Old 06-15-2008, 07:20 AM
Default Wire Separators
I'm having a problem and I'm hoping club members can help me with.
I have FE engine with Cobra LeMans valve covers with a flange for mounting a 4 wire separator. Unfortunately, I have tried Ford dealers , on-line parts, etc. but have not been able to find the wire separators anywhere. Even a on-line sites (such as Jegs) who have the actual valve covers were unable to tell me where to find the weparators. The separator is a three separted finger part which slips over the flange to hold the spark plug wires over the valve covers.
Would appreciate any help locating a vendor for the parts. A part number would be most helpful.
Thanks for your help.
Old 06-15-2008, 07:22 AM
Old 06-15-2008, 07:30 AM
Cobra Make, Engine: SPF 2773 Ford Racing 427W
They are everywhere. Try Auto Krafters1-800-228-7346 www.autokrafters.com part# B8Q-12297A and # B6A-12297A Jerry
Old 06-15-2008, 07:53 AM
427 S/O's Avatar
And buy a couple extra for that very reason.............
Perry
Old 06-15-2008, 08:38 AM
FWB's Avatar
FWB FWB is offline
Default separators
yes they are avail as the others said, the problem i ran into is they are sized
for small wire diameter, the aftermarket wires are too thick to fit into them.
i used msd's separator and tapped the plastic separator for a #6 screw
on most valve cover tangs there are 2 holes to run the screws thru. i used
short 6-32 stainless shcs ran them in from the carb side so you dont see them.
Old 06-15-2008, 11:40 AM
Kramer's Avatar
Cobra Make, Engine: ERA 739
ps....I know a guy that can get 8mm wire holders if you need them....(I believe std was 6mm or 7mm). If you need these larger ones, pm me.
Kramer
Old 06-16-2008, 02:56 AM
undy's Avatar
Default A heat gun will make them work...
Get a heat gun (low setting) or a hi-powered hair dryer and "warm up" the OEM separator on the valve cover, then start by pressing the 2 inside wires in the 4 wire separator and then the two outside wires. Press them in then don't mess with them for about 15 minutes. They take a set and will receive the wires in the future w/o worries of separator breakage. The 8 mm/8.5 mm wires will fit like a glove.
Dave
Too many toys?? never!
Old 06-16-2008, 05:55 AM
Cobra Make, Engine: ERA, 496 Tunnel Wedge
Send a message via AIM to My427stang
I use a Dremel with a 5/16 cutter and open them up. Works slick
Go in from the side, like you were drilling the hole bigger, not the direction you'd push the wire in from the top.
Just FYI a drill wont work, it catches the edge and breaks them, but the Dremel just sort of melts/grinds its way through.
1994 ERA Cobra, 452 side oiler, C5AE-F, Tunnel Wedge
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
