Like Tree4Likes
Old 06-24-2018, 07:20 AM
Apex_speed's Avatar
Cobra Make, Engine: Superformance Mk3 with Roush 427R
Default Glove Box Hinge Pictures for 427
I'm reproducing a 427 glovebox door I have all the hinge and construction info for size, width, etc but does anyone have a picture of how the hinge was attached to the glovebox lid/dash? Was it simply screwed straight up into the bottom of the door or did they notch the wood and counter sink it a bit?
I have every other possible photo of the glovebox lid and strap except for that one shot.
Thanks!
Old 06-25-2018, 11:58 AM
Cobra Make, Engine: NAF 427
Hi Apex speed.
I used a piece of fiberglass sheet (1/8" I think) from McMaster Carr and "countersunk it and notched it. Here are a few pics;
Greg
Old 06-25-2018, 03:58 PM
xb-60's Avatar
Got a picture of the finished (leather covered?) glovebox door?
Glen
Old 06-25-2018, 04:36 PM
Hi Glenn. I do have pics but I'm updating my PC so it will be a couple of days before I can post them.
Greg
Old 06-25-2018, 09:25 PM
Apex_speed's Avatar
Thanks. However I believe the original design had 1/16" aluminum on the front, a 3/8" wood core, and 1/16" aluminum on the black for a total of 1/2"
The piano hinge is supposed to be 205MM wide and approximately 1 to 1 1/6" open. Supposedly the catch that holds the door closed is just a simple metal tab that friction fits against the top of the dash when closed.
I'm just not clear how the hinge fits into that "sandwich" per the original setup. Hopefully I can under that last detail as I'm building it tomorrow evening.
Old 06-25-2018, 10:42 PM
Dominik's Avatar
Nice thread, I am watching. It came at the perfect time, because my client wants a glove box - and I try to persuade him not to!
This is for another car with a painted dash and he wants no visible screws or rivets. And I'm not painting the dash again, which is a part of the body (like on a beetle).
Old 06-26-2018, 01:14 AM
lomdel's Avatar
Cobra Make, Engine: Backdraft RT3
A pic of the Backdraft standard glove-box on my car. I am not a fan of the white plastic magnetic catch and have since replaced it with a black one. Excuse the filter boxes...
Old 06-26-2018, 03:54 AM
xb-60's Avatar
Several glovebox pictures that might be of some use....
First one....
(thanks Jeff)
...and the others are from a CSX 289 car, to show some more detail
(thanks tkb)
Glen
bwcobra15, 1985 CCX and LMH like this.
Old 06-26-2018, 08:51 PM
Dominik's Avatar
Really from Mack Road? I could have used my own pics! lol
Thanks. BDR hides the hinge quite well. I never took a detailed shot of the glove box.
Thanks also for the other pics. Helps me, too.
Old 06-27-2018, 05:07 AM
Apex_speed's Avatar
Thanks for the input. We fabricated the CSX "correct" glove box door last night. It was quite the project and I think it turned out well. It just needs to be covered and piped. The car is 1/2" oak that is tapered to fit in the opening better with the 205MM long 1 1/6" piano hinge counter sunk into the front face of the door. The door then gets a wafer thin piece of aluminum bonded to the front of it (no real reason to have it but the original cars did). The back also gets a thin piece of aluminum that does serve a purpose..it gets wrapped in material to hide the seams from where the material on the front is wrapped around to the back.
I have the original 427 glovebox handle. But will be changing out the style of hardware for the handle and door strap (keeps it from flopping open) to nickel plated screws in trim washers as the original setup looks pretty crude.
Now off to find a reasonably correct looking latch.
Old 06-27-2018, 08:33 AM
Hi Glenn. Here are a few pics of my finished glove box:
xb-60 likes this.
Old 06-27-2018, 08:36 AM
One more pic of the inside:
Old 06-27-2018, 03:52 PM
bwcobra15's Avatar
Cobra Make, Engine: Hurricane 427 Cobra #HM2008, Craft Performance 427w 600hp/600tq, TKO-600 close ratio, original Smiths gauges, lucas switches
Send a message via Yahoo to bwcobra15 Send a message via Skype™ to bwcobra15
Does anyone know where I aquire a keyed latch like this?
or what was the "correct" latch/pull for the 427 street cars?
First one....
(thanks Jeff)
(thanks tkb)
Glen
Bob Worley
Hurricane HM-2008 build is done!! (for now....)
Craft Perfomance 427W / 600hp / 600tq - TKO600
I love it and I need it I bleed it ~ Yeah it's a wild hurricane ~ Alright, hold tight, I'm a highway star!!
Old 06-27-2018, 04:01 PM
DanEC's Avatar
On 427 street cars, the pull shown in My427Cobra's photos is correct.
ERA 782 Running
Old 07-08-2018, 01:16 PM
bwcobra15's Avatar
Would you know where I might aquire said correct 427 street car door pull?
Bob Worley
Old 07-08-2018, 02:04 PM
Apex_speed's Avatar
Both Acton Cobra and Cobra Restorers have the right one. They are $90-100. I got mine from Restorers before I noticed that Acton was $10 cheaper.
Old 07-31-2020, 04:29 AM
lomdel's Avatar
How I modified my glove box lock :
https://youtu.be/NWfmtvPStyE
Old 07-31-2020, 08:51 AM
1985 CCX's Avatar
Here is mine, stock and works well.
Old 08-10-2020, 05:48 AM
rsk289's Avatar
I don't know if 427 glove boxes were of the same construction as 289s, but after studying COB6029 and with help from Dan Case and Luke on the ACOC forum, I think I have mine just about correct.
The glove box door is of plywood, with a chromed brass hinge running along the bottom. One leaf of this is fixed to the outer face of the bottom of the glove box door using countersunk-head rivets, so sits vertically when the glove box lid is closed. This is hidden by the cotton wadding and the leather covering (not sure if 427s had leather or not). The other leaf of the spring is fixed to the aluminium dashboard glove box hole return, so sits horizontally when the glove box is closed. This is attached by 4BA screws, internal tooth washers and nuts, from memory - Dan has the details.
I found a hinge manufacturer in Birmingham who supplied the motor industry many years ago, who made some to order for me. The company is Gold & Wassall, Birmingham, England.
Luke kindly sent me some photos of an original 289 glove box his firm had restored, so credit to him for these:
OK, forum doesn't allow photos (or at least won't accept ones of 46kb!). You should get the idea from the above.
Old 08-10-2020, 07:55 AM
1985 CCX's Avatar
Cobra Restorer's, Branda or Finishline would be my starting point!
The 289 key unit is not used on the 427, your lucky as they are not cheap.
