Old 11-14-2012, 06:02 AM
A98Coupe's Avatar
Cobra Make, Engine: #535 Kirkham 427, 427 Side Oiler
Default Clutch Slave Cylinder assembly for 427 Cobra
I am currently looking to replacing the clutch slave cylinder, mounting plate and push rod on my 427 side oiler / top loader combination in my Kirkham because they are poor quality and not original type.
However, I cannot find any information about the original slave cylinder mounting bracket, the correct slave cylinder and push rod assembly to use.
Does anyone know detail or pictures of the original parts which were fitted to the 427 Cobras? Also, detail of where I can source the parts?
For information, I am using an original style 427 Cobra clutch fork (from David Kee transmissions), and I have a Lakewood blow proof bellhousing.
Stuart
Old 11-14-2012, 06:23 AM
Senile Club Cobra Member
I don't think the poriginal type slave will work with the Lakewood. The cars used the Ford bellhousing and the slave is mounted differently than a Lakewood does.
rick@autoventureusa.net
Old 11-14-2012, 06:56 AM
55312's Avatar
I'm afraid I'm a little light on the originality part of this but I just went through re-doing mine. I have a Lakewood scatter shield and the original slave cylinder is a Girling. Top shelf racing stuff from the day. The mounting brackets on every set up I've seen are home made. TRW apparently bought out Girling and they have essentially killed the company. I did find a supply house in the UK that still stocks a large number of OEM Girling parts. They are PowerTrack LTD and have a web site. My slave cylinder has the following numbers associated with it - BS6 - 64677346. This is not a part number but PowerTrack cross referenced it to the correct cylinder. I bought a rebuild kit from them and they were pretty good to deal with. A new cylinder is about 56 Pounds or $100.
Tim
Old 11-14-2012, 08:29 AM
Default Original Slave Cylibde
I had a Lakewood bell housing at one time on CSX3170 and I used the stock slave cylinder and bracket. As I recall it used a tapped hole in the block and then a bolt that retained the bell housing to the block. I now have the stock bell housing back on and that same slave cylinder and mounting bracket so I did not modify it. I can't recall if there were any adapter parts fabricated for mounting to the Lakewood but don't think there were.
Old 11-14-2012, 09:41 AM
Rick Parker's Avatar
A Sunbeam Tiger uses the same Slave cylinder. Repair kits are available as are new cylinder from vendors that focus on that marque. Here is one example:
CAT Parts Warehouse
There are several vendors
Old 11-14-2012, 09:53 AM
mickmate's Avatar
I think you'll find that's the American end of the whole business. Try Ford truck for a slave, I have a program for the plate bracket.
mickmate
http://www.actoncustom.com/
Old 11-14-2012, 10:54 AM
Mickmate :
The image appears to be of the Girling slave, correct?
If you have acess to machine shop, incorporating a female Rod end (Heim) joint into the clutch arm makes a sweet setup. It eliminates the ball end on the pushrod. Illustrations are in Carrol Smiths book "Prepare to Win".
Old 11-14-2012, 02:07 PM
A98Coupe's Avatar
Thanks guys.
I'm pretty sure I can get hold of the Girling Slave cylinder in the UK with no problems because it was common with many British cars of that period and so there are lots of companies in the UK supplying such parts for the classic car industry. However, it was slave cylinder mounting bracket, pushrod and ball end parts which I need to find details of.
Mickmate: Is the photo you showed an original set up or something you have fabricated?
Old 11-14-2012, 02:10 PM
mickmate's Avatar
That's an original set up. You can tell by the little mouse that chewed the clearance on the end of the arm for the frame rail. Looks like this one huh Rick?
https://www.pegasusautoracing.com/pr...wordsearch.asp
mickmate
Old 11-14-2012, 02:20 PM
A98Coupe's Avatar
Thanks Mickmate.
Where did you get the pushrod ball end from? Also, I don't suppose you could PM me the pattern for the bracket?
Old 11-15-2012, 12:02 AM
ALF's Avatar
ALF ALF is offline
I did buy mine from Modern Driveline - Hydraulic Clutch Kits - Slave
Old 11-15-2012, 05:12 PM
DanEC's Avatar
Originally Posted by A98Coupe View Post
Thanks Mickmate.
It can't be that expensive. Why not support small business and buy one from him? I'm just saying.
Old 11-26-2012, 04:40 PM
DougD's Avatar
Default Make me one if you are fabbing some up
Nick
If you decide to whip out a few of the brackets, I'd like one. I'm still not happy with the alignment on my car. It works fine, but I expect it to fail some time in Dead End, Nebraska, on a Sunday night. I'd like to replace the whole ball o' wax with what you have pictured.
DougD
Old 11-26-2012, 04:48 PM
mickmate's Avatar
Hey Doug does your clutch arm and push rod all look like that. I have the push rods all made up, gotta make the ball end adjusters for them.
mickmate
Old 11-27-2012, 06:35 AM
DougD's Avatar
Nick
The push rod and ball end are very close, if not identical. The clutch arm is different.
I'd ideally like to buy a slave cyl, bracket, push rod w/ball end, return spring, and clutch arm as a package, all to fit my toploader.
Doug
Old 11-27-2012, 07:23 AM
ALF's Avatar
ALF ALF is offline
Hi Doug
Contact ModernDriveline!
Will can sell you all required parts (lever, pivot, slave cylinder, T/O Bearing...)
Will Ittner
Modern Driveline Inc.
208-453-9800 ext 102
Regards
ALF
Old 11-27-2012, 07:50 AM
mickmate's Avatar
You see the end of the arm has been clearanced for Cobra frame. Is that the arm you have?
mickmate
Old 11-27-2012, 10:32 AM
DougD's Avatar
No, mine has a triangular portion lopped off the end for frame clearance. Also, the dimple where the ball end of the pushrod fits has a hole in its center. I think my arm is a C8 Ford piece that I got from George at Gessford.
Old 04-10-2013, 07:48 PM
mickmate's Avatar
That should work. I'm finishing the balance of the parts now for the original set up.
mickmate
Old 04-11-2013, 05:47 AM
Mdman352's Avatar
Cobra Make, Engine: Contemporary-427 stroker
The original slave on my Contemporary was from a Volvo P-1800. I switched it out to a Wilwood unit and used a 6" bolt, turned on a lathe to make the ball end of it seat into the unit. Pedal is still stiff.
