| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
05-03-2007, 08:07 AM
What Is The Correct Name for This Part?
It's the thing that screws on to the push rod coming out of the slave cylinder and that pushes against your clutch fork coming out of the bellhousing. Picture with helpful arrows below.
Advertising
05-03-2007, 08:12 AM
Member of the north
Cobra Make, Engine: A Cobra
I call it the clutch activation rod. I made four for my car as I changed other things.
Just my $0.02
05-03-2007, 08:36 AM
How about adjustable clutch rod.
05-03-2007, 10:14 AM
CA
Cobra Make, Engine: BDR 187 Prism Red w/Silver stripes; 427 stroker by Smeding Performance, Tremec TKO600 gearbox
It's either a thingamajig or a whatsit--I can't remember which.
'round Midnight
You'll feel me coming
A new vibration
From afar you'll see me
I'm a sensation!
-Pete Townshend, Tommy
05-03-2007, 10:29 AM
Uh-huh
I know it's got a name; and I know I've heard it before, I just can't remember it. At this point I'll even settle for a link to an item on a manufacturer's site that even looks close to it.
05-03-2007, 11:15 AM
CT
I call it a clutch slave cylinder pushrod.
It looks like it's too tight on the fork so it might be a good idea to space the slave cylinder bracket forward on the block rather than changing the pushrod.
05-03-2007, 11:21 AM
That's ok, it's not mine -- I ripped that photo from page 35 of the ERA manual.
05-03-2007, 11:26 AM
FL
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
I think it is like the little plastic things on the end of shoe laces, it does not have a name.
Or does someone know what those little plastic things are called?
05-03-2007, 11:28 AM
Hmm, maybe it's called a "clutch slave aglet."
05-03-2007, 01:11 PM
AL
Patrick -
I think you are referring to the collar that goes over the "slave cylinder rod." It looks like it can be screwed in or out to adjust the distance between the slave cylinder and the fork. According to this web site, it's called the "adjuster." See the blow up drawing about a third of the way down the page.
Click here.
Tommy
Previously owned EM Cobra
05-03-2007, 01:22 PM
Il
Cobra Make, Engine: LA Exotic
The shoe string "thing" is called a niblet
05-03-2007, 01:25 PM
Originally Posted by Tommy
Patrick -
Click here.
"Collar" is better than "aglet," which is better than "adjuster." Niblet is the worst of all....
05-03-2007, 02:09 PM
NC
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
My wife calls it a thingy and I call it a pushrod. There's a logical reason to use this term . . . it's a rod that's pushed on, adjustable or not.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
05-03-2007, 02:24 PM
NJ
Cobra Make, Engine: SOLD: 2013 Boss 302 Mustang #2775 (both options). SOLD: 95 Mustang Cobra R #4 of 250 "Rosie's Diner" car. SOLD: CCX2-2505, #5 of 7 289 FIAs ever produced at Contemporary! my first Cobra: Unique 427SC w/ 428CJ moder!
A Plunger.......
....or a Doo-Hickey
REMEMBER....In Case of Spin....Both Feet in!!!!!
05-03-2007, 02:53 PM
I Give Up
I am advised that the correct term is "Pushrod Impact Isolator" and was provided the following, apparently definitive, link:
http://www.wipo.int/pctdb/en/wo.jsp?WO=2001/01006
I'm officially throwing in the towel on this one.
05-03-2007, 03:44 PM
MD
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Don't worry 'bout it.
It is a clutch pushrod adjustment collar.
Why do you need to know?
05-03-2007, 03:46 PM
AL
Patrick -
My reading of the description of the "pushrod impact isolator" in your link is that it is not the part noted in your initial picture. But, if it doesn't matter to you, it doesn't matter to me either.
Tommy
05-03-2007, 04:58 PM
This is a replacement of a slave linkage on a non-Cobra. The slave did not have a pushrod and the pushrod did not have an end. The best picture I could find was from my ERA manual. What I think will work is an acorn nut threaded through with a lock nut before it. You would be surprised at all the emails I got with authoritative names for that end piece. Now I'm back to thinking "niblet" was the best.
