Old 03-15-2010, 02:29 PM
Rick, I think that is right, hot water from the motor, not from/after the radiator. It APPEARS that I have a second port beside, behind or nearly under the distributor, mostly it's covered up by the front carb. Gonna be real tight getting a fitting in there. I might move my temp sensor to that hole and use the temp sensor hole to the intake side of the heater, through the heater valve first of course.
I suspect heater hose fittings were not a big priority when Ford designed the Hi Rise intake.
Old 03-15-2010, 02:37 PM
Any chance you could post a nice photo of what it is you're dealing with?
Old 03-15-2010, 02:44 PM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Not sure of how much room you have Ernie, but there are 90* fittings that may serve your purpose.
WDZ
