Old 04-04-2009, 03:18 PM
lovehamr's Avatar
Stolen Avitar
Default Build thread for BDR687's FE462
Hi all, I'm just now starting to get my photos loaded so that I can put this thread all the way together so please be patient. However I just came across something that's odd even for my "2 steps up and 1 step back" build and thought you guys would like to laugh with/at me. At this point I just got to bolting the intake down after having it on then off about 15 times checking and clearancing things. Then of course the pushrods and rockers get bolted down and I go to put my cool looking H/M VCs on just to keep dust out and this is what I found:
Notice anything missing?
Seriously, WTF!? I can't believe that I now have to drill and tap for a VC bolt hole at this point. Why hadn't I noticed this before? Duh! WTF is with it not being there anyway?!
More to follow................................
Steve
BTW, anyone have a dipstick and tube they want to get rid of for a reasonable price? How about a WP pully?
Old 04-04-2009, 05:58 PM
Well, since you have to do it anyway you might as well go with studs. It'll help you keep your covers from leaking... which they will.
Old 04-04-2009, 08:05 PM
lovehamr's Avatar
Stolen Avitar
Patrick, good advice which I would follow but using these VCs sort of negates that possibility:
The VCs and their bolts have already cost me an afternoon of work on it as one gauled in the other head after being run in finger tight. Seriously, finger tight. When I went to remove it, it rotated about 2 turns and stopped refusing to turn in or out. At that point I had to twist it out and hope for the best. As I twisted on it with nothing but a T handle it sheared about 10 threads up from the head. Notice that my T handle is fine. Now I'm not what you would call a small guy but it really didn't take much torque to twist that little POS in half. Uh, I mean thirds, when I tried to get what was left in the head out it sheared again, right at the level of the head, forcing me to drill it out and heli-coil that hole.
I figure these things are made of stainless peanut butter and I'm now looking for something to replace them. Just in case anyone wondered, these are what came with the VCs.
Steve
Old 04-05-2009, 06:18 AM
Another good reason for studs. You can't get some longer studs/threaded rod? I always use studs when I can on the valve covers. It makes things so much easier.
Old 04-05-2009, 06:59 AM
Yes, I would think a high-quality rod, cut & threaded to the correct length would do the trick. Beautiful valve covers, but the bolts that came with them sound like they came from Toys R Us.
Old 04-05-2009, 08:31 AM
Question You broke the golden rules
lovehamer Steve you broke to basic rules of assembling any motor. First you didnot take a good look at the new parts you got.( no tapped hole in the head) Next you didn't run a tap into every hole in the heads, block, intake, water pump,crankshaft, and timing cover if needed. You would have caught the missing hole if you checked the hole for clean threads. Worst of all, You like screwing every hole DRY? You know that steel and aluminum oxidizes and corriodes in the holes without a sealer or antiseize on the threads. Go to ARP and see if they have allen head long screws. Its a shame that you paided big bucks for those valve cover and they have cheap bolts. Rick L. Ps if you cover the area, you can drill and tap the head on the block. Get some one to use a shop-vac to collect the chips, drill slow, put a piece of tape on the drill drills to get the right depth. Drill in 3 sizes. Oil the tap and tap straight. Clean real good when done. Biggest thing is take your time. Your OK. Pss try a little lube next time, it will not hurt this much. Use the valve cover to center the hole for the bolt. Use a center punch or use the old bolt you have with just grinding the threaded end to a tip that will center in the hole of the valve cover.
Old 04-05-2009, 07:22 PM
lovehamr's Avatar
Stolen Avitar
First off yes I did not chase all the bolt holes in the head. I did do that with the block but it's a 40 year old piece and the heads are new. I will be drilling the head while it's on the block, I did the other side with a piece of bolt in it and sweated the entire time I was working on it. This one should be much easier; at least the bit won't be bouncing off of bits of peanut butter bolt while also cutting aluminum. My biggest worry is not getting the hole straight.
To answer about the studs, even using threaded rod would not work in this case as the head of the allen bolt sits down in a recess in the VC. And yes, for the price I paid for having something different I expected better quality components. I hope they don't use hardware like this on their GT40s.
Now on to other offending studs. In this pic you'll notice the cool ARP studs and nuts holding the killer KC recip assy.
Guess what happened when I tried to mount the Moroso RR oil pan? Yup, no clearance for the studs on the rear main.
So, back to bolts for the rear main! And the saga continues.
Steve
Old 04-05-2009, 07:33 PM
Cashburn's Avatar
Backdraft Racing Dealer
Good to see it coming together Steve... atleast you only have to build the engine
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 04-05-2009, 07:52 PM
lovehamr's Avatar
Stolen Avitar
Ya got that right homey!
Old 04-05-2009, 10:07 PM
Guess what happened when I tried to mount the Moroso RR oil pan? Yup, no clearance for the studs on the rear main. So, back to bolts for the rear main! And the saga continues.Steve
I JUST ran into this same problem with my Armondo pan, and I was using main bolts, not studs. With some creativity on the pan and lots of Right Stuff I think I got a good enough seal to stop the seeping in the rear, we'll see. I am praying to the FE gods it won't leak again. Nice build, bada$$ valve covers.
Old 04-06-2009, 04:36 AM
Lightbulb Here to help
lovehamer Steve Take a deep breath. We can walk you through this. Valve cover first, Mount the valve cover on the head and remove play on the cover. SHARP BITS. Next Grind the broken bolt threaded end to a point and use this as a center punch to start the hole. You really only need the mark to start in the aluminum. Next Get masking tape and see how depth the hole in the valve cover is until you hit the head. Put the tape on the drill bit leaving just enough room to slide this down the hole for the pilot hole. Put grease on the tape so it doesn't bind up when spinning inside the valve cover hole. Slow Speed on the Drill, aluminum is soft to drill. 3/4" deep should be all you need to do this. If you have the cover tight, your pilot hole is centered. Next get a bit for the correct size to the tap. Use some WD-40 when doing any drilling. Slow spray to cool the bit and keep the chips from sticking to the bit. Blow out the hole and tap it. You will have to eye this for the correct angle for the tap to go in. Put a bolt in one of the other holes and use this for the correct angle. Just take you time and use lube for this too.
Rear main studs. Do you have a wiz wheel grinder? Yes/No? If yesyou ccan cut the main studs in the motor. Just cover the area with paper and tape real good. If you don't want to cut them in the block, remove the studs and cut them in a vise down to the correct size to fit under the oil pan. Are you using a windage tray? You will need two gaskets. This will take up some room also. If you cut the stud on a vise use wet towels to control the heat from the cutting. You can either get a stud installer or double nut the studs to reinstall in the block Don't touch or wiggy the main cap if you can aviod it. Install the shorter studs, lube and torque to spec. Recheck the work and assembly. Get a friend to help you with this. 4 hands are better than 2. Rick L
Old 04-06-2009, 09:32 AM
lovehamr's Avatar
Stolen Avitar
Rick, It's not like I can't do it, I'm just pissed and venting that A) I didn't notice it until now and B) why the hell wasn't it already done.
Not even close to long enough so I used a long punch.
I'll have to see if I can find a bit long enough. If I can this could work!
Did this on the other side on the broken bolt as well.
Rear main studs. Do you have a wiz wheel grinder? Yes/No? If yesyou ccan cut the main studs in the motor. Just cover the area with paper and tape real good. If you don't want to cut them in the block, remove the studs and cut them in a vise down to the correct size to fit under the oil pan. Rick L
Just the thought of that gives me the heebee jeebees! Besides, unless I cut off all of the nut as well it still wouldn't fit under the pan. I just went back to bolts on the rear main.
Steve
Old 04-07-2009, 04:51 AM
Question Did you get the right oil pan for yourcar and motor
lovehamer Steve is this the right part for the car?? Companies have boxed stuff wrong before? Are you running a windage tray? Rick L. Ps what numbers stamped on the pan?? Did you call Moroso about this?
Old 04-07-2009, 11:19 AM
lovehamr's Avatar
Stolen Avitar
The pan is definitely an FE pan, no windage tray, it's going in a Cobra with no cross pieces under it so I didn't even have to use a front or rear sump. If you would really like the #s I'll look when I get back home. In the rear the factory bolts sit almost flush with the main cap; the ARP studs with nuts protrude above (or below depending on how you're looking at it) that level enough to hit the back of the OP where it curves from the pan rail. As far as calling Moroso goes, no I haven't and probably won't as I bought this thing used from one of the guys over on the FE forum and at any rate it's for a factory FE and probably wasn't designed with ARP studs in mind.
Steve
Old 04-16-2009, 08:37 PM
lovehamr's Avatar
Stolen Avitar
Default Up Date:
VC, bolt hole drilled and tapped; thanks Rick. ****-canned the stainless bolts and went with steel. I may have to worry about rust on the bolt heads but I won't be twisting one off with a T-handle. Here are a couple of pics showing how it's coming together;
I couldn't find a definite answer for this, so will someone look at it a tell me whether I have the oil routed correctly or not?
Now on to the headers. Considering how heavy these puppys are and how thick the flange is, they are some wavy, out of shape, heaps. I don't know if I'm going to be able to get #4 to seal w/o some surgery. What do you guys think?
Better view;
Someone really didn't want to be making FE headers that day I think. In this view with a straight edge, you can see that the flange is twisted on 3 axis. Not even close to straight;
That's it for now guys, Steve
Old 04-16-2009, 09:34 PM
I think I wouldn't be trying to pull that flush into an aluminum head. Very nice looking engine.
Old 04-17-2009, 03:59 AM
undy's Avatar
I'd get a sawzall and cut through 70% of the diameter of #4 pipe on the distorted side upward, as close to the flange as possible. I'd the get a "fat tipped" oxy/acet torch and "cherry red" that distorted flange. Put the header flange flat on the concrete floor or driveway (large anvil preferred) and flatten #4 flange, comparitive and equal to the others, working it with a hammer. Once you get it where you want it dress it up with a file. An auto machine shop head resurfacer (sander/abrasive type) would be better and get you a 100% flat flange. Once you have the flange where you want it tack weld it to the tube. Recheck flange with a straight edge and reweld/fill the gap between the flange and the tube. You're not going to see the repair once it's installed in the car so it doesn't have to be real pretty, just effective.
Dave
Too many toys?? never!
Old 04-17-2009, 04:50 AM
Thumbs up Nice job on the valve covers
lovehamer Steve do we have a torch?? Hoping the work is yes. The plates for the headers must be soft steel to get heat warpage like that. Lets fix the flanges at the heads first, DON'T TRY and straighten the flanges by using your good heads!!!! 2 thoughts on doing this. How good are you at eyeing things?? if good heat the head flanges and straighten them out with pliers and a turbo blow tip. The pipes are not coated yet. Flat edge each mounting surface to get it flat as possible. After you run the motor a couple of times the heat from the exhaust will help to flatten the flanges better. Even and proper torque needs to be done right on this step. If you have an old FE head kicking around use this head to straighten the flanges. with heat. Use a smaller tip on the torch to direct where you want the bent to take place. Will take longer. Use 2 washers and try to not over heat the bolt head. Tighten bolt until surfaces meet, reheat this area to red and let cool with room temp. After you do this, the fun starts, Make sure that you can install ALL the bolts in the headers without gaskets first. Yoiu may have to grind the holes a little to make them fit. For the Gaskets, cut the bottom of the gasket just wide enought to side on the bolt. Antiseize all the bolts. You should have the rest. Take your time. Good luck Rick. Ps if this doesn't work Shoot Dave(undy) He's sitting on the beach with a cold one and laughing
Old 04-17-2009, 04:51 AM
Variation on the theme. If you have an old iron head lightly bolt that header into place. Warm the offensive parts 'til they glow red and tighten the bolts a few turns at a time reheating as needed. Once it's "home" cool the affected area with a wet rag to "lock the setting". Then do the parts store head surfacer belt sander deal.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 04-17-2009, 04:52 AM
Damn. Lake got me on a holeshot!
