November 2025
| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
5Likes
01-01-2015, 07:57 PM
Cobra Make, Engine: Scratch Built with 482 FE
482 Side Oiler Build
This one is starting with a long block built by Jean Batteaux. OEM Ford 427 block bored to 4.25, diamond pistons, scat crank, scat h beam rods, NOS sidewinder intake, NOS dual point, and Edelbrock heads.
Advertising
01-01-2015, 07:59 PM
New years day project was to install the water pump. First had to thread NOS sidewinder intake for water bypass nipple.
Done:
Pump installed:
Prep water pump pulley for paint:
Waiting for paint to dry:
01-02-2015, 08:13 AM
ca
It's too bad you don't have a car to put it in,,,,,
01-04-2015, 01:56 AM
Minor progress. Pulley attached and key learning was edelbrock pump uses 5/16 fine thread bolts.
01-04-2015, 05:15 PM
Remote oil filter install with bracket and adapter from Finishline. Nice parts! Had to ream the bracket holes and put a notch on the pump to get it to fit together nicely:
01-04-2015, 07:09 PM
Doh cant find the 7/16 5.5 inch bolt for the alternator locally so will have to order...
01-04-2015, 07:19 PM
ca
I have a couple of them,,,,
01-04-2015, 08:07 PM
Done for the weekend, need to put alternator brackets on before water pump pulley:
01-09-2015, 11:20 PM
Brackets on, ignition will probably be next
SB
01-10-2015, 02:20 AM
Vic
Cool build.
Tell me you're going to dyno this beast when you're done! Please
I'm curious to know the cam specs and if the heads have been ported.
Also Id love a pic of the intake of you have it handy.
01-10-2015, 09:39 PM
Here's the intake, it was a find being NOS:
01-11-2015, 02:19 PM
Precison oil products billet remote adapter installed:
02-14-2015, 03:56 PM
coil location?
Not sure where the coil goes, ive seen some on intake, others bolted to head?
07-24-2016, 01:56 PM
Robbmc starter is really nice. Checked pinion clearance and all is good.
07-24-2016, 02:19 PM
Senior CC Premier Member
CA
Can you mount the coil on the inner fender instead of on the engine? Just a thought...
Nice build!
07-24-2016, 03:13 PM
Hi Bernica,
I was going somewhat for an original type look w the yellow top n thought the coils were mounted on the head. Fender is probably a cooler option
SB
07-24-2016, 03:34 PM
va
Cobra Make, Engine: Coombe, Shelby Block 496
I would have to agree with you, great starter.
Things are looking nice there with the engine build
07-24-2016, 05:16 PM
OH
Mount on intake, then you can use the canister fuel filter and bracket, attached to the head, for original looking aspect.
Hi Bernica,
SB
07-25-2016, 06:14 AM
Cobra Make, Engine: Hi-Tech
If you mount the coil on the intake, you should consider using an epoxy filled coil versus an oil filled coil. The epoxy can take the vibration better and oil filled coils don't do as well when they are mounted horizontally.
07-25-2016, 07:24 AM
AL
HTML Code:
Mongoose930
An oil fill coil has an air bubble in them. Laying them on their side exposes the wire coil and "could" cause them the burn up. I would say 70% or better burn up if laid on their side. I think the size of the air bubble is the problem.
Dwight
