| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
05-08-2002, 05:35 PM
Yet Another Gauge Question
We recieved the Autometer Gauges today and they look great. One question though, what gauges in the SW set are Mechanical and which are electric?
2500 Pounds of steel, rubber, and fire. AAAHHHH!
05-08-2002, 06:41 PM
WA
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Don't have your answer, but this might be interesting....
I have 9 of my 10 Autometer Classic electrical gauges for my build up, the latest one came in, the custom fuel pressure gauge for the fuel injection... with the isolator and computerized box, and shipping, it was $340.00 !!
(It has to be isolated because the fuel pressurized lines should NEVER be in the cockpit)
Good thing the other gauges were so reasonable !
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
05-08-2002, 07:01 PM
Thank you
05-08-2002, 07:05 PM
I have the autometer Cobra replicas..a set of seven
replaced the clock with an oil temp
I have one question for anyone who has done the mechanical pressure gauges ( 2 1/8") It says to use nothing else BUT a SS braided signal line to this gauge from the engine??
Why can't I use the old copper 1/8 capillary tube with the approprate ferrules and nuts
My hole set is mechanaical as was the original Smiths
The autometer classics will come in either.
Tim
05-09-2002, 04:55 AM
Whaler I'm using a 3/16 copper tubing to SW mechanical oil pressure gauge.
05-09-2002, 04:16 PM
Bob, do you know the answer to my question.
05-09-2002, 04:32 PM
Ike - I'm trying to avoid any liability here!
Years ago, I seem to remember some british cars with copper or brass tubing to the gage. They always had a well supported section with several loops so that the movement in any given section was near zero.
Our current Smiths and S/W gages come with plastic tubing, and I'm using a similar setup on my street car.
That said, at least use a length of -4 hose from the engine to firewall. It's cheap insurance.
Bob Putnam
- E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
05-09-2002, 06:47 PM
I think you might be mistaken. My question was whether or not you knew what gauges in the SW set are mechanical and which are electrical.
05-10-2002, 04:36 AM
The S/W gages that we supply have mechanical water and oil temp, and also oil pressure. S/W also makes electric gages for those, although with a different style face.
Bob Putnam
- E.R.A.-
05-10-2002, 05:02 AM
Is the SW tach electric with the three prongs on the back. I know these questions are painfully idiotic, but I would just like to know so I can compare the gauges.
05-10-2002, 06:07 AM
I swear S/W changes their configuration every time we get a shipment...
The current tach has 4 connections labeled (from 1 o'clock) sig, neg, pos, aux. We don't use the aux post.
Bob Putnam
- E.R.A.-
05-10-2002, 07:47 AM
That'll do, thank you very much for your info and time.
05-10-2002, 04:00 PM
NY
Cobra Make, Engine: ERA / nascar side oiler
Does " Smiths " make a volt meter ?
05-10-2002, 07:38 PM
not positive, but I'm pretty sure they do.
| Thread Tools |
| Display Modes |
Linear Mode
