Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Midstates Cobra's---Speak with Bob Kallio
Old 06-02-2005, 12:03 PM
wicked fast's Avatar
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Question Mid-States question ?????
Hey.
Trying to mount the slave cylinder to the
round tube frame.
Their are no mounting holes from the factory.
Does anyone have a picture of how
it is attached to the frame ??
BC
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
Old 06-02-2005, 12:07 PM
You will either have to fab a bracket to hang off of the tranny mount....or make a bracket to hang off the frame rail. I did the latter with my SV. It's a box frame, but it's the same concept. I took a piece of solid round bar....drilled it and tapped it for the bolt that goes through the slave cylinder rod bearing.....and welded it to the frame rail.
Old 06-02-2005, 01:09 PM
427 S/O's Avatar
See my pics...........
Perry
Old 06-02-2005, 05:44 PM
Roxie_427's Avatar
Cobra Make, Engine: Shell Valley, Shelby Aluminum 427, stroked
Send a message via AIM to Roxie_427
FinishLine sells a slave cylinder kit which mounts the cylinder on a bracket and the bracket to the block/bellhousing interface. It's clean and compact. It's also $175.
I didn't purchase the kit, but I duplicated it with some 1/4" flat stock, a slave cylinder from NAPA, and an afternoon of cutting, shaping, and fitting. Total cost was about $75, including stainless fasteners.
Instead of the mockup drill bit you see here, I purchased a CNC pushrod ($13, I think) and cut it down to size.
Tim
Old 06-03-2005, 08:29 AM
zipzip's Avatar
Cobra Make, Engine: Midstates work in progress, personally built 302
I took this pic off of a Midstates car - this is how they do it.
For mine, I fabbed a "Z" shaped bracket that came off of the rear engine mount bolt. With a couple of triangular webs on each side, I mounted the cylinder through one of them. I'll upload a pic of what I have tonite.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
