08-18-2012, 08:41 PM
Cobra Make, Engine: SPF #1473 392 cu.in. titanium/black stripes
Fastening floor mats
A while back Grubby started a post about keeping his floor mats in place... there were numerous responses, but the one that caught my attention was the response from Jeff Gagnon (1985 CCX) about the "correct way" was to use lift-a-dots. Does anyone have any photos of the placement on any original cars?
Thanks for the help.
"Outside of a dog, a book is man's best friend. Inside a dog it's too dark to read."
Groucho Marx
08-19-2012, 12:33 AM
The seats held the mats under them. The front floor mats had them at the back corners about 1.5" in from each edge.
08-19-2012, 09:45 AM
Thanks for the response Nick. You are always the go-to-guy!
Groucho Marx
08-19-2012, 08:04 PM
hi. there are four lit the dots on each front mat. 1.5 inches?, not exactly, but good enough.
08-19-2012, 09:55 PM
patty442,
Your response has now piqued my interest a bit more in regard to originality. Do you have a photo or a measurement... is 1.5 inches too much or too little?
Groucho Marx
08-19-2012, 10:44 PM
Hmmm I've decided to edit it to 3/4 in from the back edge, I'll stay with the 1-1/2" from the sides. I have photos and measurements but not with me right now.
08-20-2012, 10:13 AM
Nick,
Is there any truth to the four Lift-a-Dot fasteners and are they at each corner???  Looking forward to seeing your photos when you get back and settled in from your trip out west.
Groucho Marx
08-21-2012, 06:09 AM
n/a
Guys, do you mean 'lift-the-dots'? - or do you mean these, standard carpet clips for '50s and '60s Brit cars?
Woolies Trim - Carpet Fasteners
08-21-2012, 08:48 AM
Neat product but they definitely used lift-the-dot or lift-a-dot for the front mats.
08-21-2012, 09:28 AM
n/a
Really? Lift-the-dots? How weird - I've never, ever seen these used for carpet fixings. Treading on them would make a right mess of an ally floor pan. I don't doubt you're right, I'm just amazed as no other British car of the period used hood fasteners for carpet.
Woolies Trim - Lift the Dot
Roger
edit - I stand corrected - I've just found a site that lists them for MG. You learn something every day.
08-21-2012, 03:15 PM
I just started using the mat-locks from GG Bailey.com they are a bit of a ***** to install. Space to negotiate in my car is limited, will repor on effectiveness, if it does not work a screw with a finishing washer will be... I hate the crumbled up mats!!! and they could be dangerous in the driver side.
08-23-2012, 06:45 PM
carpet
Hi. Four lift the dots for each front mat. No question, no stories. I have my original floor mats and my original aluminum floor pans. The lift the dots receivers are sort of crimped into the carpet compressing the rubber backing of the carpet and covering the carpet on the top- upper surface.There is a dedicated tool for installing them correctly into the carpet. The four lift the dots pins, current available are a little different than original, the style of the head now is more round and the finish is different, are thru bolted with a nut on the underside of the car. They are not threaded into the floor. A hole drilled - passed through and a nut on the back side. I will check if it is a regular hex nut or aerotite, can't remember right now. I will have to check. The AC, idea for lift the dots made for easier servicing (cleaning) of the front mat, where all the wear and dirt would accumulate from your big, fat, dirty,shoes. The carpet under the seat is held down by the seat tracks mainly, with a touch of yellowish glue at the perifery, but not all the way out to the intersecting vertical carpeting. The aluminum floor is NOT painted but raw. There was a foot /heal pad on both the driver and the passenger sides, no questions. The pad protected the original poor quality carpet from rapid deterioration. All of the above pertains to a 427 car. I am not sure of 289 stuff. I have owned my car for 39 years. Mickmate ( Nick) is a very nice guy, and a good friend.
08-23-2012, 08:38 PM
I don't know who this guy is! Kidding of course, as friends we agree to disagree sometimes. I'm saying two at the back on the drivers side, front held by slits around pedals. Four on passenger side. Same dimensions will work.
08-23-2012, 09:47 PM
Cobra Make, Engine: CSX2321
+1
2 on drivers side, 4 on passenger side
08-27-2012, 05:40 PM
After searching around a bit I found an example of Lift-a-Dot fasteners holding the floor mats in place on CSX3004.
It also shows two fasteners in front on the passenger side. I hope this is helpful and clears things up at bit, although we all know that there is no one right way.
Groucho Marx
08-27-2012, 05:45 PM
Great shots Bob thanks.
08-28-2012, 02:26 PM
Hi folks:
I purchased the Matguards clamps DON"T work in my car the cross member of the seat base makes it impossible to fit they way is supposed hence the holding pin gets bent and allows the carpet to move. I tried today to bolt it down to the floor bt the self tapping screws do not go throgh the metal floor, tried making a pilot drill hole that did not work either. I will try from the bottom up tomorrow on the way to a car cruise. If anyone has any good ideas please I welcome it. I hate crumbled up carpets. My carpets are 11" wide x 26" long rectangular.
Hope to hear from someone.
Lou
08-28-2012, 03:56 PM
Cobra Make, Engine: Backdraft 1134, Roushcharged Coyote Aluminator NA
Originally Posted by BAsque1
Hi folks:
Lou
If your floors are stainless steel, a carbide tip at a low RPM will help. Stainless is fairly tough stuff to drill. Not sure what you have, but based on what you have tried....
08-28-2012, 04:29 PM
MD
I had a project a while back drilling out some hardened steel in an area where I had to use a hand drill  and found that these bits cut much better than other carbide tip bits. Don't let the "multipurpose" language dissuade you. They work great and Ace Hardware has them - Artu Multipurpose Drill Bit.
www.partskeeper.com
08-28-2012, 08:11 PM
I guess this good shot answers that question. If we look at the underside of foot boxes we will find out if they used self tappers or nut type studs.
