  #61 (permalink)
Old 06-14-2010, 06:47 PM
...look again. Mine was 115 lbft.
Ahhh, c'mon Chas... won't you look for me? Pleeaassseee.... 115 ft/lbs seems awful high, but if you can find it on the ARP site then I'll personally bow down and proclaim your torque expertise.
  #62 (permalink)
Old 06-14-2010, 06:50 PM
Just edited that post-look again. Mine was 115 lbft.
CORRECTION: I misspoke. The ARP spec with their lube for a 5/8-18 is 189lbft. (243 with oil!) I think all I could muster was 130 on my back under the car.
I used to watch 4 engine builders torque them with impact guns set on kill.
Chas.
  #63 (permalink)
Old 06-14-2010, 06:53 PM
189 ft/lbs?!? Uhhhh, I'd like a second opinion on that from the gallery please.
  #64 (permalink)
Old 06-14-2010, 07:06 PM
Pat-that's straight off the ARP bolt spec sheet I have taped to my cabinet. If I must, I'll take a snap tomorrow morning for you.
We may joust all the time but I wouldn't lie to ya. As I said, some pros use an impact which is at least 150lbft. 130 has been fine for 12 seasons for me.
Chas.
  #65 (permalink)
Old 06-14-2010, 07:12 PM
I believe you; I just wonder if that's right though for that particular application -- Chevrolets don't have that big of a bolt up there. Maybe Keith, Barry, & Brent will tell me what they do. My torque wrench only goes up to 100 ft/lbs. I bet my arm doesn't go up a whole lot higher than that either.
  #66 (permalink)
Old 06-14-2010, 07:17 PM
Yes I'd like to hear from our pros on here too. You could get your impact with extension over the K-member on it.
Chas.
  #67 (permalink)
Old 06-14-2010, 07:25 PM
dcdoug's Avatar
Another opportunity for you to buy a tool that you will only use a few times.
www.partskeeper.com
  #68 (permalink)
Old 06-14-2010, 08:14 PM
Default ARP torque spec sheet...where is it on their Web page?
I am reinstalling the flywheel (aluminum) and pressure plate on my car.
Just called ARP's tech line this afternoon. Very helpful, discussed the torque values with oil, locktite and moly...
OK, where is the bolt/torque chart on ARP's site? I have not seen it, but I am sure its there.
I have an old general torque chart from a Sears beam-bar torque wrench package. Of course it doesn't touch on effect of different lubes on the threads and torque required.
Always like to find good references on torques, techniques to apply it accurately
Would be good to see a thread on proper tightening to achieve correct torque and the bolt stretching that is necessary to get it.
ERA 289 #2027
  #69 (permalink)
Old 06-14-2010, 11:16 PM
Rick Parker's Avatar
Right Here:
http://www.arp-bolts.com/Catalog/Catalog.html Page 24
The fastener itself may be capable of that torque value however that might be overkill for the intended application, I would follow the torque spec provided by the damper Mfgr or else use OEM specified torque. Don't break the snout or you'll REALLY be pissed! 189 Ft lbs seems like way too much to secure the damper.
  #70 (permalink)
Old 06-15-2010, 01:48 AM
I wouldn't torque to 189 lb-ft....
IMO, OEM factory spec or a little higher is fine with Loctite. I'd torque her at about 100. If you want to pull a little harder on it, it's not going to hurt anything.
  #71 (permalink)
Old 06-15-2010, 03:10 AM
Default Using an ARP crank shaft bolt
I torque mine to 75 pounds and use a drop of red locktite. No failures or the bolt coming loose yet was tight for 8 years before rebuild. I have seen the spec from 70-90 ft pounds I would not take the bolt pass 120 pounds for fear of stripping the threads inside the crank or pulling them. You need to be sure that the dampener is seated to the bottom of the snout of the crank. As long as the dampener is tight on the snout and the pulleys are spinning true, see no reason for 100+ torque reading, but that is just me. Rick L.
  #72 (permalink)
Old 06-15-2010, 04:58 AM
Cobra Make, Engine: keith craft 427, tko600, very shiney pile of parts
as long as damper is seated well, snug on it's key 100ft/lb is max i'd go to...loctight for forever reassurance!
  #73 (permalink)
Old 06-15-2010, 06:23 AM
dcdoug's Avatar
You're not concerned about over-torquing with an impact wrench?
www.partskeeper.com
  #74 (permalink)
Old 06-15-2010, 06:53 AM
Again, I watched it happen everyday. These were IR or Snap On guns-all were set well over 100. No warranty returns due to crank nose or damper bolt failures.
As stated I set my own by hand at 130, 12 years ago. We all have our own preferences based on experience-I do not claim mine is the only way.
Chas.
  #75 (permalink)
Old 06-15-2010, 07:16 AM
Originally Posted by Rick Parker View Post
Right Here:
Thank you Rick-I thought I'd have to show St Patrick the holes in my hands...
More amazing is that the same fastener without ARP lube takes 243!
IIRC the castle nut on the Jag rear requires 180 lbft. I quit at 150.
Chas.
  #76 (permalink)
Old 06-15-2010, 07:38 AM
Default A Summary of My Findings...
I received a surprisingly good bit of feedback via email, PMs, etc. so here is a summary of my findings:
The ARP Torque Table: The figures that are found in the ARP table are general guidelines only and different applications (rod bolts versus something else, for instance) require a different interpretation of the table in light of the functional relationship that the fastener has with its surroundings. As an example, if the OEM fastener was originally "oversized," the torque values found in the ARP table may be inappropriate, as they obviously do not take in to account the object that is being fastened or the type of stress that may be involved. Further, ARP recommends that if you are adhering to the values in their chart that you reduce the torque value down to 75%. Thus, if we blindly follow the ARP chart for an ARP Ford Crank Bolt 5/8-18 it would be 142 ft/lbs. with moly.
The Original Ford Specs: I have an original 1967 Shop Manual, so I looked it up with my own two eyes. The torque specs for an original Ford OEM bolt (which hasn't been made in years) are 70-90 ft/lbs. with no mention of anything on the threads, by the way, in the shop manual R&R procedure, just "lubricate the inside diameter of the hub and line up the key...."
What People Tell Me They Actually Do: 1) The majority of mechanics put nothing on the bolt (meaning no oil, no moly, no thread locker, nothing at all). Rick and one other person use red loctite; a few use blue). The vast majority of mechanics are torquing in at or under 90 ft/lbs regardless of the manufacturer of the bolt. As an interesting side note, the older the mechanic, the lower the torque setting seems to be. 50 and 60 ft/lbs. were not uncommon numbers that were sent to me by some of the really old FE mechanics.
Does it Really Back Out? -- No one reported a crank bolt loosening or backing out on an FE even when torqued to a relatively "low figure."
So What Am I Going to Do? -- I'm going to torque it to 90 ft/lbs with blue loctite. And at the suggestion of one respondent, I'll paint a little white line on the bolt that easily shows any backing out that may occur.
  #77 (permalink)
Old 06-15-2010, 09:53 AM
I knew that college education would pay off some day. Should I worry?-I'm at 69.2%
Chas.
  #78 (permalink)
Old 06-15-2010, 09:56 AM
I think you're perfect just the way you are.
  #79 (permalink)
Old 06-15-2010, 10:27 AM
Bernica's Avatar
Senior CC Premier Member
Originally Posted by Snakebit View Post
I second the Romac balancer.
I'll also agree on the Romac steel balancer. Mine is 7-1/2". It's very well made, and it does only have the one timing mark. Just used a piston stop to verify the mark, then re-checked with a dial-back timing light, then for good measure I put on the MSD timing tape so I can use my self-powered timing light anytime with little hassle....
  #80 (permalink)
Old 06-15-2010, 10:37 AM
I'll also agree on the Romac ... and it does only have the one timing mark.
As of this morning mine's on a UPS truck just leaving Little Rock. As soon as I get it I'll post some shots.
