Like Tree12Likes
  #81 (permalink)
Old 07-30-2012, 08:06 AM
Cobra Make, Engine: Kirkham #259
Richard
BTW.....these are GT-2 cars running in GT-1 Class......age and technology.
Morris
  #82 (permalink)
Old 08-07-2012, 01:48 PM
garyjettrike's Avatar
Cobra Make, Engine: Chevy LS3 supercharged
Originally Posted by Jac Mac View Post
If you could mount the rack in the position indicated by the 'yellow' rack outline with the tie rod ends above the steering arms you would get the necessary ackerman effect plus gain a bit of clearance from brake rotors to tie rod ends.
with camber compensaition the rack has to stay in line with the bottom ball joint and and a arm iner bushes this way there is zero bump steer if you move it up you get problems as the top a arms move in and out on the rocker to adjust camber you will get bump steer
  #83 (permalink)
Old 08-07-2012, 02:08 PM
Originally Posted by Richard Hudgins View Post
Morris,
Gary..... Nice looking piece you have designed there. I will be interested to see how you like it when you start testing.
Beautiful sheet metal work as well. Congrats...
Interesting brake calipers. I guess one can never have enough pistons but I do wonder the reason for 5? Are they trying for high beam stiffness or are the pistons of various sizes to give even pad clamping?
Hi Richard we hav been building cars with this sytem for ten years now and have it well sorted now hears some pics of a lotus 7 replica we have built a few hundred of them,
the pistons in the calipers are various sizes and thers ten in the fronts,
thanks Gary
  #84 (permalink)
Old 08-07-2012, 02:21 PM
hears a bit of film of one of our cars at bedford autodrome
Dax Rush Hayabusa Turbo Bedford How Fast. 28.01.12. - YouTube
  #85 (permalink)
Old 08-07-2012, 03:25 PM
Gary
Your comment on the rack having to be in line with the lower control arm to have zero bump steer is not correct......
There's a line between the inner upper pivot (upper control arm) and lower pivot (or lower control arm) that you can have the end of the steering rack mounted on....
And as you guy's get up into larger GT-1 type of cars....you will start to under stand how we have been able to get larger cars to handle on race tracks....and the lower control arms are mounted under the chassis so low that you can't get a steering rack down to that level.
Ackerman works better on Sedan type of cars then on formula cars....
Just trying to give you some of the experience that took us many years to acquire.
Morris
Morris
  #86 (permalink)
Old 08-07-2012, 08:27 PM
Richard Hudgins's Avatar
Cobra Make, Engine: Porsche 928 S4
Sweet....................!!!!!!
I think I would enjoy one of those.......
Best regards,
Richard Hudgins
  #87 (permalink)
Old 08-08-2012, 02:58 AM
Originally Posted by Morris View Post
Gary
Morris
Morris, I agree with everything you are saying as long as you are talking about a conventional double A arm system. With the camber compensation system the top A arms are constantly moving in and out to adjust camber and the nearer you are to the top arm the more steering deflection you will get as the arms move.
This web sit explains how camber compensation works.
The Camber Compensation & Anti-Roll (CC&AR) Suspension System
Regards Gary
  #88 (permalink)
Old 08-08-2012, 07:16 AM
Cobra Make, Engine: jbl
Richard would drive anything that sounds like a f1 car
  #89 (permalink)
Old 08-09-2012, 07:24 AM
hears some pics of anotherone of our camber compensaition cars that has been racing for a few years it wins regularly even though the othe cars in its class are lighter and run down force ,
it runs a LS3 580 HP and has no truble geting the power down thanks to the camber compensaition,
the other car is my bell jetranger turbine powerd car with the same chassis
  #90 (permalink)
Old 09-02-2012, 08:58 AM
our man Duncan Cowper takes another 2 seconds off the lap record at bedford in one of our camber compensaition cars beating the Graham Hathaway Juno
http://www.youtube.com/watch?v=eJxAo...Uy-w_Oapsbpe6Q
  #91 (permalink)
Old 09-08-2012, 05:27 PM
been busy in the workshop body hood and doors fitted and in the engine bay we done air the filter and header tanks for engine and intercooler, the air fillter will suck cool air from the side of the radiator.
Mando and alfy65 like this.
  #92 (permalink)
Old 09-10-2012, 11:54 AM
xlr8tr's Avatar
Cobra Make, Engine: CAN-AM cobra, 460 SVO
thats gonna be a BEAST! Cant wait to see some video of it running.
Mark
  #93 (permalink)
Old 10-09-2012, 05:54 PM
xlr8tr's Avatar
any updates?
Mark
  #94 (permalink)
Old 10-13-2012, 06:33 AM
Originally Posted by xlr8tr View Post
any updates?
Hi Mark plumbing in the engine was a biger job than i expected another header tank for the inter cooler and ducting in the air filter to pull cold air from the side of the radiator,
we have also made some new side mirror mounts and side vents, its getting there now.
Gary.
  #95 (permalink)
Old 10-13-2012, 07:06 AM
very nice work. i find the side mirrors useless with all the vibration and limited view going down the road unless a convex mirror is used, looks real nice though. same with the rear view, i switched to a boat mirror from cabelas and makes a world of difference. for the side you can get the round stick-on if you decide to try it.
  #96 (permalink)
Old 10-18-2012, 05:19 PM
just found a bit of film on utube of me scaring the crap out of a tv presenter from Stripper cars for cash, go strait to 34.50
strippers cars for cash - YouTube
  #97 (permalink)
Old 10-30-2012, 02:05 PM
Moor progress, we went for a different shape bonet scoop just to make the car recognisable as the XCS Cobra,
finished the fuel tank and boot area and sunken twin filler caps,but now we want to re make the roll over bars in bigger dia tube
done all the engine plumbing fuel water and intercooler in front of the radiator and doing the wireing now there is loads of it
  #98 (permalink)
Old 10-30-2012, 10:05 PM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
Great video. He's right, you know: That thing is a monster!
DD
Dangerous Doug
"You're kidding, right?"
  #99 (permalink)
Old 11-12-2012, 12:46 PM
just tacked the new 2"dia roll bars together and the large filler caps have arrived
  #100 (permalink)
Old 11-13-2012, 03:55 AM
Great job,
but outside hinges for the boot lid??
Rate This Thread:
