Like Tree107Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average. Display Modes
  #121 (permalink)
Old 02-11-2021, 03:03 PM
1795's Avatar
I have done a similar thing like Tony and went to a local car parts store and found a section of a standard hose that worked.
  #122 (permalink)
Old 02-11-2021, 04:58 PM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Mike,
It may not be ideal since it will be visible but I had to fabricate a lower hose for my car. Could you use the 90 degree like Patrick showed above plus a 45 degree hose joined by a coupler? You can find 45 degree hoses and couplers here: http://www.pegasusautoracing.com/adv...=3COOLHOSETYPE
rads42 likes this.
  #123 (permalink)
Old 02-12-2021, 12:34 PM
Cobra Make, Engine: CSX Cars
Mike,
In the past on the car builds we ended up just going to a parts store that had a number of tubes and just looked thru all of them in the back. Usually found one that was close and cut as needed.
Allan
A happy SAI customer
Cobra Make & Engine: Continuation Series Shelby Cobra, CSX 7034 the most accurately detailed Continuation Cobra to original specification since the demise of CSX 4027.
  #124 (permalink)
Old 02-12-2021, 12:56 PM
ERA 626's Avatar
Originally Posted by CJ428CJ View Post
Mike,
Thank You Chris... I think I will go that route...
  #125 (permalink)
Old 02-12-2021, 07:41 PM
ERA 626's Avatar
Made a custom thermostat housing that attaches directly to the bottom of the kirkham header tank...
jehammer1952 likes this.
  #126 (permalink)
Old 02-13-2021, 12:10 AM
Registered User
Hi Mike,
great work.
What brand of hose and fitting's are you using?
Regards Mando.
  #127 (permalink)
Old 02-13-2021, 11:03 AM
ERA 626's Avatar
fittings are setrab and the hose is summit
  #128 (permalink)
Old 02-26-2021, 01:21 PM
ERA 626's Avatar
The time is almost here!! Today we did all the diagnostics for the EFI system (megasquirt) found a few minor issues I fixed, Set the timing. All I need to do is put everything back together and start it for the first time!!! I needed to fab up a bracket for my coolant tank, it is not sitting tin the traditional place like a typical FE, but I wanted the look of the FE header tank. I had a machine shop make me a thermostat housing that attaches he bottom of a Kirkham header tank. see photos above... while drilling and tapping a screw in the housing I broke the fuk tap... :-( so I ordered a 1/4" tap extractor, I hope it works... As soon as I get this done I put it together and fire it up!! Then off to the alignment shop... then the fun starts at the DMV...
  #129 (permalink)
Old 02-27-2021, 04:12 PM
ERA 626's Avatar
filled it up with 50% distilled water mixture and found a leak. Turns out the the machine shop did a nice job making the thermostat housing but did not bother to check if the screws holding it together were the correct length... they were bottoming out. I need to take apart the header tank/thermostat housing and troubleshoot the issue, 45 min later all put back together all good... Its ready to fire tomorrow morning and establish a baseline tune.
FFR428, sgianino, 1985 CCX and 1 others like this.
  #130 (permalink)
Old 02-27-2021, 04:39 PM
Cobra Make, Engine: NAF 427
Hi ERA626. Beautiful looking EFI system you have there. And that's quite a covey of coil packs you have on the firewall.
What ignition set-up are you using?
And where do you draw manifold vacuum for the MAP sensor? A vacuum reservoir somewhere?
Greg
  #131 (permalink)
Old 02-27-2021, 05:05 PM
ERA 626's Avatar
Greg
we are using a megasqurit...there is a port on the rear on the valley plate for the MAP vacuum tube, then it goes to the ECU. look on my build photos it shows detailed photos of this... The design is amazing.
  #132 (permalink)
Old 02-27-2021, 08:03 PM
Cobra Make, Engine: SPF832, 466cid
Mike,
How did the black satin ceramic coating on your exhaust turn out? If I recall, you used Accessories Plus in Belmont.
Your car looks fantastic!
Curtis
  #133 (permalink)
Old 02-28-2021, 09:29 AM
ERA 626's Avatar
the guy in belmont was an a$$ I think he ended up going out of business... I ended up taking everything to capps in fresno and had it done over again... The black looks nice but it scratches easy... I may end up using a spray on paint or having them done over in silver...but for now I want to drive it for a while.
  #134 (permalink)
Old 02-28-2021, 09:56 AM
HPC did mine in Black satin 20yrs ago and not a scratch......like with a black car you have to be really careful and that includes clearing the seatbelts from the lap before attempting to get out otherwise they become catapults and end up on the pipes.
  #135 (permalink)
Old 02-28-2021, 06:16 PM
ERA 626's Avatar
1st start went well today, at first we thought the cam sync was off 180 degrees, we checked all that and then after checking the settings in the software we made one change then BOOM it fired right up.... no leaks all good... all in all a good day... now the tuning starts... once we get a base tune on it i will most likley take it to a chassis dyno shop.
Randy Rosenberg likes this.
  #136 (permalink)
Old 03-07-2021, 07:47 PM
ERA 626's Avatar
My builder (Neil Ruegsegger) Made me some air filters.
CJ428CJ, 1985 CCX and Blacklemming like this.
  #137 (permalink)
Old 03-28-2021, 04:54 PM
ERA 626's Avatar
She is almost done... I couple photos of the progress, alignment shop... While I was building the car I put a scratch on the rear quarter panel of the car... to fix it correctly we had the clear the whole rear of the car... Thats OK I wanted to wet sand the stripes anyway...
1985 CCX likes this.
  #138 (permalink)
Old 03-29-2021, 07:55 PM
xb-60's Avatar
Great Progress Mike!
Engine looks top notch, and the overall effect of all black except for the red stripes is excellent.
I'm not normally a fan of stripes, but that combination with body, wheels and pipes in black looks perfect!
Glen
ERA 626 likes this.
  #139 (permalink)
Old 03-29-2021, 08:40 PM
ERA 626's Avatar
Thank you Glenn
  #140 (permalink)
Old 03-29-2021, 10:19 PM
xb-60's Avatar
Originally Posted by ERA 626 View Post
Thank you Glenn
Easy comment to make, Mike. It's a nice looking- but mean looking - car
So, it's not far off being road-ready, then?
Incidentally, I have seen (in person) Mando's Morrison setup. He is indeed a perfectionist!
Glen
