10-20-2007, 09:07 AM
Cobra Make, Engine: BDR Car # 186 & Keith Craft Aluminum 427 Windsor
Right Turn Signal Working Intermittently
I have BDR 186 and the right turn signal started working intermittently. I changed out bulbs and the relay but it didn’t fix the problem – left flashes normal and right is a hit and miss. The turn signal assembly is not the greatest in the world and wouldn’t be surprised if that is my problem. Any thoughts or has anyone had to change out the turn signal assembly?
Rod
10-20-2007, 10:23 AM
Ill
Turn signals are designed to work intermittenly
Now if it doesn't work, or stays on all the time=====
Check for proper grounding---fiberglas cars and boats---
Jerry
10-20-2007, 10:42 AM
Turn signals on a boat????
10-20-2007, 02:30 PM
All right, you got me on the intermittently. Let me rephrase this - sometimes the right turn signal works….sometimes it doesn’t. I will check for grounding. Thanks
Rod
10-22-2007, 11:46 AM
OK
Cobra Make, Engine: BDR #139, Indigo blue, white stripes, KeithCraft 351W, 315 WHP, 17" Boyd Smoothies, dual roll bars, gunrack, assorted young females
I was told that the turn signals on build #139 were Volkswagen, and that they are dialed-in by some set-screw-thing.
Mine have never worked properly from Day One.
I'll be watching this thread, I'm tired of getting busted by local PD and state HP.
UT
Eagles soar- but weasels don't get sucked into jet engines.
10-23-2007, 05:48 AM
my rh signal has never worked consistantly either, more not, than working...I don't believe relays, bulbs, or grounds are the problem. Both sides would be likely affected. I believe it's something in the mechanism in the wheel, that I haven't gotten around to fooling with yet. Several times have come very close to getting creamed while making a turn...and have received an extreme amount of hand gestures and cussing out. (Can't blame them!) With the tiny wheel in these, you need both hands on it to make a tight turn.
10-23-2007, 10:06 PM
cbreez- sounds like you are driving too slow.
10-24-2007, 04:37 AM
Il
Cobra Make, Engine: LA Exotic
Had the same problem when I had the wife check my lites while I was in the car. She said now it is working, now it is not, now it is, now it is not. jeesh..
10-28-2007, 11:27 AM
fl
Cobra Make, Engine: Backdraft #985 Custom Pro/ Street Race Car, full cage, dry sump 427W and G Force T-56 Fully Street Legal!!
Rod,
I've had a similar issue, but with quite a bit of track time scheduled, I haven't had much time to focus on things lower on the priority list, up until this morning.
I removed the steering wheel and hub, then then turn signal assy, unplugging it from behind the dash. After ohming out the assy, a found no continuity between the input wire and right turn wire when activated.
With the assy in my lap, from the back there is a large snap ring that holds everything together. After dissassmebly, I found a fair amount of dirt ( alum shaving dust and some kind of antiseize) on the electrical contacts and inside the whole assy.
After cleaning everything with WD40 and a clean rag, reassemling all the bits, and Viola. She works like brand new. It's all really simple in there, and it wouldn't take much fpor it to not work at all.
Hope this helps,
Richard
Life is short, live like you mean it!!
Live every day like it's your last. One day you will be right!
