Old 09-07-2014, 03:13 PM
Jeff Frigo's Avatar
Cobra Make, Engine: ERA 454 S.O.
Default No Instrument Light
Bob:
I was driving home last night and lost all of my instrument lights. I'm not good with electrical items. I checked all of the fuses, all good. I rotated the dimmer switch back and forth and got nothing. Car #269.
Jeff
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
Old 09-07-2014, 09:58 PM
Jeff Frigo's Avatar
Update something is loose, when I hit bumps they come on then back off again. Tell me where to look.
Jeff
Old 09-08-2014, 03:34 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
I'd start with the gauge ground first, then where the gauges pick up power.
Jack
XSSIVE .....
Old 09-08-2014, 05:41 AM
Put both the rheostat (dimmer) connections on a common side and see what happens. The rheostats have been marginal.
Old 09-08-2014, 07:54 AM
Jerry Clayton's Avatar
poor ground of the fiberglass dash----run a test ground lead to any single bulb that you can reach and see if it comes on-----------
Old 09-08-2014, 09:01 AM
On an ERA, if you lose the light circuit grounds (at the steering column mount), you will also lose the tachometer ground and it will also cease to function.
Old 09-08-2014, 03:59 PM
Jeff Frigo's Avatar
The tach was always been a problem, I will check the ground, thank youe.
Jeff
Jeff
Mark Donahue
