Like Tree2Likes
Old 03-14-2016, 12:51 PM
cycleguy55's Avatar
Not an ERA car, but I used off the shelf braided lines with AN fittings and an adapter to mate with the 3/8" x 24 TPI fittings on the car. The adapters have the groove to take the clips that mount them to brackets on the frame. Here's a link to the Earl's adapters at Summit, but all the major fitting manufacturers make them: Earl's Performance Brake Adapters 989543ERL - Free Shipping on Orders Over $99 at Summit Racing
The same thing by Russell: http://www.summitracing.com/int/part...1291/overview/
Brian
Old 03-14-2016, 03:54 PM
Originally Posted by cycleguy55 View Post
Not an ERA car, but I used off the shelf braided lines with AN fittings and an adapter to mate ...]
Here's what you would be seeing if you had the ERA manual (don't tell Bob I showed it to you):
66gtk likes this.
Old 03-14-2016, 04:43 PM
Thanks! I couldn't get the fitting loose, even with 2 different flare nut wrenches I tried. Looks like I have to crush it and get it off with a vice grip?!?!? If I do that, I'll have to replace the hard line down the whole side of the car. This is unfortunate. 20 year old car with hardly any miles - I guess this is what can happen when cars sit too long.
Old 03-14-2016, 04:48 PM
Heat it up with a torch with a welding blanket behind it and use the flare wrench again. Be careful around flammables, of course.
Old 03-14-2016, 05:37 PM
DanEC's Avatar
Troy - here is what I've done with frozen brake and fuel line fittings when a brake line wrench appears to be slipping. Provided there is room, I get a set of vice grips and clamp over the top of the brake line wrench to clamp it tighter and prevent spreading. I've not had it fail on me yet that I can remember and I'm currently in the process of replacing all the original brake lines on my 49 year old 67 GTX right now. A shot of PB Blaster got most of them loose. The vice grips worked on a couple stubborn ones. I just have the two lines at the MC left.
ERA 782 Running
Old 03-14-2016, 07:06 PM
Interesting idea. I did PB blast it a few hours before trying. Put some more on there and will try again tomorrow or the next day.
Old 03-15-2016, 05:05 AM
DanEC's Avatar
Forgot to mention that I have a couple sets of the smaller vice grips (about 4 to 5 inches long) that work pretty well for the smaller fittings. They are a lot easier to position in tight spaces than a full size set of vice grips. I've pretty much decided that line wrenches have been vastly over-promoted over the years. They work just slightly better than a regular box end wrench IMO.
ERA 782 Running
Old 03-14-2016, 07:05 PM
like the gas tank, fuel hose, and filter right next to the brake line?
Old 03-14-2016, 07:12 PM
Uhhh, yeah. You can also use a heat gun, instead of a torch, if that feels a little safer. If you can get the connection nice and hot, without blowing yourself up, it will come apart rather easily.
