Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > JBL-- JBL Larry G.
Old 07-29-2003, 04:15 PM
jmarsey's Avatar
Cobra Make, Engine: A Blue Car
Default Boss JBL Progress
While the engine was out I thought it would be convenient to change out the on/off switch to something a bit more manageable. This is a rally clutch. Uses two discs (organic) instead of three disc (bronze). Still not a street clutch but a bit more forgiving.
It's a 331 giant killer.
And here it is back in the hole.
NASA - Instructor - 2012 TTA Champion - We Drive Harder!
Old 07-30-2003, 08:30 PM
Richard Hudgins's Avatar
Cobra Make, Engine: Porsche 928 S4
John,
Looks good.
I was always quite partial to the triple plate units. They could embarrass you as the driver quicker than anything. Nothing like killing the engine as you try to leave your pit box.
I was by the shop today and Dave said he was sending out a upright and new front rotor hats and caliper mounts. As well as new spindle bolts, washers and nuts. (This is a update.)
The front structure is being fabricated now. Dave is making a run of them. They have the upper crosspiece moved to allow more clearance for the anti-roll bar actuator in droop.
Best regards,
Richard Hudgins
Old 07-30-2003, 08:34 PM
bmalone's Avatar
That is impressive. Very nice-looking engine.
Bill Malone
Gashole
CSX4786
Old 07-30-2003, 09:50 PM
It's nice to know that the first big block in a JBL Cobra is a 385 series engine!
Old 07-31-2003, 08:52 AM
jmarsey's Avatar
Originally posted by Richard Hudgins
John,
Richard,
Dave told me he is sending me the front clip this week for sure. It is powder coated and ready....hummm. I know about the clearance issue with the upper crosspiece. I had to clearance this tube to allow room for the actuator to rotate with the roll bar as suspension moves.
Question: if you are moving the upper crosspiece, I'm assuming forward towards the radiator, wouldn't the (2) body-support- round-verticals need to be shorter to match the downward body contour?
I didn't have much trouble with the triple disc setup but my girlfriend wants to be able to drive the car, hence the rally clutch. Richard, I'm wondering if this is such a good idea?
BANDIT 1,
I don't get it.....maybe a 335 series engine, which I think included Aussie 302C. I suppose my engine would be similar. However, if a big block was ever to be stuffed into a JBL, it would be by someone much crazier than me....perhaps JBL Dave. I know he has one or two alloy Boss 429's laying around. Now that would be a 385 series engine.
THanks, John
Old 07-31-2003, 09:53 AM
John,
Quote "Dave told me he is sending me the front clip this week for sure. It is powder coated and ready....hummm."
I cannot answer this one. But, I know that the new parts (With the upper crossmember moved forward) just came out of the CNC mill on Tuesday. They are being welded up now.
Quote: " Question: if you are moving the upper crosspiece, I'm assuming forward towards the radiator, wouldn't the (2) body-support- round-verticals need to be shorter to match the downward body contour?"
No. the mounting tabs on the crossmember are moved to the rear of the tube. This puts them in the same location as the old units.
As to your girlfriend driving the car. (No matter what type of clutch) Your call.
At least if she prangs it, you can take out the damages in trade.
Best regards,
Richard Hudgins
