Old 05-03-2007, 09:07 AM
Default What Is The Correct Name for This Part?
It's the thing that screws on to the push rod coming out of the slave cylinder and that pushes against your clutch fork coming out of the bellhousing. Picture with helpful arrows below.
Old 05-03-2007, 09:12 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I call it the clutch activation rod. I made four for my car as I changed other things.
Just my $0.02
Old 05-03-2007, 09:36 AM
How about adjustable clutch rod.
Old 05-03-2007, 11:14 AM
Cobra Make, Engine: BDR 187 Prism Red w/Silver stripes; 427 stroker by Smeding Performance, Tremec TKO600 gearbox
It's either a thingamajig or a whatsit--I can't remember which.
'round Midnight
You'll feel me coming
A new vibration
From afar you'll see me
I'm a sensation!
-Pete Townshend, Tommy
Old 05-03-2007, 11:29 AM
Default Uh-huh
I know it's got a name; and I know I've heard it before, I just can't remember it. At this point I'll even settle for a link to an item on a manufacturer's site that even looks close to it.
Old 05-03-2007, 12:15 PM
I call it a clutch slave cylinder pushrod.
It looks like it's too tight on the fork so it might be a good idea to space the slave cylinder bracket forward on the block rather than changing the pushrod.
Old 05-03-2007, 12:21 PM
That's ok, it's not mine -- I ripped that photo from page 35 of the ERA manual.
Old 05-03-2007, 12:26 PM
priobe's Avatar
I think it is like the little plastic things on the end of shoe laces, it does not have a name.
Or does someone know what those little plastic things are called?
Old 05-03-2007, 12:28 PM
Hmm, maybe it's called a "clutch slave aglet."
Old 05-03-2007, 02:11 PM
Tommy's Avatar
Patrick -
I think you are referring to the collar that goes over the "slave cylinder rod." It looks like it can be screwed in or out to adjust the distance between the slave cylinder and the fork. According to this web site, it's called the "adjuster." See the blow up drawing about a third of the way down the page.
Click here.
Tommy
Previously owned EM Cobra
Old 05-03-2007, 02:22 PM
Cobra Make, Engine: LA Exotic
The shoe string "thing" is called a niblet
Old 05-03-2007, 02:25 PM
Originally Posted by Tommy
Patrick -
Click here.
"Collar" is better than "aglet," which is better than "adjuster." Niblet is the worst of all....
Old 05-03-2007, 03:09 PM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
My wife calls it a thingy and I call it a pushrod. There's a logical reason to use this term . . . it's a rod that's pushed on, adjustable or not.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 05-03-2007, 03:24 PM
John McMahon's Avatar
Cobra Make, Engine: SOLD: 2013 Boss 302 Mustang #2775 (both options). SOLD: 95 Mustang Cobra R #4 of 250 "Rosie's Diner" car. SOLD: CCX2-2505, #5 of 7 289 FIAs ever produced at Contemporary! my first Cobra: Unique 427SC w/ 428CJ moder!
Talking
A Plunger.......
....or a Doo-Hickey
REMEMBER....In Case of Spin....Both Feet in!!!!!
Old 05-03-2007, 03:53 PM
Default I Give Up
I am advised that the correct term is "Pushrod Impact Isolator" and was provided the following, apparently definitive, link:
http://www.wipo.int/pctdb/en/wo.jsp?WO=2001/01006
I'm officially throwing in the towel on this one.
Old 05-03-2007, 04:44 PM
Naumoff's Avatar
Don't worry 'bout it.
It is a clutch pushrod adjustment collar.
Why do you need to know?
Old 05-03-2007, 04:46 PM
Tommy's Avatar
Patrick -
My reading of the description of the "pushrod impact isolator" in your link is that it is not the part noted in your initial picture. But, if it doesn't matter to you, it doesn't matter to me either.
Tommy
Old 05-03-2007, 05:58 PM
This is a replacement of a slave linkage on a non-Cobra. The slave did not have a pushrod and the pushrod did not have an end. The best picture I could find was from my ERA manual. What I think will work is an acorn nut threaded through with a lock nut before it. You would be surprised at all the emails I got with authoritative names for that end piece. Now I'm back to thinking "niblet" was the best.
