574Likes
03-04-2018, 06:20 PM
Cobra Make, Engine: Hi-Tech
Cutting the hood and mounting the scoop...
03-04-2018, 06:21 PM
Looking like a Cobra now with rollbar installed...
03-04-2018, 06:26 PM
Side view of rollbar, English windshield, Lucas 104 mirror.
03-04-2018, 06:33 PM
Rear quickjacks, boot handle and plate frame / light. Original Wilmot Breeden lock, key and correct key code...
03-04-2018, 06:40 PM
And my favorite so far, my original style Ceandess dry sump cap...
03-04-2018, 06:43 PM
Oh yes - let us not forget the all important windshield wipers. Taken for granted but no easy task.
03-05-2018, 04:57 AM
It's really coming along! Can't wait to see the finished product!
03-05-2018, 04:42 PM
Elliot tag, 10 pts....
Alloy scoop and plate bracket? loss of bonus points....
03-05-2018, 05:00 PM
Full Blown Member
Originally Posted by 1985 CCX
Alloy scoop ...?
I believe the glass scoop to be a victim of, "I'm going to all this trouble for an aluminum car? Damn the glass scoop to hell!"
Not on KMP600, though
rodneym
03-05-2018, 07:42 PM
Hey Jeff, you forgot my points for the Lucas 104 mirror!!! Black crinkle paint goes on the back this week.
Also, most of the early Comp and race Cobras are not drilled for plates as they weren't meant for the road!! I call owners choice.
03-05-2018, 07:52 PM
I would like extra points for my original Enots cap (with red gaskets) and Supertanium bolts. Inspired by CSX3020 - one of my favorites!
03-05-2018, 08:05 PM
va
Kevin, don't forget the correct bolt spacing on the cas cap flange!
(Thanks to a clubcobra member with an original csx 3000 car that tries his best to keep me on the right path!)
Thanks Doc!!
03-06-2018, 08:38 AM
Kevin, do you give any consideration to "clocking" the Lemans cap at a 45 degree angle (cap opens toward driver's seat) or even straight back (cap opens to front of car)? I've seen several originals with both orientations, but given time and tinkering, perhaps they all came from El Segundo with the perpendicular look as you have given this excellent example? Also, I can appreciate the Supertanium bolts and krinkle-finish backing on the mirror and bracket...love the exacting details.
03-06-2018, 07:49 PM
Hi Steve,
Craig put a lot of time and thought into getting the cap exactly where we wanted it. First, he drilled the correct pattern into the body. He then added the appropriate spacers and gaskets and screwed the cap to the base and tightened the cap. Since the base had no holes drilled in it, Craig was able to locate and clock the cap assembly exactly where we wanted it and then drill the six holes into the base and mount it. I think it came out great!!
03-06-2018, 09:41 PM
SD
Cobra Make, Engine: CSX 4145, aluminum body and Shelby aluminum FE stroker
Looking good, Craig! I would expect nothing less from you. 😀
03-07-2018, 07:28 AM
Kevin and Craig
Awesome job!
Car is perfect just poking fun...
03-07-2018, 01:12 PM
Kevin and Craig
Awesome job!
Thanks Jeff. Also, the hood scoop will be fiberglass
See you on Saturday!!
03-07-2018, 03:01 PM
Full Blown Member
My ally scoop is garage art
rodneym
03-07-2018, 05:09 PM
If I wasn't painting my car, I would have used an alloy scoop but since I am painting it, it has to be fiberglass!!
03-07-2018, 05:19 PM
Hi Steve,
I got the process backwards...
Craig tightens the cap to the base with the appropriate spacers and gaskets, drills the base with the appropriate pattern and then transfers the pattern to the body.
