.facebook.com/david.fulli...epa=SEARCH_BOX
Fred
06-24-2020, 07:09 PM
Cobra Make, Engine: Backdraft cobra FE big bock
Looks cool, but I would be very concerned about the pressure exerted on the trunk strut mount, when closed. It just looks like it would stress that area....
06-24-2020, 07:35 PM
NJ
Trunk strut mount???
I am guessing you are referring to the bottom mount. It would all depend on the pressure the shock exerts. When the trunk lid is in the vertical position, the only pressure exerted would be gravity but in the closed position and the shock compressed, the force would be shear force against the sides of the mount and mounting bolts and not pushing or normal force directly down but across attachment.
06-24-2020, 10:36 PM
Cobra Make, Engine: BDR Iconic 427 (Dart SHP-Ford 351W)
Think this would be a great addition to my BDR. The question raised on "stress" now concerns me. With the new hinges being designed for this application, does the possible stress issue become a moot point? FredG, can you share the designers email address?
Thanks Gus
06-25-2020, 04:38 AM
NJ
Cobra Make, Engine: BDR #1604, VMS 427
I heard that Backdraft is offering this same thing on the brand new RG4 Cobras.
06-25-2020, 05:51 AM
Yes im talking about downward force when closing. That is not an area you want to stress fracture. I can see mine flex strictly from the weight of the trunk when open. I cant imagine the downward force on closing be good for that area. It would in my opinion need to be a very weak strut to overcome this. All struts ive seen require a good amount of compression to begin the collapse of the piston.
It may be fine, but to me it would add stress on an already poor design.
06-25-2020, 05:55 AM
NJ
Email Address
Gus
Here is his email address. davidfullington@comcast.net
I just emailed him and asked about the force on the bottom hinge.
Fred
Thanks Gus
06-25-2020, 06:35 AM
NJ
Reply from designer
Here is what I received back when I inquired about the piston force.
The answer to the question is 20 lbs of force. When I got the gas shock I thought it was too much for the hinge, but it is perfect. The hinge on the trunk is very solid because you are using 2 bolts to hold it in place and the trunk is reinforced from the factory at that exact location. That is why I chose to use the stock mounting location. In addition, I didn’t want to drill additional holes in the car. I actually had a custom made gas shock at 10 lbs of force and it was not enough to hold it in place. The lower mount is the stock mount where we leave the bracket connected to the car but take off the special mechanical bracket and put a ball stud in it’s place. The only drilling you have to do is when you remove the mechanical bracket the hole used to mound that piece is too small for the ball stud, so it needs to be slightly bigger. This kit fits and operates perfectly. You will love it. Thank you.
06-26-2020, 04:44 PM
How much are they?
06-26-2020, 06:48 PM
Backdraft Racing Dealer
From whom?
06-26-2020, 07:36 PM
NJ
Cost.
$200 with $25 shipping.
Fred
Originally Posted by Steve Gallegos
How much are they?
06-29-2020, 03:59 PM
NJ
Originally Posted by Cashburn
From whom?
The fellow that is selling them mentioned it to me on an email.
07-02-2020, 04:50 PM
Cobra Make, Engine: Backdraft RT4 - #2145
I have a RT4 with a fastback hardtop on order. If anyone tries this set up with the fastback please let me know if there's enough clearance
04-11-2025, 07:20 PM
AL
Cobra Make, Engine: Backdraft BDR RT4
Re-start an old thread
Re-start an old thread.
I have a BDR RT4 and like the idea of the gas strut fully opening and holding the trunk open more.
So wanted to ask after many years of usage if everything was still holding up and if you have had any stress cracks etc at the body of where bracket is mounted?
Thanks in advance for a followup of where you have now used this shock absorber for more than 4 years.
Backdraft BDR RT4 427 Number 2172
