Like Tree1Likes
Old 06-03-2015, 12:28 PM
davids2toys's Avatar
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Originally Posted by Dangerous Doug View Post
I'll send a pic via PM. Posting a pic on cc using my iPhone isn't easily noodled out.
The plastic reservoir is for the 10 oz reservoir. The link I sent is for the smaller reservoir which is billet aluminum. It is a bit confusing, but ordering that part I did get real billet aluminum reservoirs.
I didn't actually order those particular lines. I think mine are Russell Performance lines. Just posted that as an example of the kit. You'll have to look at what you're replacing and then match it.
Doug
Doug sent me these and I am posting them for him
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
Old 06-03-2015, 12:30 PM
Dang, that's pretty fancy. Makes my Girlings look like they came off a Model T... which they pretty much did, I guess.
cobra likes this.
Old 06-03-2015, 06:17 PM
Patrick, is there a pic somwhere of those girlings in you car?
Old 06-04-2015, 05:08 AM
Here you go. They're the traditional cans, with little hand cut gaskets at the top to absorb the occasional splash drop that gets out from under those Dorman gaskets I show above. They do not leak and, after almost 10 years, they have a lovely patina.
Old 06-03-2015, 07:42 AM
I just ordered a 2 oz tube of "Seal-All" on Amazon for 4.00+, just to have imn my toolbox as you suggested in the thread.
Thanks for passing that along
Old 06-03-2015, 12:53 PM
Did some of you installed the wilwood D52 calipers Bolt on system
This solution seems to be the easiest way to upgrade the GM calipers
Nô modification for installation
The performance are as expected ?
Old 06-03-2015, 06:15 PM
Pretty good price for the colors, 100.00 cheaper than the SSBC colors. I wonder why they do not list them for a 1975 Chevy Camaro on Summit?
Old 06-04-2015, 04:33 AM
DanEC's Avatar
Everyone refers to these brakes as Camaro brakes but I think these are actually generic GM Calipers used on most medium and larger GM cars trough the 70s and into the 80s. Does anyone know if this is correct?
ERA 782 Running
Old 06-04-2015, 06:37 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
That's pretty much a correct statement. GM made the D52 and D54 calipers. The D54 are metric calipers and the distance between bolt holes is about 5 1/2 inches, while the distance between bolt holes on the D52 is about 7 inches. Easiest way I know to tell the difference.
Jack
XSSIVE .....
Old 06-05-2015, 05:30 AM
Patrick,
Sweet pic, looks great...thanks
Old 06-05-2015, 11:11 AM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
Yes, they are a generally used caliper used on everything from the Camaro and Chevelle to station wagons.
Dangerous Doug
"You're kidding, right?"
Old 06-06-2015, 06:23 AM
Lately we been getting DOT-approved S.S. lines from Fragola Performance. Summit has a lot of their line, although we deal direct. They will make custom assemblies.
Old 06-06-2015, 07:19 AM
cobrajeff's Avatar
Default Girling type brake reservoirs
I ordered my ERA 289 FIA with the upgraded front brakes. At the time, ERA did not offer an upgraded rear brake package. I am not particularly fast on the track, but I have found this system to be adequate for my use on the street and at Open Track events.
I replaced the single plastic brake reservoir with a dual reservoir set of cans:
I eventually dropped the third can, as I have an automatic in my car. I ended up putting the voltage regulator where I had originally placed the third can.
I got my cans from Dave Bean Engineering in CA. They carry all kinds of "spares" for British sports cars.
Dave Bean Engineering, Inc. The Official Vintage Lotus Car Parts Distributor
regards,
Jeff
CobraJeff
ERA P 202
Old 06-06-2015, 02:25 PM
Great Bob. So do you have a rear braided brake line you could sell me or provide me a part number for?
Thanks
Old 06-06-2015, 02:40 PM
Jeff,
Nice pics and info...thanks
Old 06-06-2015, 08:58 PM
Sounds good to me too...LOL
Here is the thread connected to that pic. Short and sweet
Help! - Leaking Brake Fluid Reservoir
Old 06-12-2015, 06:58 AM
Cobra Make, Engine: ERA 714
If you upgrade the brakes you should add the LED tail lights according to Patrick and I. It heps blind the people behind you at night!
Phil
Display Modes
