Like Tree1Likes
  • 1 Post By LMH
Old 12-09-2020, 03:45 PM
Default Top loader tail housing
Hi ,
Question to Bob . For the ERA FIA car, I plan to use a wide ratio 24” long ford top loader, what tail shaft side shifter position is correct ? I have access to all 3 shifter positions tail housings ? The era manual shows a bracket mounted on what I believe is the mid position, so is that bracket to make a mid position into a forward position? If so, can I just use a forward position tail housing and not worry ?
I’d like to prepare the transmission before the car arrives.
Thanks ,
Luke
Luke
Old 12-09-2020, 08:27 PM
LMH's Avatar
LMH LMH is offline
I'm sure Bob can tell you more specifics as they apply to ERA's but CSX2345 for example, didn't use a top loader, rather a BW T-10. The shifter position for small block cars puts the shifter 16" back from the bellhousing, center line of the shifter in neutral. That may help you determine what housing or position is needed.
ERA might be different though depending on engine placement and interior aluminum.
bl5211a likes this.
Alba gu bràth
Old 12-10-2020, 04:56 AM
I can't keep track of all the shifter variations. You'll have to ask Doug via phone.
Old 12-10-2020, 09:20 AM
Thanks Larry
Luke
Old 03-23-2021, 03:21 PM
DanEC's Avatar
Early GT350s used T10s, I believe with aluminum case. I think they switched to toploaders in late 66 or in 67.
ERA 782 Running
