December 2025
Old 02-15-2011, 11:39 AM
Cobra Make, Engine: Classic Roadster II
Default Parts I need for completion
Its been 18 months in the works, but she's just about complete. I need a couple items if anyone can help.
1) Tag light and holder (I bought one from Finshline, but wrong size)
2) What kind of rubber is everyone using on the trunk for a seal
3) Trunk and hood holders (looking for something very nice)
Thanks,
Krewton
Old 02-15-2011, 12:35 PM
Krewton,
Here is a link for the light recently.
I need a part--?
DV might be able to chime in on the rest.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Old 02-27-2011, 03:29 PM
Cobra Make, Engine: Classic Roadster II, 351 windsor, Tremmec T-5
Default Trunk Seal
Krewton,
I used the "bulb seal" which was supplied by CRII until I realized that the seal did not make adequate contact with the interior surface of the deck to make it watertight. I had a gap, which was greatest across the top and tapering to none down the sides.
I replace the CRII bulb seal with a larger bulb seal. I found this to work for me.
Mfg. Name: Precision
Mfg. Part #: UWS 160-25 (25 designates the length as 25 feet)
Supplier: J.C. Whitney
Supplier item #: 132561
Cost as of 2009 was $34.99 plus $8.99 S&H
I placed one continuous piece up one side, across the top, and down the opposite side. It was too thick for the gap I had across the bottom. I used the seal from CRII, which was adequate. I was able to tuck the bottom seal, which was smaller, into the upper seal and provide for an overlap. Rather than a butt joint.
Hope this helps. Twood
