Like Tree1Likes
  • 1 Post By steve meltzer
Old 02-26-2018, 05:50 PM
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Default Carb and Turkey Pan gasket
Does the gasket go between the intake manifold and the t-pan or between the turkey pan and the carb? Or, as has been suggested, you should use two gaskets. thanx steve
GLS-BDR226 likes this.
steve meltzer
"I may be wrong, but I'm never in doubt"
Old 02-26-2018, 05:58 PM
Two gaskets, please.
Old 02-26-2018, 06:07 PM
Oh, Patrick, what would I do without you? s
steve meltzer
Old 02-26-2018, 07:41 PM
OK, i have both a thick cardboard gasket, a thin more paper-like example and but none of the metal impregnated ones. Are both gaskets the same material or? thanx. s
steve meltzer
Old 02-27-2018, 02:53 AM
Gaz64's Avatar
The less gasket thickness you use, the less likely to warp or break your throttle body.
For your setup, a thin one on the bottom and a thick one on top, if you need it for clearance within the turkey pan,
and ONLY if it has compression limiting spacers at the mounting points. Otherwise, two thin gaskets.
Old 02-27-2018, 06:30 AM
I use the same standard Holley gasket that comes in the rebuild kit both above and below the Turkey Pan. BUT, I use a "pointer type" inch/lb torque wrench on every bolt when working on a Holley. It is very easy to warp and crack them by giving them just a hair too much tightening.
Old 02-27-2018, 08:26 AM
Patrick, I have a gob of gaskets in a bag and don't recall which ones came from where. At any rate is the stock gasket more like paper or more like cardboard? Also, what is the torque setting in inch-pounds for the hold down nuts? I pretty careful about those nuts, but a real number would be (at least in theory) better. thanx. s
steve meltzer
Old 02-27-2018, 09:48 AM
The gasket is the thickness of the typical cardboard coasters you put under a drink. Here's a hi-resolution pic:
And here are the torque settings that I use for my Holley ventures.
Holley Carburetor Fastener Application Torque Range (Minimum—Maximum) Inch-Pounds
Bowl Screws 25-30
Throttle Body Plate to Main Body Screws 25-30
Main Jets 30-40
Adjustable Needle-and-Seat Lock Screws 50-60
Carburetor to Manifold Attaching Screws 60-80
Internally Adjustable Needles-and-Seat 60-80
Power Valves 40-50
Fuel Bowl Inlet Fitting 175-200
1/16--Inch Pipe Plug 50-60
1/8--Inch Pipe Plug 100-150
1/4--Inch Pipe Plug 160-240
Old 02-27-2018, 09:51 AM
Great! and thanx. Is the hole in the middle of the gasket from setting down too many martini glasses on the coaster? s
steve meltzer
Old 02-28-2018, 04:03 AM
Gaz64's Avatar
As Patrick has shown, here is the torque list from Holley:
http://documents.holley.com/techlibrary_torque.pdf
I don't agree with some things, like a needle seat lock screw tighter than a power valve as example.
Somethings, I prefer the "short spanner feel".
Old 02-28-2018, 05:38 AM
EXCELLENT! THANX. s
steve meltzer
Old 02-28-2018, 05:41 AM
Uhhhh, when was the last time that car went for a nice, uneventful drive?
Old 02-28-2018, 09:26 AM
i'm not answering that....been awhile, partly because of other auto projects. argghhh. s
steve meltzer
