Old 12-16-2015, 02:35 AM
Double Venom's Avatar
Fella,
Tom's red scoop is about dead on, you OR your fiberglass guy is going to split the scoop dead center from front to less than a 1/4"
To the back. Use the DOOR CUT OUTS for filler, cut strips out to match your new configuration. Each strip will be cut in a pie shape
Making the hood as TALL & WIDE AS YOU NEED IT. Cut the BOTTOM OF the original scoop flush with the surface of the hood.
MARGLASS/ DURAGLASS the pieces in place, once you've got it the way you want them, reinforce it IN OUT with MATT.
Body work ' then prime etc.
DV
