Old 03-25-2006, 06:06 AM
mrmustang's Avatar
Gold Star Contributor
Default 427SC Proper ride height
Can anyone tell me the proper ride height (front and rear) for the 427SC ERA replica? Either bottom of frame to ground, or perhaps center of outer wheel lip to ground.
Thanks in advance,
Bill S.
Old 03-25-2006, 07:56 AM
If you own an ERA, you can get the manual as a download with that information. E-mail me at eracars <at> sbcglobal.net
Old 03-25-2006, 09:35 AM
mrmustang's Avatar
Bob,
Email sent.
Bill S.
Old 03-25-2006, 12:30 PM
Cobra Make, Engine: ERA 427 #708, 427 SO
Bill,
Here it is from the manual.
"Front
The specifications for the standard front spring preload are on page 46. This will result in about 7-1/2" from the ground to the bottom of the front crossmember (5-1/4" to the front of the main rails). The specifications shown below are predicated on the standard tire sizes: 235-60 and 295-50-15. You may change the front height to suit personal taste but be aware that the oil cooler scoop will contact pavement if car is too low.
Once the height is correct, tighten the front upper control are pivot bolts. See Page 87.
Rear
If you have adjustable spring collar shocks, the rear height can be adjusted to taste. E.R.A recommends that the main chasis rails be raked about 1/4" to 1/2" from front to back."
Bill I don't know if you need to see more from the manual. Let me know.
Chris B.
Old 03-25-2006, 12:52 PM
mrmustang's Avatar
Chris,
Got the downloaded manual(s) from Bob this afternoon. Once I get the silver FFR out of the garage, I'll get the ERA out of the trailer and start tearing into it so I can get it on the road by spring...
Thanks..
Bill S.
Old 03-25-2006, 01:03 PM
computerworks's Avatar
It is Spring.
Old 03-25-2006, 01:13 PM
mrmustang's Avatar
Originally Posted by computerworks
It is Spring.
Maybe out on Long Island, but here in NW NJ, I've had snow flurries on and off all day. of course I did have to take a guy from Queens out for a test drive in the Silver FFR so he could then decide to either buy it, or buy a Cheetah someone up in CT
Bill S.
Old 03-25-2006, 04:24 PM
Default Height for an ERA SC
Bill I sent my car up with a 5" height front and back at the corners of the frame behind the front wheels and ahead of the rear ones. The look and stands was good. If you want the car to handle, get the car weighted on scales. You want your body weight in the drivers seat. I did my car with my fat a$$ in the seat and the balance on the car was 5 lbs side to side front and back and made a 3 second differents on a road course. If you are going to go by a tape measure at lease add your weight in the drivers seat. It is well worth the money to setup the car on scales. Find a dirt track racer, and a case of beer or $50.00. It's the best money spent with the most return so far. Rick Lake
Old 03-27-2006, 07:21 AM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
Rick:
So, it's a question of $50.00 or a case of cheap beer?
Does the beer get consumned before or after the weigh-in?
J
