Like Tree5Likes
Old 11-20-2025, 08:27 PM
davids2toys's Avatar
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Default Runs 15 minutes then dies and won't start
Hi guys, it has been awhile. A couple of more surgeries kept me away for awhile. I have a MSD 6AL box and MSD dist.It has a magnetic pickup in the dist which failed way before this problem. It was replaced and has been fine.This new problem started 3 years ago. Pulled into a cruise night and the car just shut off like it ran out of gas. We all did a bunch of trouble shooting and a cobra friend had a brand new coil. Installed the coil, started up and drove it home. I thought it was the answer, WRONG! The following weekend drove it to a party at a friends house. Ran fine for the 1/2 hour ride and then died in his driveway. installed another new coil but it would not start. We parked it in his garage. I came back the following day to screw with it. i had installed a MSD noise capacitor before this problem started so I unwired it and joined the wires together. Still no start. I called my Roadside assistance and had it flat-bedded back to my house. During some trouble shooting it seemed like the ignition switch was questionable so I changed it out. Started it up a few times and thought all was good. Then I had 2 more surgeries which took me out of commission for about 2 years. So a month ago I got it ready to go for the maiden voyage. It ran great! So 15 minutes into the ride I puled up to a stop sign and it just shuts off. Tried to start it back up, no luck. Had fuel at the carb, so I sat on the side of the road for 45 minutes. I figured it might be the coil and might start after it cooled down. It started right up and I raced home before it died again. I have been testing and inspecting everything and it was passing with flying colors. Cap , rotor, Pick up in dist was very clean and tested fine at 674 ohms. Did the paper clip trick to test the box and it was fine. Check all my grounds, fine. I gave up and thought maybe simulate the shutoff / no start condition and then do the same tests while it was hot and not starting after it shut off. Today I ran it in my driveway. It started and ran just fine. After about 20 minutes it just died. Tried to start it, nothing but spinning. Immediately did all the tests again. everything tested good. Also while cranking it had 6 lbs fuel pressure so that would eliminate vapor lock. I let it sit for about 30 minutes tried to start it, fired right up!!! I'm stumped. You guys have any ideas???
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
Old 11-21-2025, 05:25 AM
mrmustang's Avatar
Gold Star Contributor
I'd say either the 6AL box is starting to fail, or your fuel pump.
Do you have an electric or mechanical fuel pump?
Bill S
Old 11-21-2025, 06:46 AM
The other possibility is a failing ignition switch. Check the voltage at the MSD.
Old 11-21-2025, 06:57 AM
PeteF's Avatar
Cobra Make, Engine: ERA2041 sold 2021
I had similar symptoms years ago on ERA2041. It turned out to be the fuel pump. Upon disassembly, I found that the diaphragm valve was a press fit, and would sometimes pop out of its seat and lose fuel pressure momentarily, and the engine would die. Sometimes it would restart and sometimes it wouldn't. A new pump solved the problem.
Old 11-21-2025, 05:36 PM
Bill,I have a mechanical fuel pump and it is reading 6 lbs even when it is on the side of the road not starting.While it is cranking over, I was looking right at the Gage.
I also tested the box while in the stalled no start condition. The MSD tech told me if I am getting the spark using the paper clip test, it is not the box.
Old 11-21-2025, 05:38 PM
Bob, the switch is new. Where and how are you suggesting I check the Voltage at the MSD
Old 11-21-2025, 05:43 PM
That is interesting Pete, I never heard of that. I always thought the fuel pump worked or did not work. I do have a new one on the shelf. It is weird because it has only done this under no load, car hardly moving or stopped. I suppose if nothing else works I may just change it the hell of it
Old 11-22-2025, 03:18 AM
Ron61's Avatar
David,
You have tried about every test but it still sounds like a heat related electrical problem to me. Have you tried pulling a plug wire when it won't start and then turning it over and watching to see if you are getting a good spark to the plug. Mine will arch about 1/2 inch or more so make sure you don't have you fingers at the end of the plug wire when you do this.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 11-22-2025, 09:31 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Coil is going bad.
John
Old 11-22-2025, 10:21 AM
PeteF's Avatar
If you saw good fuel pressure while cranking, then the pump should be good. The coil sounds like the next possible culprit.
Old 11-22-2025, 10:26 AM
PeteF's Avatar
But, rereading your first post, you have changed the coil twice already. I'm out of ideas now
Old 11-22-2025, 01:12 PM
twobjshelbys's Avatar
Coil or wires and connections coukd be heat sensitive. Remove andcre-seat all of them.
Tony
CSX4005LA
Old 11-22-2025, 01:42 PM
Tom Wells's Avatar
David,
I had a similar problem with a 557.
It was caused by fuel boiling in the float bowls of the Holley carb.
The boiling point of today's substance we laughingly call gasoline is so low that my bowl vents looked like Old Faithful. I proved this by removing the hood scoop and the air filter and watching it do exactly that at low speeds. The fuel would geyser up, make a u-turn and go straight into the intake. Instant shutoff.
Highway cruising was fine but in low speed traffic it shut down as if the key was turned off. No coughing, no sputtering, just running fine one second and dead silent the next...
I spent nearly two years trying to fix that (and spare you the details LOL) before switching to Holley EFI - problem solved!
Picture the pressure in the float bowls at zero psig and the EFI at 43 psig. That big pressure difference prevents today's fuel from vaporizing at typical underhood temperatures.
The temperature required for evaporation of today's fuel is probably 50 or so degrees lower (I knew the number but time has swallowed it) than it was 40 years ago when carbs were king.
Another thing to think about, yes?
Tom
Ron61 and G_Edmonds like this.
Old 11-24-2025, 07:01 PM
Ron: by doing ans passing the MSD paper clip test while it is in the no start condition would indicate IO am getting good spark
Pete: I agree with you about the fuel pump and it not being the culprit
Tony: wires are a few years old but have very little time on them.
Tom: Did you really take all the rivets out and remove the scoop??? How about removing the air cleaner and just run the car like I did the other day and then look at the vents when it shuts down. Also I found this video on how to take the ethanol out of gas
https://www.youtube.com/watch?v=BeL_2ecQci4
Old 11-25-2025, 05:51 AM
Tom Wells's Avatar
David,
Whoops! The car was my 1981 Zephyr wagon that sees road course action, not my Cobra so it was easier.
My Cobra had similar fits of stopping so it got converted to EFI about 20 years ago. That cured those problems just fine but it was early days of EFI so there were plenty of other misadventures with Holley's teething problems. After many upgrades it's doing OK now.
I didn't make the correlation until much later with the Zephyr. Plus I had one of the world's best carb guys helping so both of us thought we could whip it. Sadly, didn't happen.
Here's a possibly easier way to get good data: alcohol free gasoline. It's available in lots of stations here mainly for boats and the like. Should be available somewhere near you. If the problem goes away you have an answer. At the very least it should be a big improvement. Only possible fly in that ointment would be if your engine has too much compression for the no-alcohol stuff, say north of 11:1 or so.
On reflection, there's probably not an easy way to observe the fountains directly on a Cobra short of temporarily removing the hood and air cleaner...
Sorry for not thinking that one through!
Tom
Old 11-25-2025, 11:45 AM
LOL, no problem. Even if I ran the car in the driveway with the hood open and the air filter off, it would not be simulating the real world because it would be bypassing the normal under hood temp because the hood would be open.
If i was going to go the fuel injection , I would look into the 8 stack systems because they look very cool.
Ethanol free is impossible to get in CT. I just left a message at our local airport to see if they sell it. I would get it as a diagnostic and if it worked well, as you say, I will know the problem, then maybe switch to fuel injection.
Old 11-25-2025, 11:51 AM
Cobra Make, Engine: built the molds and body composite construction
It appears you have taken all the steps to track down the problem. I would suggest how ever you wrap the fuel lines with an insulator. I feel you have a vapor lock problem and it could be in the fuel lines. Many years ago, I was delivering for a dealer in New York City to Miami a 1962 SWB Ferrari 250 GT-California convertible. It would run fine for 25-30 minutes and shut off as you have stated, cool down and restart for another 20-30 minutes. I am willing to bet that as you temperatures in CT are dropping your run time should increase. If this is true, then find the heat sink, my guess is the fuel lines from the pump to the carb or the carb included. You did not say, if you are running a turkey pan or not, one may help in the future. Plus it looks better under the hood.
BillK
Old 11-26-2025, 09:41 PM
I understand what you are saying. I do have a turkey pan and a mechanical pump.My setup has been the same since I have owned the car, how could fuel vapor lock just start out of nowhere? As I said, as soon as it stalled out in my driveway, I cranked it over and had 6 lbs on the fuel pressure gauge. I would think if I had vapor lock, I would not see any pressure
Old 11-27-2025, 03:40 AM
Tom Wells's Avatar
David,
There are web sites that give locations for buying alcohol-free gasoline. Here's one:
https://www.pure-gas.org/
If you look in CT you can find a list of 32 gas stations that are supposed to have it available.
Hope this helps,
Tom
Old 11-28-2025, 12:50 AM
Cobra Make, Engine: Backdraft. SB 427
Chat GPT: Most Probable Causes (ranked)
1. MSD 6AL box failing when hot
Why this fits perfectly:
Car runs normally until fully heat-soaked (15–20 minutes).
Engine dies instantly, as if key was turned off — classic MSD box shutdown symptom.
After cooling 20–45 minutes it restarts immediately.
Numerous coils tried → no change.
Pickup tests OK cold and hot.
Grounds check OK.
Ignition switch replaced with no improvement.
Important detail:
MSD boxes often fail only when hot, and about 70% of the time they still pass the "paper clip test" when tested immediately after failure, especially if they are in the shade or starting to cool.
Even when they pass the paper clip test, the internal capacitors or the switching transistor can break down under heat + load.
2. Magnetic pickup intermittent when hot (despite 674 Ω)
Even though resistance is correct (MSD wants 500–700 Ω), failing pickups often:
test perfect cold,
test perfect immediately after a shutdown,
but fail only under thermal expansion + vibration.
This can produce the “dies instantly at a stop sign” symptom.
Testing tip:
Check AC voltage output while cranking during a hot no-start. You should see 0.3–1.0 volts AC.
If it drops to 0–0.1, the pickup is dying even if resistance is normal.
3. Heat-soak failure of the coil trigger signal path
You already tried multiple coils — that strongly suggests the coil is not the problem, but the trigger path TO the coil might be intermittent.
This includes:
MSD box to coil wire (heavy red + heavy orange)
MSD box ground path
Small red wire (switched 12V) heat drop / intermittent open
Loose spade connectors at the box
A small-red-wire voltage drop is a known MSD shutdown cause.
