21Likes
03-26-2023, 03:15 PM
Well that is just lovely. What are the build specs and parts that Blair chose?
03-27-2023, 06:56 PM
+1^ what Tom said.
What your dyno chart does not show is the run-up to 4800 rpm. I suspect the TQ curve down there will be quite impressive also. High torque at low engine speeds provides an exceptional driving experience. Like Tom suggested, it will be quite exciting in the lower gears.
Reason: Spelling & Grammar
03-28-2023, 06:05 PM
Tx
Cobra Make, Engine: ERA 427 S/C #844 Ford FE 482 cu/in
Ford FE speciification for 482 cu in 10.5:1 Compression 4.125" x 4.125" bore x stroke producing 582 HP @ 6000 RPM W/ 593 ft/lbs Tq @ 4680 RPM
BBM 427 Side Oiler Block
Edelbrock Heads - CNC by Blair Patrick
SCAT 4340 Forged Crank
Molnar 6.7" H Beam Rods
Mahle PowerPak Pistons
Bluethunder Medium Riser Manifold
Custom Solid Roller Camshaft 238/242 114 by Blair Patrick
Crower Enduramax Solid Roller Lifters
T&D Custom Rocker Assembly - Blair Patrick
Aviaid Oil Pan & Dip Stick
Duramax Ignition
Custom Holley 4150 850 Carburetor
03-28-2023, 06:11 PM
Tx
Here is the image of the engine installed
03-28-2023, 06:21 PM
That's good stuff. If Blair dyno tuned your engine I doubt he put a Turkey Pan and small filter on it before he adjusted the Holley. So, the customizing that he did might not match to your setup as you have it installed in your ERA. Not a big deal by any means, just something to tuck in the back of your mind. That's half the fun.
03-28-2023, 06:29 PM
Tx
Very true. The price we pay for some originality
03-30-2023, 10:12 AM
Duramax Ignition
Your displacement is actually 445" if your specs you listed are correct. My KC built, Pond block side-oiler is a true 482" and it's 4.25" x 4.25".
Too many toys?? never!
03-30-2023, 11:11 AM
I bet that was a typo on his part. I actually do have the 4.125" stroker crank in my block, along with a 4.155" bore. Of course that opens up the debate as to whether a 4.125" crank revs faster than a 4.250" crank, all things being equal. Personally, I have always believed that the shorter stroke results in a shockingly improved rev factor.
03-30-2023, 05:26 PM
I always thought that too Patrick, until my 4.25” stroke 428 that Keith Craft built. Not sure if it was their balancing work or just the light weight of the car, but it revs crazy fast and very smooth, very much like the Ford 3V modular motors (which are also under square).
03-31-2023, 04:44 AM
KY
The stroke length number itself has zero, zilch, nada to do with how an engine accelerates. The weight of the rotating assembly, the camshaft, compression ratio, and a few other variables have everything to do with how an engine accelerates.
04-07-2023, 06:10 AM
Hi Folks,
After one year on the ERA wait list Peter has just started on my 427 chassis No 844. I am now Shopping for an engine, but the supply chain issues are creating a back log such that many of the usual engine builders have declined or been non responsive. Does anybody have experience of Prestige Motorsports for an FE turnkey build?
I’m way late to this thread. Congrats on a great motor from a great builder.
04-14-2023, 02:03 PM
Tx
Apologies, and yes a typo, it should be 4.25. Well spotted!
