December 2025
  #61 (permalink)
Old 02-02-2011, 02:36 PM
Cobra Make, Engine: 396W Kirkham KMPS036
David,
Alfa engines have been wet sleeved for generations. Cast Aluminum blocks with iron sleeves. If I remember correctly the liners had flanges toward the bottom that rested on an O ring against the block. They were held in place by the clylinder head. If assembled correctly it was bullet proof to 9000 rpm on the street, if not it wouldn't last a week.
Bob McLinden
ERA FIA 2080 SOLD
Kirkham KMPS036
  #62 (permalink)
Old 02-02-2011, 03:00 PM
fordracing65's Avatar
A wet sleeve the outer surface is part of the water jacket around the cylinder, this helps speed up heat transfer between the bore and coolant. With coolant indirect contact with the cylinder sleeve corrision CAN be a problem. It can even insulant the sleeve from the coolant which reduces the main advantage of having a wet sleeve at all. The walls on a wet sleeve are thicker than on a dry sleeve, they dont have the same support from the block as dry sleeves so they depend on there wall thickness. In diesel engines vibration caused by combustion can cause CAVITATION this damage appears similar to corrosion and can eventually destroy the engine. Now that said i understand wet sleeving is a viable option, just dont see it too much in big block daily drivers. (I DONT DOUBT THE KIRKHAMS FOR ONE SECOND)
PRIDEnJOY
  #63 (permalink)
Old 02-02-2011, 03:33 PM
David Kirkham's Avatar
Original Shelby Owner
Drilling the oil galley.
  #64 (permalink)
Old 02-02-2011, 03:36 PM
Originally Posted by Sal Gerace View Post
David is a reality tv show in the works!
Keeping up with the Kirkhams
We're just here making dreams come true. I have a wonderful crew who believe in their soul, "If you make a mistake what's the worst that can happen? You learn something. We don't make mistakes...we have happy accidents." Bob Ross
Thanks guys!
David
  #65 (permalink)
Old 02-02-2011, 03:37 PM
Originally Posted by Robert McLinden View Post
David,
That sounds like most things in life. If an FE isn't assembled right it won't last 2 minutes
David
  #66 (permalink)
Old 02-02-2011, 03:39 PM
Milling the outside port for the main oil galley. We eliminated the lower oil remote and will plumb the oil cooler hoses directly to the block...why have extra parts?
  #67 (permalink)
Old 02-02-2011, 03:42 PM
The mains are almost done.
  #68 (permalink)
Old 02-02-2011, 03:44 PM
Getting ready to do the final pass on the cylinder bores with a boring head.
  #69 (permalink)
Old 02-02-2011, 04:16 PM
We had to do a little custom work on the boring bar to make it stick out past the boring head.
  #70 (permalink)
Old 02-02-2011, 04:26 PM
The bore is quite deep for the sleeve.
  #71 (permalink)
Old 02-06-2011, 09:05 AM
Here is the YouTube video from Kirkham Motorsports University. Here we show you how we took a solid, 386 pound block of aluminum and machined it into a 427 FE engine block.
David
  #72 (permalink)
Old 02-06-2011, 11:53 AM
N2VENOM's Avatar
Cobra Make, Engine: Kirkham KMP500 LeMans- Roush 451 Shelby block; KMP Flip-top with cammer: KMP 289 Bronze under construction.
David, impressive video! After the R&D is competed, will this block go into production? I hate to ask, I'm sitting down, how much$$? Peace, Darren.
  #73 (permalink)
Old 02-06-2011, 12:44 PM
Glad you liked the video. I think it is my favorite one to day. Thanks for the ideas and the push to help us get this going. (We will have another Flip-Top video tomorrow
We don't have a price yet. We don't even have a running engine yet
We are hoping to have it sell for less than the Shelby or Pond block...
David
  #74 (permalink)
Old 02-06-2011, 01:35 PM
Cobra Make, Engine: 2004 Kirkham 427 S/C, Shelby 496C.I.
Wow! 17 percent of the original chunk of aluminum left!
Just goes to show the other 83 percent is a waste.
Kirkham only keeps what's necessary to produce power.
Can't wait to see the dyno run and final pricing to see if I can fit it in my budget.
Congrats Kirkham team! Another project done with excellence.
  #75 (permalink)
Old 02-06-2011, 01:37 PM
Thanks for the kind words. If it doesn't make the car go faster...we left it out.
The other 83 percent isn't waste--it is on its way back to Alcoa to turn back into a block some day
David
ps. we have a bunch of parts here for you. I'll call you tomorrow.
  #76 (permalink)
Old 02-06-2011, 02:00 PM
Bluedog's Avatar
Cobra Make, Engine: Once Owned CSX4803, CSX803 block, Keith Craft 468, Suspension by Tom Barnard, Built by Kris Kincaid
Default Re:
Wow, that is about 1/2 the weight of my 427 Shelby block! Simply amazing!
Are you going to etch in the timing marks for accuracy?
Bluedog
  #77 (permalink)
Old 02-06-2011, 03:09 PM
Cobra Make, Engine: Several
"We don't make mistakes...we have happy accidents."
Or... schedule-altering learning experiences. At DARPA, we called that "research".
Our friends at KSC and Thiokol used to call them VLE's. Sounds benign until i give you the code: Very Large Explosions.
Absolutely facinatin' work, chappies. Dobbers'up! Wet sleeves forever. See Alfas above.
If we could only take that milling machine to DC. 83% waste seems about right.
i could live forever on your and Tiger's throw-away.
"A free people ought not only to be armed and disciplined but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government."
George Washington
  #78 (permalink)
Old 02-06-2011, 03:53 PM
It really is quite light. Where would we etch in the marks?
David
  #79 (permalink)
Old 02-06-2011, 03:56 PM
Thanks for the kind words. What Shingo taught could easily apply to DC. I doubt there are many people there who want to listen, however. Sometimes I wonder if it is a feature--not a bug
David
  #80 (permalink)
Old 02-07-2011, 01:15 AM
This thing is gorgeous! As you said quite a bit different from what you originally envisioned. Wet sleeve, webbing in the lifter valley, I’ll be quite interested to hear what you learned from the F1 engines that you didn’t already know.
With cast iron sleeves and the bottom to go, what do you expect the final weight to be?
Again, that thing looks so good I can see glass windows in the side of the engine bay just to show it off, that or perhaps a lot of flip tops.
Display Modes
