  #21 (permalink)
Old 05-02-2002, 09:31 AM
Chaplin's Avatar
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Geary/Rick
Thanks for the info. Another question: I have been considering the 406 that Southern Automotive sells and have spoken to Bill Parham- truly a great guy. Does anyone have the Southern Automotive 406 ? If so, I was wondering if you could share your insight on power, streetabiliity and idle characteristics.
Thanks.
Mike
Replica is not a dirty word.
  #22 (permalink)
Old 05-02-2002, 10:09 AM
Cobra Make, Engine: Unique 427SC-Junkyard 390 with a few aluminum parts-toploader
When I first started looking for an F E, I had a hard time finding a suitable 428 to rebuild. I did run across a 390 standard bore engine and ended up using that block, crank, rods, flyheel and balancer.
The money that I saved by not springing for a 428 was used to buy upgrades. The engine is finished and mounted in the frame and has had the cam run in---- about 45 minutes fun time so far and it sounds like a monster.
I used the Edelbrock aluminum RPM heads and intake and water pump. Holley 750 vacuum advance, Crane custom grind solid 238/248@ 110 LC cam and the Dove/Comp Cam roller rocker set up with Crane lightweight "shell" lifters.
The engine sounds pretty tuff. I have no problem with the bragging rights issue. This motor looks right, sounds right and will make plenty of power .
  #23 (permalink)
Old 05-02-2002, 10:29 AM
Cobra Make, Engine: Unique 427SC, Southern Automotive "Super FE" - 452ci FE390 Monster!
Send a message via Yahoo to patrija
Mike
I have one of SA's 406 engines and it is great! They've made it visually indistinguishable from a 427, has all of the benefits of a big block (sound, torque, etc.), and is obviously a cheaper route to go. I consider it the perfect replica engine for a replica cobra!
Jason
  #24 (permalink)
Old 05-02-2002, 07:05 PM
Cobra Make, Engine: ERA / nascar side oiler
Pete c .
Be sure you find the post that talked about the differences , some have better brass bushings or something , one of our guys here went with the shelby set up , but the holes in his heads (edelbrock aluminum ) need to bo drilled out from 3/8 to 7 / 16 or somthing to allow for the different angle of the push rods . But Go for it . Solid lift does not give .
