  #21 (permalink)
Old 03-07-2007, 10:20 AM
Default Shifter
You would be surprised at how many " so called machanics" have come into my shop when I had my BB ford, lakewood BH, and TKO 600 with shifter mounted, doing measurements before I installed it and told me my shifter was on backwards.
My reply was---Why haven't you put an aplication in at Walmart automotive department?? They could really use someone with your automotive intellect.
  #22 (permalink)
Old 03-07-2007, 10:55 AM
Cobra Make, Engine: Just a collection of parts right now...
Send a message via MSN to spl310
happy to help!
  #23 (permalink)
Old 03-07-2007, 11:16 AM
Cobra Make, Engine: None yet
Talking
Like the quote that's a good one. I have dealt with some of their personel and I think to myself how'd you ever get this job? But to be truthful, most of them I've dealt with were actually pretty good. It was just those that had that I Know It All attitude that I couldn't stand. I guess a person will find those goof balls just about most anywhere. I've learned to just disregard them and blow them off.
  #24 (permalink)
Old 03-07-2007, 02:24 PM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
Now Chaplin, I may have only "10" miles on this car (which is ERAFIA) but my first two cars were big block ERA427SC cars with what were then called DN4+1 trans and "backward" shifters. Those cars did see some miles... true, true, I was much younger then.
Jim
  #25 (permalink)
Old 03-07-2007, 04:50 PM
Cobra Make, Engine: LA Exotics, 351C/T-5 trans. Guardsman Blue
The backwards shifter looks so cool in my Cobra that I personally wouldn't consider anything else. My first Cobra, a Classic Roadsters, had a short, straight up shifter and it worked great, BUT the original backwards shifter look and feel is the "cat's whiskers" in my humble opinion.
  #26 (permalink)
Old 03-07-2007, 05:22 PM
JBo JBo is offline
Cobra Make, Engine: Ex CSX3327, & AK7113 AutoKraft AC MK IV
Default shifter
The original 427 street and s/c backwards shifters were a joy to use. first to second was a natual pull up and slightly back, second to third was a push down and right and third to forth was another up and back. All very natural and positive, muuch last chance of a missed shift; although I did miss a few. down shifting was the same positive action. I thought nthey were Fairlane and galaxie units, not Mustang...could be wrong...thought the backwards part was the extreme rear locus of trans in car itself., as this is/was amid engined car.
  #27 (permalink)
Old 03-07-2007, 05:30 PM
Cobra Make, Engine: B&B 302 GT40, T5 5sp, 9"rear end
OK so where can I get a backward shifter for a T5?
  #28 (permalink)
Old 03-07-2007, 06:44 PM
Dwight's Avatar
Smile shifter
Mike Lane had me to heat and bend a shifter. Then he had it rechromed. I think it was a FFR shifter. He loves it. He had it behind three motors, three trannies, & two Cobras.
Dwight
  #29 (permalink)
Old 03-07-2007, 07:41 PM
Hmmm... Now that you mention it, I recall reading Fairlane in one text. I may do some digging when I get bored. I could be wrong as well. I am certain of the Galaxie one though...
  #30 (permalink)
Old 03-09-2007, 08:45 AM
Cobra Make, Engine: FFR 3881 427 FE w/2x4bbls and 4 spd toploader
I'm using a Hurst competition plus shifter and a (reversed) short flat lever on my 4 speed top loader. I would like to get a reverse shift lever as used on the originals (I know, it will have a non functioning reverse lock out when bolted to the Hurst shifter). The replica Ford/Cobra shifters I've seen on line all seem to be for five speed transmissions or for an original Ford top loader shift mechanisms (the original Ford shifters bolted on rather than through the shift lever mount as used with the Hurst). Is there one out there that fits the Hurst top loader competition plus shift mechanism or will I have to modify one of the 5 speed copies?
RB
  #31 (permalink)
Old 03-09-2007, 09:29 AM
Rick Parker's Avatar
The OEM reverse lockout feature requires the use of Ford OEM shifter mechanism under the rubber boot. The mechanism has a "Foot" with a lockout tooth to prevent the lever from being put into reverse without the "T" being lifted. The sliding "T" was connected to a braided steel cable inside the lshift lever. In an OEM 427 Cobra application the lever was reversed 180 degrees in the "Foot", with the knob poining off center to the left centerline of the transmission tunnel. This placed the knob in a very comfortable position relative to the steering wheel. This was done because the transmission being used had the shifter mechanism located on the extreme end of the transmission tailshaft housing. From what I remember (?) it was very similar to what was used in a 1963 Galaxie but reversed. The bend angle was unique, the Mustang unit has more of an arc than a sharp bend, it was made from the same materials but dimensions were changed for the Mustang because of the placement of the shifter mechanism on the long tailshaft housing of the transmission and engine placement in the Mustang. For those of you that are so inclined, the lever is made of 9/16 mild steel tubing with a .250 wall thickness, it would not be too difficult to fab one up, cut some threads, machine a slot and even fabricate a "T" handle. Whether you make it functional or not depends on what shifter mechanism or transmission you actually use.
Rick
  #32 (permalink)
Old 03-09-2007, 10:24 AM
FWIW, ERA replicates the original lever from scratch (with some OEM pieces), complete with reverse lockout.
  #33 (permalink)
Old 03-09-2007, 08:05 PM
Looks like I'll be modifying one of the five speed 'replica' shifters (flat shift plate mount) from Cobra Accessories. Thanks for the tech Rick, my '68 428 CJ Mustang had exactly what you described for the reverse lock out. Snapped my stick right off at the base on a spirited trip down the quarter mile up in Wingdale, NY ("Dirty Dover") a few thousand years ago!
RB
  #34 (permalink)
Old 03-09-2007, 08:09 PM
I would sure consider 'original specs' as much as possible within a reasonable budget. I would also be VERY tempted to go with a 5 speed (.8 OD ONLY, no way .6)! BUT, that five speed MUST HAVE a correct in appearance shifter.
  #35 (permalink)
Old 03-18-2007, 09:27 PM
snakebitekit's Avatar
Cobra Make, Engine: ERA FIA #2119
Default shifter
From what I remember from my Mustang 67 GT, 390CI this is the shifter reversed. The Mustang had no console nor the "high" buckekts of the larger ford. Without seeing side by side it would be difficult, but I have a dollar to a donut.
I ordered the FIA and would prefer the forward shifter for exactly the reason brought up. Who knows I may switch after the build but then someone might shoot me.
Also, from all the literature I have read and reread, ERA offers the shifter lock out look but it is not functional. Please correct me if I am wrong as I would love to have it, if not only for memories.
Display Modes
