Like Tree9Likes
Old 10-02-2018, 01:43 PM
vntgspd's Avatar
Cobra Make, Engine: ERA #347
Originally Posted by 66gtk View Post
Any car can go "fast" these days. Cobras like these are fun to drive at any speed and don't require one to go crazy fast to get the awesome cobra experience.
Well said.
Old 10-03-2018, 06:55 AM
fastd's Avatar
Cobra Make, Engine: ERA FIA, 351W
do you have an opinion about the era outboard rear vs the jag inboard rear? is there a different feel? which one do you think is "better"?
Old 10-03-2018, 06:57 AM
fastd's Avatar
and the 351 vs the 427...I have a 351 in mine and I like the way it revs and drives better than a big block...
Old 10-03-2018, 07:25 AM
The outboard rear brakes are much easier to service and I can't really comment on which one is "better" since I don't track the car. The jag style rear end is very nice for a street car. I wouldn't expect a dramatic difference in "feel" for street driving between the two. They both work great.
You could line up 10 seemingly similar 427 FE builds and 10 seemingly similar SBF builds and you would have 20 different performing engines, each with their own mannerisms. Each engine is set up uniquely to the skill and preferences of their mechanics and owners. They all perform differently and they all age differently based on driving style and owner care/maintenance.
These are my opinions that I've shared since you asked. Enjoy your car. If you have a 351 in your FIA, you likely have a winning combo right there, and since you like the way it "revs and drives", don't look back (:
Old 10-03-2018, 09:16 AM
fastd's Avatar
good advice. thank you.
Old 10-03-2018, 11:48 AM
I have the outboard braked rear. From a performance/ride standpoint on the street, there's not much of a difference. But, from a maintenance point of view, repairs and maintenance are much easier. That's not just the brake pads either, if you have to change out a stub axle on the differential you can do it in a half hour -- without having to drop the rear or pull the hub. Popping the half shafts out is quick and straight forward, as is rotor replacement. Let's say you wanted to replace the pads, rotors, and repack the inner & outer wheel bearings. On the ERA outboard braked rear that's an afternoon's job, moving at a leisurely pace and, again, you don't have to drop the rear to do it (although you do have to pull the hub). On an XKE with the inboard brakes, it's a nightmare. On an ERA with the Jag rear, it's less of a bad day, but still a significant PITA. Changing out U-Joints is another example. Go with the outboard braked rear, you'll be glad you did.
1985 CCX likes this.
Old 10-25-2018, 07:30 PM
Cobra Make, Engine: ERA 2092
HI, did you powder coat the roll bar in satin or gloss black , it looks much better black then chrome
thanks Bob
Display Modes
