1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
08-07-2013, 07:47 PM
CA
Cobra Make, Engine: 1966 Classic Roadster
Side Pipes
I need to either fix or replace my side pipes. The muffler inserts are rotting out and rattling. Does anyone know if a place that can make a repair then re-coat them or am I going to have to replace them.
If I have to replace them, then I need a place that is familiar with class roadsters and can build to fit. Any suggestions would be appreciated.
Thanks,
Greg
08-07-2013, 08:10 PM
CA
I doubt you can repair them. You probably will need to replace at least part. Classic Chambered (and others) can sell you the center muffler section in several lengths, and they can weld on the turnouts too. If your collectors are in good shape, I would think any good exhaust shop can weld them to the new muffler section and mount them. You could either paint with VHT or have them ceramic coated.
08-08-2013, 09:04 PM
CA
What Lippy said is right on. I purchased new mufflers from Classic Chambered Exhaust and had a fab shop cut the old mufflers out and weld the new mufflers in. Then off to get ceramic coated. BTW- the original CR mufflers are very restrictive and I literally picked up about 70hp with the change. I dyno'd before and after so no BS there. I went with the 2 1/2" id x 30" with packing, louvers open to the exit side of the pipe. Much deeper note too.
John
09-12-2013, 01:50 AM
AZ
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
I am in the process of building new ones for the same reason. I should be receiving the parts later today, a 3" mandrel bent "U" pipe to make the two down-turns from and two V-band flanges. My buddy has two brand new mufflers he's not going to use, so he will weld everything together in the next few days.
3.00" Mild Steel, 6.00" Radius, 180 Degree Mandrel Bend Columbia River Mandrel Bending
My present pipes, which are chromed, were modified with V-band clamps a few years ago so I could easily switch to shorty, wide-open pipes for the track.
I believe I will paint the new ones white with "Flame-Proof" paint, I think it will look good with my paint scheme.
I'll try to get some pictures in the next few days after we start on the project.
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
09-12-2013, 09:07 AM
CO
A couple of years ago I cut my FFR mufflers out and welded in some new ones from Classic Chambered Exhaust. Not a difficult process, really. But the results are impressive. I didn't do any dyno testing. But the sound is much better; not as harsh, not as loud.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
09-12-2013, 11:42 AM
ca
I have a new set of side pipes for my Contemporary I'm not going to use.
09-12-2013, 02:59 PM
nm
Cobra Make, Engine: 1965 Shelby Cobra, 427FE side oiler, 4 speed top loader, dual holly carbs. Carbon Fiber Frame.
Mufflers
Go to the for sale section and in the search tag, put in mufflers. Look at the ones that I put on my Cobra. These are extra, but read all about them. These will last a very long time.
09-13-2013, 09:58 AM
IL
Cobra Make, Engine: Classic 427, I purchased it May 2005, the kit was bought in 1991. I'm not sure when it was completed! Installed GMPP Connect & Cruise 376/525 with T-56 S/M 3.55 gears about 2 years ago! 1/4 miles is with old setup!
Thanks,
Greg
I did my own headers and all. Photo's are on the board here someplace! I used 3" ID Cherry Bombs, they flow much better and sound good! I think they look good check the photo's
Al
I want to do right, Just not right NOW!
09-13-2013, 10:30 AM
Member of the north
Cobra Make, Engine: A Cobra
Just a suggestion.
Whatever you do, do it with your intent on the vehicle.
I had creamic, chrome over and was getting into SS. But I drive my car.
I ended up, after several years of different pipes, steel that any skilled welder can make and painting them with high heat semigloss black.
If the paint chips or gets FUBAR, I blast and repaint.
Just something to think about.
Tru
09-13-2013, 12:08 PM
NC
Cobra Make, Engine: Lone Star, 351-c
Tru, what kind of mufflers did you use. My pipes, from 1997, are still good, but way too loud. I want a slightly quieter, and deeper tone, and have a skilled exhaust guy to do it for me. He may not be sure on muffler selection. Thanks! Chris
CHRIS POTTER
09-13-2013, 05:20 PM
IL
Here is the link to mine! Diy The turn-outs ($10-12) are welded to the Cherry Bombs and you could weld them to your CR collectors. They are not that loud until you step on the pedal hard!
Diy
Al
09-13-2013, 06:37 PM
AL
Classic Chambered Cobra Pack
Classic Chambered Exhaust Inc. - Home Page
if you want a quieter muffler then buy longer ones. I replaced my 24" with 28" and they are quieter.
Dwight
09-13-2013, 06:44 PM
AZ
Originally Posted by Lightingrod
Here is the link to mine! Diy ...
Diy
Al, I looked at your build-site and shot off an e-mail to those guys you used for coating. I only need the mufflers/downturns coated and asked for a quote from them.
I gave you credit for advertising for them!
Ralph
Burma Shave
09-14-2013, 09:30 AM
IL
Thanks, I'm pretty happy with their work and service! They did the Cobra as well as the 2" SuperComps on my old 454SS truck.
Al
09-14-2013, 12:48 PM
CT
I had the Corvette side pipe muffler modified to fit in a shell and prior to the turn out used an internal baffle from a Harley exhaust.. Quieter than the Arizona Exhaust, no longer in business, mufflers and for mild street driving could not detect any performance degradation.
09-14-2013, 07:11 PM
IL
3" ID, 4" by 30" body and 35" overall Cherry bombs are $76.00! Now I know LOUD is a relative term! The Cobra is not as loud as my old truck (3" super 40's) but then again it does set off car alarms! If, again if the Cherry Bombs are not to loud for you I think they are a real good deal and they come in a lot of different sizes!
I had the Cobra out this afternoon. A Boss 302 Mustang wanted to play, he got SNAKE bit! I was on my way to the VFW, a few minutes later a friend stop by. He heard us go by and said he knew it was me! His house is close to the road, so?
Options, are always good! Look, listen, research and then make your own decision, chances are you will have a better result than all of us put together, and that's the purpose of this board!
Al
