03-23-2006, 10:46 AM
LU
Cobra Make, Engine: Backdraft
Scattershield for a 302 ¿neccesary?
Hi Guys! I've been reading posts related with sccatershields, clutch explosions...etc. My BD is on the boat and the next month Jay in Vintage will finish it with a 302-345 bhp ans a WC-T5 trans and standard rear. Jay said to me that they use to install scattershield in more radical engines. I will use my car for street and weekend (perhaps a little bit hard driving but not racing). I could upgrade bellhousing to a steel one, but I only want do it if neccesary....Your oppinion? Once the car in Spain it will be difficoult to make modifications...so please tell me all you consider important!!
Alfonso
03-23-2006, 12:45 PM
NC
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
If you don't turn the engine over 5,500 rpm and the flywheel is free of even the smallest cracks, as in heat checks, you should be OK. Tapered steel flywheels--thinned at the ring gear--with small-dameter clutches don't need scattershields. Tilton and Quartermaster supply these assemblies.
Caution: This doesn't apply to plain cast-iron flywheels. Nodular ci flywheels are OK if they are in good shape.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
03-23-2006, 01:14 PM
Az
[quote=speed220mphTapered steel flywheels--thinned at the ring gear--with small-dameter clutches don't need scattershields.
[/QUOTE]
This is completely false.
03-23-2006, 02:45 PM
ny
Cobra Make, Engine: A&C,351W
I asked the same question when I started my cobra. I had a very nice stock bell already and didnt want to spend the time and money on the scattershield.
One of the replies I got just asked "what value do you put on your legs". Had a quick look at just where things would actually be located in the car in relation to my legs and immediatly purchased the scattershield.
You only get one pair of origionals.
Good Luck,
Aaron
03-23-2006, 06:24 PM
NC
Cobrabill: Explain yourself, please.
Tom
03-23-2006, 09:11 PM
Az
No clutch disc/pressure plate/flywheel is immune to failure.
I had a clutch let go in my HEMI GTX years ago.The following was the result:
Disc-completely gone
Pressure plate & springs-completely gone
PP cover-torn and stretched to over 20 inches
Bell housing-all missing but a chunk the size of my fist where the Z bar attached and several quarter size pieces where it bolted to the block.
Inspection cover-gone(obviously)
Hole in the back of a valve cover
Lower corner of the block broken off
Front bearing retainer broken.
So....when you get a scattershield,make it a Mcleod.Lakewoods are worth the hassle.
03-24-2006, 07:42 AM
Backdraft Racing Dealer
Cobrabill,
How many years ago? What condition where the parts involved, all new and when were they produced? Used? What power levels are we talking with that Hemi? What RPM and what environment did it let go?
Just getting some more perspective thanks.
03-24-2006, 07:53 AM
Az
Shiiiiiiiiiiiiiiiiiiiiiit-i can't remember what i had for dinner last night.
This was the late Seventies.It had a cam but that's about it.The parts that let go were in the car when i bought it and there wasn't anything left to I.D.
Possibly a Scheifer.But i really don't know.
03-24-2006, 08:59 AM
NC
Cobrabill: I see you have had personal experience with a clutch/flywheel failure, but it was with a large diameter flywheel and clutch. The HEMI GTX didn't use a small clutch or flywheel. I've also had many experiences, but mine have been with hardcore racing. Yes, I've had the disc shed its flacings during a 7,500 rpm shift, but that's not what we're talking about.
You're right, no clutch disc, pressure plate or flywheel is immune to failure, but if the right components are used--I was speaking of small-diameter clutches of under six inches and light, flex-plate style pressure plate--the chance of failure is so low it becomes insignificant providing the components are installed correctly. I am not saying this without base, having designed or cooperated on the design of all types of cars, from Indy, TransAm, Pro Stock and off road, to name a few. Check out the setup Olthoff's use in their Superformance clutch and flywheels. I have seen many nasty stuff when acting as an expert in may cases involving clutch/flywheel failures. But in all my travels within racing circles and litigations, I've never seen a clutch such as the type I have mentioned fail due to centrifugal forces.
By the way, I have a Lakewood b/housing fitted to the back of my 427 s/o.
Here's a picture of a '40 Ford Gasser with a sb Chevy in that had a flywheel come apart during an 8,000 rpm shift. This was in the early days when scattershields were not required. This is why NHRA institued the requirement.
Tom
03-24-2006, 04:04 PM
See the clutch explosion stories always start with .... "back in the 70's" or "fat slicks on the back" etc. This is what I was getting at.
