2Likes
Post By bkozlow
Post By eschaider
06-07-2021, 06:47 PM
NJ
what temp does your car run at w/ Fluidyne Radiator
What temp is your car running with a fluidyne radiator and a FE motor? I’m using a 180 thermostat and a 16” fan and running 90-100c.
Jon
06-08-2021, 07:07 AM
Ill
when you convert C to F its 1.8 degrees F per each degree C----so 90*C is 180*F
06-08-2021, 07:34 AM
NJ
c to f
90c is 194f
jon
06-08-2021, 08:35 AM
180-190 F but mines a 289
06-08-2021, 03:24 PM
mine runs at 80c even on very hot days.
06-08-2021, 05:39 PM
NJ
Thermostat/fan
What temp Thermostat and CfM fan are you using?
Jon
06-08-2021, 07:03 PM
Cobra Make, Engine: built the molds and body composite construction
More info is needed, is your fan a pull through or a push through, are you running a shroud, any idea what CFM the fan is, 16 inch fans have different flow rates, whose manufacture. Does the temp go down once you start moving? Are you running an under drive pulley on the water pump? If you are not running a shroud that would be the first place I would start.
Bill K
06-08-2021, 07:21 PM
SC
Jon
180-190 degrees with a 180 degree thermostat is pretty normal for highway driving, expect it to spike in stop and go traffic.
Two ways to go
https://www.flex-a-lite.com/electric...ontroller.html
or
The two speed electric fan from the 1994 to 1998 Ford Taurus or Mercury Sable with the 3.8L engine, don't laugh, It's a 16" diameter fan on low speed 2000 CFM, high speed 3500 CFM Does have a tendency to pull a lot of amps, but cools BB hotrods very well.
Bill S.
06-09-2021, 05:55 PM
NJ
What I was looking for is if you have a fluidyne radiator and a FE what fan are you using successfully to keep the motor cool. I don’t have room for a shroud
Jon
06-15-2021, 08:55 PM
Black Magic shrouded fan. 427 runs 80c even in Arizona.
Dan in Arizona
CCX3209
06-16-2021, 09:10 PM
Cobra Make, Engine: FFR Ford
I installed pusher fan's, I turn them on with a toggle switch when driving in traffic or slow thru town. I still have a Spal puller fan as a primary. Big block with a Be Cool Radiator, temp. stays around 190.
06-18-2021, 07:26 PM
NJ
I don’t have room for a bigger fan. The distance between the back of the fan and the steering rack is 3/4”. I do have a pair of pusher fans which I just got wired and hope they help the problem.
Jon
06-23-2021, 09:52 AM
Without having to use a chart the conversions back and forth between ˚C and ˚F can be done with the following two converters;
˚C to˚F
(˚C x 9) ÷ 5 +32 = ˚F
....100˚C x 9 = 900
.... 900 ÷ 5 =180
....180 + 32 = 212˚F
Going the other direction,
˚F to˚C
(˚F - 32) x 5 ÷ 9 = ˚C
.... 212˚F -32 =180
.... 180 x 5 = 900
.... 900 ÷ 9 = 100˚C
100% accurate in both directions no matter what temp you start at.
Ed
06-23-2021, 03:25 PM
Or... just ask Alexa.
06-27-2021, 06:52 AM
Hey Jon
Your temp seems to be pretty accurate. In the cool months (Florida) it takes a while for my engine to reach 180 /190. In the summer months 190 is about right driving and will go to 210 in traffic. As soon as I start to get moving and some air flowing across the radiator it will settle at 190. My temp never exceeds 210.
Running Griffin 3 row, w/ Black magic temper control fan. I do have pusher fans but they really don’t help much only prolong the increase in temperature when at idle in traffic on a hot summer day.
FYI as long as your not overheating and you oil temp is getting above 160, you should be good. You just want to make sure your temperature is cycling when applying air across it (fan or driving) and your radiator should be good.
Hope it helps.
