Like Tree6Likes
Old 06-09-2016, 08:04 AM
FUNFER2's Avatar
Default Thoughts on this Side Oiler for sale ?
What do you think of this 427 Side Oiler for sale, and price ?
A video link is below.
427 FORD FE Side Oiler Rebuilt Medium Riser Tunnel Wedge
427 FORD FE Side Oiler Rebuilt Medium Riser Tunnel Wedge - $9995 (Marysville) hide this posting
condition: like new
make / manufacturer: Ford Mercury FoMoCo
model name / number: Sideoiler
FORD 427 FE Side Oiler Cross Bolted Medium Riser with Tunnel Wedge and Matching C5AF-BC-BD Holley's. Complete High End Rebuild with Only the Best New Parts. The Specs are Below:
1970 427 FE Hydraulic Block. These Late Blocks are the Strongest FORD made and also were Hydraulic Blocks for better Lifter Oiling. This Block has No Repairs, Cracks or Sleeves
The Block is Bored .030 over and was Honed with Torque Plates.
Venolia .030 Dome Pistons
C5AE-C Std./Std. Forged Steel Crankshaft. Crank has Screw in Plugs
C5AE-C LeMans Rods with New ARP Bolts
C5AE-6090-F Medium Riser Heads with New Stainless Valves. Date Codes of 0A19 & 0B6
Lunati Billet Mechanical Roller Camshaft, Lift .588 int. & .593 exh. Dur. @ 50 256 int. & 266 exh.
Matching Lunati Solid Roller Lifters
HD Harland Sharp Roller Rockers with Solid Rocker Shafts
Vintage Accel Dual Point Distributor with Tach Drive
C8AX-9424-A Aluminum Tunnel Wedge FoMoCo Intake & Linkage
Matching C5AF-9510-BC & BD Holley Carbs Dated 853 and 853
Cobra LeMans Pent Roof Aluminum Valve Covers
TRW HV Oil Pump
Ford Motorsport Windage Tray
Steel Flywheel
Complete Rotating Assembly is Balanced.
This Engine was Running on a Engine Break in Stand for about an hour to break it in and do some tuning. Come hear it run. Here is a link to the YouTube video: [ame]https://www.youtube.com/watch?v=xEX_wW9ygrA[/ame] or just paste this into the YouTube site: v=xEX_wW9ygrA
Sound and Runs AWESOME
PRICE $9,995.00 CASH
http://images.craigslist.org/00101_7...Z5_600x450.jpg
Kevin
Kevin
Old 06-09-2016, 03:04 PM
Shootnride's Avatar
Cobra Make, Engine: Superformance, 427SO
If it's everything it's claimed to be, I would say it is a very good buy.
Ted
Old 06-09-2016, 03:41 PM
FUNFER2's Avatar
The problem is, I trusted a internet website FE engine builder and I get kicked in the nuts. But, I can not and will not, say that everyone on the net, on ebay and various forums should not be trusted.
My builder was respected as a builder and was known on a few forums that he advertised on. He also took my newer hard drive camcorder, tripod and bag.
He said my aluminum side oiler block (and other peoples blocks)and parts were stolen, but he went through a divorce and had other money problems, but I believe he sold all he could get.
I need to sell some Sprint Car racing parts and another toy I have to add to this engine build. We don't have the money we used to because of my bad health issue, Hospital bills and medications.
I just can't put a low cost, mediocre, purring little kitten motor in the Cobra.
The engine builder stole my "spirit for life" for 6 years, but I'm now ready to get back with building a motor for my Cobra, and back to a happy life !
Kevin
Old 06-09-2016, 04:26 PM
CHANMADD's Avatar
That looks like a good price for a running motor, in comparison to everything else out there. You could always take it apart and make sure of things .....
Old 06-09-2016, 04:43 PM
Sorry you went through all of that. I tried to warn you the best I could without committing slander...
FWIW, he was never respected as a builder.
Old 06-09-2016, 05:26 PM
FUNFER2's Avatar
That's what I thought, as I do not know if the intake and carbs will fit under the hood, so I could sell all three if needed.
With my first FE, I had the Edelbrock Performer intake, then it broke a rocker shaft bending the pushrod inside, so with the FE, I had to tear it down. I did some other mods and bought the Air Gap RPM intake and it hit the hood, so I milled it down 3/8". It did not hurt the performance that could be felt.
Kevin
Old 06-09-2016, 05:28 PM
FUNFER2's Avatar
Hello Brent, thank you.
Kevin
Old 06-09-2016, 05:59 PM
It isn't libel or slander if it's true!
Old 06-09-2016, 06:30 PM
Bernica's Avatar
Senior CC Premier Member
Something don't smell right here, but maybe I'm wrong and a great deal. Just ask Blykins what it really takes to build a true 427 old school engine.
Old 06-09-2016, 07:27 PM
FUNFER2's Avatar
I agree, he's one of the best.
Kevin
Old 06-09-2016, 07:32 PM
FUNFER2's Avatar
Being a solid roller, I'd like to see the cam a bit larger, even for the street, but without real high spring psi.
Kevin
Old 06-10-2016, 04:20 AM
I certainly wouldn't be able to recreate that build for $10k. When blocks are going for $4-5k just by themselves, I would expect this to be a collection of parts that have been sitting on the shelf....including the Venolia pistons which are very "old-school".....
I am pretty leery of factory 427 rotating parts because they have probably been abused for 40-45 years. I would not reuse factory rods and I'm really not a big fan of the factory $ crank unless they are specifically asked for by the customer.
The cam isn't small at all. It would be pretty aggressive with a 427. I wouldn't go any bigger and would probably favor something a little smaller in duration. You don't want to pair a street car with street gears with a cam that won't play nicely.
I echo the thoughts of some of the others.....it may be a decent deal, but I would absolutely take it apart and go completely through it, changing a few parts for the sake of strength/longevity.
Old 06-10-2016, 05:02 AM
undy's Avatar
Not a side-oiler Kevin. The guy says medium oiler and side-oiler too. They can't be both... Be careful that you're not heading down the same path with this guy.
Too many toys?? never!
Old 06-10-2016, 05:28 AM
FUNFER2's Avatar
What is a medium oiler ?
I'll have him shoot a photo of the oiler side to see if it's a true S/O.
Can't really want to afford a new block but, if that's what it's going to take, I guess that's what I'll do. hum.....
I don't know what to think now ?
Kevin
Old 06-10-2016, 05:37 AM
undy's Avatar
Sorry, mis-read his ad... He say's a it's a side oiler with Medium riser heads, not medium/top oiler. My bad and poor reading skills. DUH.
Old 06-10-2016, 05:45 AM
FUNFER2's Avatar
I understand what a side and center oiler is, guess I don't recall it also being named medium, other than medium riser.
Yeah, I know, it just means saving up more money, I want a solid motor. I'm hoping to find a great condition built side oiler from a honest man or one that needs assembled, so it's lower in cost.
FE's are incredibly,....... high in cost !!!
Kevin
Old 06-10-2016, 05:47 AM
FUNFER2's Avatar
Love ya buddy but,....YOU'RE SO DAMED OLD ! lol
I'm turning 54 on the 25th.
Hey, how about a S/O for my Birthday !
Kevin
Old 06-10-2016, 05:49 AM
DanEC's Avatar
It's .030 over and he says no cracks. I think I would ask how they know it could safely handle that overbore and that there are no cracks and see if his response includes the words "sonic" and "magnafluxing" in it.
But, if it is what he says it is - no way to build a motor close to that for the money.
Those carbs are probably worth a lot.
ERA 782 Running
Old 06-10-2016, 05:54 AM
FUNFER2's Avatar
I though that the S/O's were safe going.030 ?
But, last night I did more research and a few people were saying it's too much.
I did with my 428 and had no issues.
Kevin
Old 06-10-2016, 05:56 AM
FUNFER2's Avatar
Dave, I'll call you, unless being so old, that you're still in bed !
Kevin
