Old 09-20-2009, 07:44 AM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Uhhh, you know that the average high temp in February in Tampa is 72 degrees?
That may be, but the average low is 51 deg with a record low of 18 deg in December. Anything below about 60 degrees and my gf wants her seat heaters on. What can I say, she's a girl and she's cold-blooded.
Old 09-20-2009, 08:00 AM
As far as cockpit heat goes , I didn`t see it on your list , but definitely get the ERA heat shields between the primaries and the foot box . I live in SC and summer here is upper 90`s to low 100`s ..... and the foot boxes definitely get hot , even with the shields . I also insulated the vent hoses under the hood where they pass over the primaries . One thing I found out the hard way ... the vent controls work backwards . If you pull them out , it shuts off the air and all the way in opens them . Bob P. said it was done that way since everyone seems to leave them open all the time and the dash looks better with the controls pushed in .
You`ll be hot anyway .... after all it`s a convertible and you live in FL !
I went with a 3.54 rear and the TKO with the .82 fifth gear . I understand what you mean about speeds in FL as that used to be part of my territory ... and if you don`t run 80 + , you get run over . However , your cam selection will have an effect on where your cruising rpm needs to be and where your engine ( and you ) are happy I would think that 2000 rpm might be out of your powerband if you needed a sudden burst of speed . 2600 rpm works well for me at 70 .... after all , my 427 Galaxie runs 3200 rpm at 70 mph !! Analyze your driving habits well before making that choice . How much will actually be in areas where you will do 80 + ?
Old 09-20-2009, 08:11 AM
Once I heard his wife was really pushing for it I immediatly reversed course and recommended he get it.
Old 09-20-2009, 08:24 AM
Mooch's Avatar
Cobra Make, Engine: ERA 427 - #783
I ran a quick spreadsheet of MPH vs RPM for the different TKO-600 setups, with the rear ratio in the top left corner and the gear ratios down the left. What do you think of the 3.31 rear with the 0.82OD? My motor should be in the high 500s for hp at the crank, with torque to match. I'll have to figure out my cruising RPM in the next few days.
EDIT - By the way, this is calculated with 26.5 inch diameter tires.
Old 09-20-2009, 09:55 AM
xracerbob's Avatar
Congrats on your new ERA. I was faced with all the same questions and came up with some alternative solutions-
On the rear gear and trans- I went with the 3:54 and a G-Force T-5 with the optional .75 fifth gear. This seems to work really well. I rarely use fifth anyway, but its nice to know you have it when just cruising. I also have a Pond 482.
Sound deadening- I put Dynamat on all the surfaces in the cockpit that get carpeted. My footboxes get warm, but not hot like I have heard so many other people speak of.
Ceramic coating of the pipes- I spent a lot of time checking into this and there is one that is really different- Swain Technologies. http://www.swaintech.com/store.asp?pid=10296 Too lengthy to explain here, but one of the best things I did. I did the sidepipes as well. They do not get nearly as hot as many others I have checked. Yes, you can still burn yourself, but it will be 2nd degree instead of 3rd degree.
A couple other suggestions- get the Quicktime bellhousing- does not need to be trimmed like the Lakewood and saves a bunch of weight. Use an aluminum flywheel for faster acceleration and a more responsive motor.
Good luck with the build and have fun!
Old 09-20-2009, 10:25 AM
Alright, it was mid 70's today so I took her for a nice drive and paid particular attention to what you've asked because once you've driven your car for a while you don't notice stuff like this unless you really pay attention. Here is what I believe to be true:
1) With pusher fans, big radiator fan, extra venting & heat shielding, and ceramic coated pipes, in mid 70's weather you don't notice the engine heat at all. Zero heat comes through the firewall or trans area.
2) For pleasant cruising at highway speeds, with your wife, with whom you presumably want to chat with from time to time, anything above 2700rpm is going to be unacceptable because of engine noise (and I have specially crafted "quieter pipes" too).
3) If your car's engine is civilized enough to run without hiccupping at 2000rpm or just over, I would use that as your benchmark for the highway cruising speed that you expect to drive at, and then back in to your gears from there. If you plan on racing your car at speeds over 120 or so, forget about the .64 overdrive altogether.
4) Don't forget that you will also be going slow, so don't make your gear combinatioin too steep in first gear.
EDIT -- BTW, I bet you only need like 50 ft/lbs of torque to cruise at 70mph. It's how your engine runs at that RPM and whether you can lightly accelerate from that speed, at a given rpm, without it burping...
Old 09-20-2009, 10:53 AM
RodKnock's Avatar
I think your goal should be to be around 2,200 RPM at 70mph. I have the 0.82 5th and a 482, but with the Kirkham 3.42 rear end. Cruising on the freeways (65mph speed limit) around that rpm seems optimal for me.
The 3.54's with the 0.82 5th just doesn't look good for freeway cruising.
Old 09-20-2009, 11:24 AM
Hmmm, I was thinking a .8 would work well with my existing 3:31. Sounds like my rpm drop might be to much though. I might reconsider the whole issue...
WHAT? You mean you gotta loose the glove box when installing a heater in an ERA? Well that sucks, I LIKE my glove box. But moving to the mainland I wanted to install a heater. I'll pass on the heated seats, that big 427 keeps me warm enough, with the heater, it should be plenty.
Old 09-20-2009, 11:47 AM
RodKnock's choice is a nice one. BUT, if you are honestly going to casually cruise at 80MPH then you will be turning 2800RPM with this setup. That's pretty loud. If you're going to cruise in the mid to upper 60s, then his setup is very nice. The absolutely number one rule when spec'ing out your Cobra, or talking to your engine builder, is To Thine Own Self Be True.
Old 09-20-2009, 12:16 PM
If I were ordering again, with the TKO 600, I would definitely have gone with the .82 OD and I would have ordered a 3:31 rear rather than the 3:54. I really don't like the .64 with the 3:54 rear. If you are driving a lot in the 60 - 70 mph range, it is a real pain - you want to shift - but that huge drop sucks big time. My old cobra had a T5 with a .75 OD and I had a 3:31 rear - which was a nice combo.
Old 09-20-2009, 12:21 PM
Rick is right on the money with this and he's put his finger on the .64's weakness. But Mooch, don't go with anything just because someone else went with it -- you've got to choose this one all by yourself and gear it to your engine and driving speed. Whatever you do, *don't* go with a 3.54/.64 combination just because I did.
Old 09-20-2009, 12:37 PM
This discussion highlights the fact that you need to talk to your engine builder about how he builds your stroker. By design, if built and cammed right it should be plenty torquey...enough to pull you out of the 2k/70mph hole if you go with 3.50/.64. But as you say, you gotta pick your cruising band and plan your setup from there. Don't listen to me either, I didn't plan diddly squat where this is concerned>>>>During my build I found a brand new still-in-the-box .64 TKO 600 on Craigslist for $1000 and made what my wife commonly characterizes as an "impulse spend."
  #33 (permalink)
Old 09-20-2009, 03:03 PM
Mooch's Avatar
Again, another calculation with TKO-600 gear ratios through the cruising band with 26.5 inch tires. I figure there a lot of people who have been doing this calculation on their own. Hopefully they can just refer to this. I had to put it in a code box for the formatting.
Code:
RPMs         3.54w0.64od      3.31w0.82od     3.54w0.82od
1500              52              44              41
1550              54              45              42
1600              56              46              43
1650              57              48              45
1700              59              49              46
1750              61              51              48
1800              63              52              49
1850              64              54              50
1900              66              55              52
1950              68              57              53
2000              70              58              54
2050              71              60              56
2100              73              61              57
2150              75              62              58
2200              77              64              60
2250              78              65              61
2300              80              67              62
2350              82              68              64
2400              84              70              65
2450              85              71              67
2500              87              73              68
2550              89              74              69
2600              90              75              71
2650              92              77              72
2700              94              78              73
2750              96              80              75
2800              97              81              76
2850              99              83              77
2900             101              84              79
2950             103              86              80
3000             104              87              81
This is the equation:
MPH = (RPM*pi*d)/(12*88*g*od)
Here are the variables:
MPH = MPH
RPM = RPM
pi = 3.14159
d = Tire true diameter (inches)
g = rear end gear ratio
od = final gear reduction for overdrive
Once I talk with my engine builder, hopefully tomorrow, I'll let you know where I'm going with the gearing decision. I think I'm going to have the trunk lid finished, and I am still mulling over the seat heater and interior insulation options.
  #34 (permalink)
Old 09-20-2009, 03:16 PM
Good post Mooch! So, 70 to 75 is around 2400-2600 for a .8 with a 3.31. That's just about perfect for my setup, cam profile, etc. I need to stay just a hair over 2000 to be comfortable, a little more is better. So 60 mph and up would work for me.
When considering MY trans gearing I ALSO want to keep a close eye on 1st gear, not to low. The wide ratio top loader is just about right with the ratio's on the bottom three. I think the T600 mimics those ratio's fairly closely, making it a wise choice.
  #35 (permalink)
Old 09-20-2009, 03:22 PM
Have you given any thought to a solid flat tappet cam?
  #36 (permalink)
Old 09-20-2009, 03:47 PM
BAAAAAAAAAAAAAAAHAHA!
Cool one Pat. The guy<s in a trunk-sound-deadner and seat-heater-or-not quandry and you want him to adjust valves??
He's getting a 482 with juice roller so the noise won't offend his wife. Also nothing north of 5800.
Take your medicine and give the flat tappet song a rest Pat.
Chas.
  #37 (permalink)
Old 09-20-2009, 03:49 PM
Well, my Redskins did manage to stumble in to a win, so maybe I should just quit while I'm ahead and go to bed now.
  #38 (permalink)
Old 09-20-2009, 05:18 PM
Mooch's Avatar
I'm not sure how to take that. You seem to imply that because I'm asking about sound deadening and seat heaters that I can't turn a wrench, almost offendingly so. Thanks for the welcome. If I'm reading too much into this, then I'm sorry, but easy on the newb.
I actually was going to do an original 427 marine conversion with flat tappets, but after examining the block I turned to the aftermarket blocks and it seems that the Pond blocks run better with hydraulic rollers.
  #39 (permalink)
Old 09-20-2009, 05:23 PM
I agree with you Mooch, ERAChas was clearly out of line. You should just ignore him. He can be kind of a jerk from time to time.
  #40 (permalink)
Old 09-20-2009, 05:30 PM
ZOERA-SC7XX's Avatar
Don't know who you spoke with, but I have the heater and the glove box. It was never an issue, as the heater box is centered under the dash.
Tags
firewall, gear ratios, seat heaters, spectrum, tko-600
