Old 08-15-2010, 12:39 PM
Default Crotch Belt Install in ERA 757
Finally got around to installing my crotch belts . Thanks to a solution Bob P. at ERA came up with , installation was easy .... and more importantly , attaches the mounting plate/belt to the frame member that runs under the seats in the proper location . The frame has nut serts installed ( 6 ) for the bolts to connect to ..... frame isn`t tapped for the bolts . All hardware is grade 8 .
Bob has dimensioned drawings if anyone is interested in doing this .... however , check with him on your specific chassis/seat combination . I have no idea if this can be used on anything other than an ERA .
I did have to bend the belt attachment tabs 90 degrees as it felt like I had a proctologist under the seat when I hit a big bump at speed .
Here are some pics .
Bob
