November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree440Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
  #281 (permalink)
Old 02-02-2020, 04:34 PM
xb-60's Avatar
Will you leave it a bare aluminium panel? (I would)
  #282 (permalink)
Old 02-02-2020, 06:30 PM
Bill D's Avatar
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
Yes. It will be sanded to give a nice brushed finished
xb-60 likes this.
  #283 (permalink)
Old 02-03-2020, 04:18 PM
Bill D's Avatar
Added a notch to the fiberglass for the door light wires to pass thru. Then sanded the panel with 220 grit and finally 400 grit.mthen countersunk the rivet holes. Time for other door
1985 CCX likes this.
  #284 (permalink)
Old 02-14-2020, 08:39 PM
Bill D's Avatar
Original cars had a bracket welded to the body to which the hood prop rod was attached.
Since I can’t weld aluminum to the fiberglass, my only option is to mount it to the firewall with rivets
  #285 (permalink)
Old 02-14-2020, 08:41 PM
Bill D's Avatar
Spent the last few days trying to find a picture of a 289 engine bay that shows the prop rod retaining clip. Today I found it.
And then searched for “metal prop rod retaining clip”. To my surprise, I found one. Made for early Jaguars. Ordered it tonight
Life is good
  #286 (permalink)
Old 02-14-2020, 08:44 PM
Bill D's Avatar
Hood prop rod and associated hardware installed.
  #287 (permalink)
Old 02-15-2020, 04:41 AM
1795's Avatar
Nice job Bill You're almost there. Just in time for driving weather.
Jim
  #288 (permalink)
Old 03-09-2020, 10:11 PM
Bill D's Avatar
Finished epoxying the faux rolled beads on the transmission tunnel cover. Still need to doma final sanding with 320 grit sandpaper. Will install when I get the car back from paint.
  #289 (permalink)
Old 03-10-2020, 08:13 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
You forgot cup holders?
Amazing project, I have enjoyed following your progress.
Blas
SPFWiringDiagrams@Comcast.net
  #290 (permalink)
Old 03-20-2020, 06:37 PM
Bill D's Avatar
One door panel and the transmission tunnel cover are complete and ready to install
1985 CCX and Mongoose930 like this.
  #291 (permalink)
Old 03-20-2020, 07:01 PM
xb-60's Avatar
Wow....nice work Bill
Finish line is coming closer
Glen
Bill D likes this.
  #292 (permalink)
Old 03-21-2020, 10:18 PM
Bill D's Avatar
All the panels are complete. Whew!
  #293 (permalink)
Old 09-22-2020, 09:44 PM
Bill D's Avatar
I have an update. It’s not good.
The painter is having difficulty fabricating door hinges that open the door far enough to prevent the doors from hitting the body. Not his fault. He’s not a custom fabricator. Coupled with the virus pandemic no progress after 6 months.
This has me in a quandary. Do I just leave it and hope something miraculous happens? Or do I bring it home and at some point in the future find a custom fabricator? Either way, I’m just depressed and would really like to sell it to someone who is motivated to finish it. I’m just no longer interested in the project
  #294 (permalink)
Old 09-22-2020, 10:10 PM
CompClassics's Avatar
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Can you post a photo of the issue and the hinge mechanism?
  #295 (permalink)
Old 09-22-2020, 10:13 PM
Bill D's Avatar
No. The car is in another city and the doors are not mounted.n
I’ll try to describe the problem
Now, when you open the doors, the leading edge of the doors hits the body before the doors are fully opened. Trying to fabricate new hinges that move the doors out further to be able to fully open them
  #296 (permalink)
Old 09-23-2020, 12:57 AM
ALF's Avatar
ALF ALF is offline
Would the door hinge limiter straps not be an option?
As sold by Nick
Bill, don't stop your great work.
My car has left for painting in December 2019 and is still not back.
You're not alone with this kind of frustration.
AndrewB and 1985 CCX like this.
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
  #297 (permalink)
Old 09-23-2020, 03:35 AM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
Bill
Stick with it, the doors hinges can be tricky to get right, believe me I know.
I use a steel stop for the hinge so the door won't open into the cars body as your describing.
I would not trust the original strap type by it's self.
  #298 (permalink)
Old 09-23-2020, 07:36 AM
jolsen42's Avatar
When you say the doors hit the body, and what do you mean fully open? If you are using the FF hinges they are adjustable up and down and in and out. Has he tried shims? Mine can only open to between 60-75 degrees open with limiting straps. That's more than enough to get my fat ass in. Have you called Bruce and see what he recommends? Contact "Ivy Green" on this forum, he's building a "Bruce" roadster and see what he's done, Stacy is very helpful. Don't you DARE whimp out.
John O
jjo42
  #299 (permalink)
Old 09-23-2020, 09:33 AM
Ivygreen65's Avatar
Bill,
I had struggles with Bruce's door hinges also. My issue was that the top arm of the hinge was about 1.5" up into the dash and I couldn't open the door due to interference with the dash. After some surgery, I was able to relocate the arms on the mounting plate and make them work. I also added bronze bushings to tighten them up and make operation quite a bit smoother. This doesn't sound like the issue that you have, but know that your struggles are shared by others. Bruce makes you think outside of the box in order to make things work sometimes.
I'm having issues posting photos, but if you'll PM me your number, I'll text you some pics of what I did with mine.
Stacy
  #300 (permalink)
Old 09-23-2020, 10:27 AM
My door hingers are different from the f-5 hinges, the solution with the fiberglass dash is to trim the ends of the dash to clear the hinge, The reason the hinge arms are spread further apart is to stabalize the door for a more solid feel, that is why the are made of 3/8" plate, arms close together= more flex on the hinges, as for the bronze bushing, I musta missed shipping them with the body/frame. As for Bill D, the doors were hung and clearanced when the body/ frame was shipped. I sent 4 round shims to put between the hinge post on the frame and the door hinge, this spaces the hinge out so the door opens 90 degrees when it's open, keep in mind the body was made to fit onto the F-5 frame so there is some fludgeing needed to make things work.
jolsen42 likes this.
Rate This Thread:
