394Likes
08-11-2017, 08:14 AM
Jeff, did you use Dans drawings to make the glovebox?
Alba gu brąth
08-17-2017, 07:18 AM
No sir....
I made it to fit my space out of Alloy. I have felt for cover just not sure I will use.
09-29-2017, 06:32 PM
Headed towards KW power.
09-30-2017, 08:23 AM
Abnormal CC Member
Have you changed to a plug-in hybrid drivetrain?
10-30-2017, 10:35 AM
This may be the last ride of the year!
34F is a bit brisk ..... yup getting old when I say that. CSX4125 in front of me...
03-04-2018, 03:53 PM
Getting set for 2018 season.
Lined the glove box with needle punch fabric, black....
With the help of my friend Dan, added original cast side markers however had to use new centers. Neat authentic piece!
03-04-2018, 03:55 PM
Another angle.....
The edges are slightly arched and sharper casting. These were all cast at once and the casting marks on back match all other originals as one batch equal a match....
11-09-2018, 02:43 PM
Detail update.
Minor detail but cool.
Thanks to John Bessey for making these parts.
All about the details.
11-09-2018, 02:45 PM
John patterned these parts after an early car.
The detail is in the notch and playing.
Today’s has no notch and are yellow playing. Next detail is to change the screws to studs
11-09-2018, 04:13 PM
Direct comparison
11-10-2018, 12:31 PM
A little better...
....... now for the other 24 that need changing to studs ..
11-10-2018, 03:54 PM
Best view of bracket
11-13-2018, 01:32 AM
CH
Hi Jeff
Did you use plastic washers?
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
11-13-2018, 07:56 AM
Actually on the bottom, helps space the gap with the spun units.
In the picture I had it on top, since moved it to below.
11-13-2018, 10:15 AM
Heres what they look like with the Weber supplied air horns....
12-04-2018, 06:17 AM
Continuing to make small changes now that winter is upon us.
Added period rod ends to SS rods. Going to use small alloy tubing to shroud rod for correct look.
Always work to be done.
12-04-2018, 06:41 AM
Ont
Love the detail Jeff. Looking real good!
12-04-2018, 06:53 AM
CH
Hi Jeff
Your outstanding work and your eye for the details are of great inspiration for my project.
But the chocolate foil on the Weber's is still challenging me
12-09-2018, 01:50 PM
Added a little more of a touch.
Happy at the moment, will touch up final details after adjustment.
05-15-2019, 08:03 AM
Started out this year and found fuel pump failure.
Rebuilt Carter, in and up and running
