09-25-2007, 06:48 AM
390FE or 351w (stroked to a 427)
Would you rather a 390FE or 351w (stroked to a 427)? The 390FE would be more origanal than a 351w But there is a lot of great after market parts for the 351w. They are both great motors but I am unsure what I would rather have and would like to hear your opion.
Josh
09-25-2007, 07:09 AM
VA
This one seems clear. Is the priority, the best look, or lots of power in a lighter package.
________
________
09-25-2007, 07:12 AM
KY
The FE is more period correct and IMO will get you more ogling and resale value in the future.
The 390 can make big power with the right parts, as can the 351W. Parts are readily available for FE's these days...and it's easy to get 550hp and 550 lb-ft out of a 390 with a stroker kit and some good heads.
09-25-2007, 08:51 AM
Where is a reasonable place to buy a motor from? Any good companies or websites?
09-25-2007, 08:53 AM
KY
There are several good builders that advertise here. Keith Craft, Southern Automotive, Gessford Machine, are a few.
Cobra Make, Engine: Factory Five MK3, 390 FE, Toploader
I bought a 390 FE from these guys and it's worked well so far:
http://stores.ebay.com/Tuff-Dawg-Engines
09-25-2007, 09:21 AM
I was going to call them today. How was the service? Would you buy one again from them? What motor did you get from them? (stroked)
09-25-2007, 10:18 AM
OH
I like my Keith Craft FWIW.
09-25-2007, 10:45 AM
Originally Posted by FFRBob
The 390 in my CSX is from Tuff Dawg as well. It has been flawless and I would buy another motor from them in a heartbeat.
Sal Mennella
09-25-2007, 10:46 AM
Cobra Make, Engine: Hi-Tech
Power Surge, a bit off topic but when ya moving to Palm Coast?
09-25-2007, 10:47 AM
Leaving Thursday.
Sal Mennella
09-25-2007, 10:53 AM
Good Luck!
09-26-2007, 06:01 AM
Big Blocks
Does the Hurricane Kit come with the right headers for a Big Block as well as motor mounts? Is that something you have to tell them when you purchase the kit? Just wondering how they know what you are putting in the engine compartment?
09-26-2007, 08:57 AM
MO
Cobra Make, Engine: Hurricane Motorsports 427 Roadster
Headers
Josh,
The kit will come with complete exhaust for the engine of your choice. That will include the headers and side pipes. Hope this helps.
09-26-2007, 10:50 AM
I've called Tuff Dawgs a couple of times for support and they've been very helpful. Also, they welded an oil temperature bung in the side of the oil pan for me at my request for an additional $75. I felt that was reasonable considering the cost of an aftermarket pan.
09-26-2007, 10:57 AM
VA
never heard of them before. Do they offer a warrenty
________
________
09-26-2007, 12:18 PM
Yes 12 month 12000 mile not bad. There is no warranty when using a Blower, Turbo, Super Charger or NOS
http://www.bigdawgengines.com/
thats there website
09-26-2007, 12:36 PM
Cobra Make, Engine: BDR 559. 410 Stroker 72 block AFR205 Heads, Solid roller lifters, Comp Cams XR286, Eagle 4" stroke internally balanced with chevy journals, Oliver rods, Probe Forged pistons, Mighty Demon, Super Victor, MSD Digital 6.....
Make sure you invest in forged pistons.... I notice that many of their builds do not include them.
Go for alluminum heads as well, run cooler, more power, less weight.
BDR 559
Indigo Blue, White Stripes
SBF 410
TKO 600 .82 OD (Road Race)
HP= Enough!!
09-26-2007, 02:39 PM
OH
You can stroke a 390 as well, 4.08 bore, 4.250 stroke = 441 cubic inches.
4.08 bore , 3.98 stroke = 414 cubic inches.
You can get reasonably priced parts for either engine, but obviously there is a much greater range of parts for the 351W.
Starting with a factory cast iron block, I would guess the build cost wouold be similar no matter which engine, either using a stock crank or a stroker crank.
09-26-2007, 06:31 PM
Fe Fe Fe Fe
