Like Tree141Likes
  #201 (permalink)
Old 02-19-2019, 11:30 AM
Cobra Make, Engine: ERA 3012
Update: I've got the wiring almost wrapped up. I am so impressed with the wiring harness and associated documents that ERA provides. It really makes it nice when deviating from the norm - such as using electrical gauges instead of the stock mechanical ones.
Over the weekend I was surveying where to mount the MSD box and cap. Its funny how you seemingly have all the room in the world behind the dash until the dash is actually installed. I know many mount the box upside down under the glove box, but wanted to avoid that as the MSD manual specifically says not to. I ended up mounting it to the right side of the glove box, and I think that will work, but I wanted to check here to see if anyone had any more creative options.
  #202 (permalink)
Old 02-19-2019, 11:42 AM
You can safely ignore the MSD proscription unless you plan on driving through a monsoon.
  #203 (permalink)
Old 02-19-2019, 01:12 PM
RockBit's Avatar
I see you went with the programmable MSD 6530. You must be planning to program your timing curve. I also opted for the 6530 but have not programmed it so far. I’m working up the courage to do it!
Chris
  #204 (permalink)
Old 02-19-2019, 01:59 PM
Yeah, my plan is to get the car running and dialed in then hide a map sensor and start all over from scratch. Masochistic some may say but I love to tinker .
  #205 (permalink)
Old 03-08-2019, 12:42 PM
Cobra Make, Engine: ERA #3014; 331 CID SBF
Andrew, earlier in the thread you mentioned that torquing down the engine and trans bolts was a PITA. Any insights, recommendations, or tools that might have made it easier? Would love to benefit from your hindsight
Bill
  #206 (permalink)
Old 03-08-2019, 12:58 PM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
The motor mount to frame nut is a pain to get to and to get tight. Get one of these ratcheting flex wrenches. They make the job a piece of cake.
https://www.homedepot.com/p/Husky-MM...CMMN/203424740
  #207 (permalink)
Old 03-08-2019, 01:20 PM
Yep, that is exactly how I did it as well. I just would have liked to be able to get my torque wrench in there so I could get an idea, as well as be consistent, with the torque I applied.
  #208 (permalink)
Old 03-13-2019, 07:03 PM
Got the clock bezels back from chroming today. Time to finish off the dash!
1985 CCX and LMH like this.
  #209 (permalink)
Old 03-13-2019, 07:34 PM
xb-60's Avatar
Looking good Andrew.
Have you leathered the dash panel yet?
Glen
edit: just looked back to post#43, and of course, yes, it was done by ERA
AndrewB likes this.
  #210 (permalink)
Old 03-13-2019, 07:47 PM
Glen
Hi Glen,
Yeah, ERA did it.
Note: I have since swapped the tach and speedo into the correct positions
1985 CCX, LMH, Gaz64 and 1 others like this.
  #211 (permalink)
Old 03-13-2019, 10:11 PM
LMH's Avatar
LMH LMH is offline
Hi Glen,
Yeah, ERA did it.
Do you have the screws in place for the clock?
Alba gu bràth
  #212 (permalink)
Old 03-14-2019, 06:41 AM
1985 CCX's Avatar
I used riv-nuts on the backside thus you can screw directly into them.
A little epoxy on back of dash to nut works
AndrewB and LMH like this.
  #213 (permalink)
Old 03-14-2019, 10:22 AM
Hi Larry,
Yeah, ERA epoxied some studs back there to mount the clock.
LMH likes this.
  #214 (permalink)
Old 03-14-2019, 11:38 AM
Cobra Make, Engine: ERA 714
I have my MSD box under the dash upside down. I have never had any problems. From what I have read the MSD boxes don't like heat and under the dash is cooler than in the engine bay.
Phil
  #215 (permalink)
Old 03-16-2019, 05:59 AM
1795's Avatar
I had mine under the dash upside down no problems as well. From what I recall, MSD does not want them upside down because there are drain points on the bottom of the unit that will allow moisture to escape if the unit gets wet and in the upside down orientation there is no way for moisture to escape. The is more critical if the MSD unit is mounted in the engine compartment or someplace else where the unit could be exposed to water. If the MSD unit gets exposed to water mounted upside down under the dash, the unit getting wet and not being able to drain is probably going to be the least of your worries
Gaz64 and ACHiPo like this.
  #216 (permalink)
Old 04-18-2019, 11:46 AM
Cobra Make, Engine: ERA Slabside 3013, 351W
How is it going with 3012? Love to see your car. I am building 3013. It sat for 12 months before I started the car. Did you go with undercar exhaust? Do you have some pics or advice? I just sent mine out for ceramic coating. Will install when I get it back.
desgros@vtlink. likes this.
  #217 (permalink)
Old 04-18-2019, 12:39 PM
3013 - cool! 3012 is making steady progress. We were able to fire it up for the first time a couple weeks back and do the initial break-in so that was quite the milestone. No real leaks or surprises and no metal shavings in the oil so I'm pretty happy. The thought of wiping a cam lobe is still in the back of my mind though as I've read too many of those horror stories to feel comfortable yet. After getting the timing set it runs fantastic through the rev range, and as suspected, living up to my fear of maybe having too much engine for the car. We'll see how she drives though before I stress about it too much, but it sounds...aggressive. This weekend I'll start working on the interior.
Regarding the exhaust. Yes, I have the full under-car system and if I did it over again I would have trailered the car to an exhaust shop - it has been the most frustrating part of the build for me. Just getting everything lined up, trimmed, hangars marked/welded, etc so the exhaust looked right from the side profile was just not my idea of fun and took a lot more time than I anticipated. Once it was all completed I had the entire exhaust system ceramic coated and I think it came out great!
If you have any specific questions or need a picture of anything please feel free to contact me. I'm more than happy to help.
  #218 (permalink)
Old 05-21-2019, 11:23 AM
Quick update - I've got almost all the insulation work done. Of course I came out just a bit short so I had to order another roll to finish off the foot boxes and rear bulkhead. I used the high temp stuff underneath the floors and the temp/sound insulation on the interior. Quite a bit of time was spent fitting (especially underneath the floors), but it truly is amazing how it "stiffens up" and deadens the aluminium structures so I think it was a very worthwhile endeavor. Now on to the carpet! Anyone have any tips on fitting the ERA carpet before I get crazy with the knife and contact cement?
  #219 (permalink)
Old 05-21-2019, 12:49 PM
vntgspd's Avatar
Cobra Make, Engine: ERA #347
When you say you are finishing the "rear bulkhead", does that include the inner fenders visible in the last photo? I would highly recommend it if you haven't already planned for it. In my car with under car exhaust I find that this area radiates more heat than the footboxes on extended drives. The heat can be uncomfortable on warm days if I'm driving with my left arm/elbow inside the car.
Progress looks great so far!
  #220 (permalink)
Old 05-21-2019, 01:50 PM
dacobb's Avatar
Cobra Make, Engine: ERA 3018 - Lykins 289 H.O. SBF
Did you ceramic coat the exhaust system? Curious if that makes a significant difference or not.
