Old 04-26-2008, 11:35 AM
Cobra Make, Engine: Still Working on This
Default Lame Question - Effective Tar Remover
I know this one is lame, but am looking for all suggestions regarding an effective product for road tar and bug splatter removal from my cars (ideally without destroying the paint). Had been using DuPont product for years, but it is no longer available.
Everything available here in California seems to be long on promises but very short on actually being able to remove tar, bug splatter, etc., from the car. I understand that there was some regulation that forced manufacturers to change their formulas; based on what I am seeing, many still have a long way to go.
All tested recommendations appreciated.
Old 04-26-2008, 12:50 PM
427 S/O's Avatar
Gasoline........
Perry
Old 04-26-2008, 12:54 PM
Starting fluid
Old 04-26-2008, 02:12 PM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
If the tar is not too thick use Mothers cleaner paste wax just be sure there is no grit in with the tar otherwise use lacquer thinner sparingly
Old 04-26-2008, 02:57 PM
FWB's Avatar
FWB FWB is offline
Default tar or bugs
"Goo-Gone" is nice it isnt harsh. i wash with soap and water after using it
Old 04-26-2008, 03:25 PM
jams's Avatar
Cobra Make, Engine: B & B
I second the goo-gone.
Old 04-26-2008, 05:13 PM
4RE KLR's Avatar
WD-40 works for me
Old 04-26-2008, 05:35 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
"Bug and tar remover"
Get it at the auto parts store.
Old 04-26-2008, 08:49 PM
Silverback51's Avatar
3M adhesive remover works great. You do have to re-wax the area however.
Old 04-26-2008, 09:05 PM
wtm442's Avatar
Beam Me Up Scottie
Castrol Super Degreaser. Great stuff. But I heard that you cannot buy it in California. Not 100% sure.
http://www.amazon.com/CASTROL-SUPER-...269023&sr=8-12
Warren
Old 04-27-2008, 02:03 AM
Ron61's Avatar
Post
I always use wet paint. Once you do the car with it everything just wipes right off with a little water or Meguiars Quick Detailer. Also the more times I use it, the deeper the color gets.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 04-27-2008, 08:38 AM
Default Thank You
To all who replied. The "Bug & Tar" remover available here in California auto parts stores has been reformulated to meet some kind of environmental edict. While I applaud anything to limit potential environmental damage, the stuff simply does not work.
Think I will try the "Goo-Gone" suggestion and some of the other suggestions.
Old 04-27-2008, 10:50 PM
Naptha, or lighter fluid... WD-40 is also a pretty safe solvant although it leaves a film of oil behind.
Old 04-27-2008, 11:24 PM
Maurice Butler's Avatar
Cobra Make, Engine: Scratch build, with help
butter is good for tar - greasy film then can be easy washed off
Maurice
researching for scratch build
