Like Tree574Likes
  #261 (permalink)
Old 03-08-2018, 05:34 PM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
Craig did a test fit of the FIA wheels and I am really excited at how awesome the car looks (I'm biased of course). Exactly the look I was going for...
1985 CCX likes this.
  #262 (permalink)
Old 03-08-2018, 05:36 PM
Final fitting of the dry sump tank cap.
  #263 (permalink)
Old 03-08-2018, 05:44 PM
Craig's awesome turkey pan fitted with my custom built carb.
  #264 (permalink)
Old 03-08-2018, 05:48 PM
1795's Avatar
Sweet! It's coming together nicely. Tell us about your custom built carb.
  #265 (permalink)
Old 03-08-2018, 06:20 PM
As much as I would have liked to use a "correct" carb, with 482 cubic inches, I needed something that looked period correct while having enough CFM to keep the engine going. I sent a Holley 4150 to Joe Bunetic along with 2 Lemans float bowls. Joe added and adjusted the bowls, machined off the air horns, installed .128 needle valves with steel tips and when everything was done, had the carb properly replated. The choke was also removed. This is the carb that Barry Rabotnick used to dyno my engine: Video: Survival Motorsports And 482 Cubic Inches Of FE Fury - EngineLabs
The HP & Torque numbers are higher now that we have improved fuel flow to the carb / engine.
  #266 (permalink)
Old 03-08-2018, 06:21 PM
Forgot to mention that the 4150 is 850CFM.
  #267 (permalink)
Old 03-09-2018, 03:33 PM
cobrakiwi's Avatar
This car is really starting to take shape, the fia type wheels look right at home on this one. Great choice imo!
Front inner panels made up and test fitted, flange for the footbox vent installed.
  #268 (permalink)
Old 03-18-2018, 05:33 AM
cobrakiwi's Avatar
Here we have replaced the inner bushings on the front lower control arms.
Everything is nice and straight now and should work just fine.
Ready to be all dolled up with new powder coating.
  #269 (permalink)
Old 03-19-2018, 05:11 PM
1985 CCX's Avatar
Sweet Jesus! Awesome!
cobrakiwi likes this.
  #270 (permalink)
Old 03-20-2018, 05:18 AM
Glad you like it Jeff!!!
Craig has removed all of the goodies from the car as it will be heading to the painter over the next few weeks. He put the car on the rotisserie and is finishing up all of the detail work on the bottom side. Exciting times...
  #271 (permalink)
Old 03-20-2018, 07:55 AM
LMH's Avatar
LMH LMH is offline
Very cool!
Alba gu bràth
  #272 (permalink)
Old 03-20-2018, 08:40 AM
1795's Avatar
Can't wait for photos when it is done.
  #273 (permalink)
Old 03-20-2018, 09:39 AM
Craig still needs to add the handles to the hood, fit the comp screen and tonneau cover and then it should be ready for paint!!
  #274 (permalink)
Old 03-20-2018, 11:05 AM
Cobra Make, Engine: Kirkham 599 Polished Bronze
I've been following this thread and I can't wait to see the finished product. You're to be congratulated for following through on this project.
  #275 (permalink)
Old 03-20-2018, 04:42 PM
Thanks Tim - I appreciate the encouraging words. If I hadn't connected with Craig, I very much doubt I would have followed through with this project. He is a very talented fabricator and so much more. My standards are very high and he has not disappointed. When all is said and done, I think this is going to be one heck of a car. I can't wait to see the finished product either
  #276 (permalink)
Old 03-20-2018, 09:55 PM
Gaz64's Avatar
I would hope you have fuel bowl "whistles" fitted.
Those bowl vent tubes are bit short for my liking.
What depth air filter are you using?
Vent tubes can run at near 3/4 inch to the air filter lid.
The car is a work of art.
  #277 (permalink)
Old 03-21-2018, 05:04 AM
Hi Gary,
No one else has mentioned this as a concern but I will definitely look into it. I am planning on running a Stelling & Helling air filter. As tall as I can fit with a K&N element.
Thanks - Kevin
Gaz64 likes this.
  #278 (permalink)
Old 03-21-2018, 12:47 PM
1985 CCX's Avatar
Geeze saw the car on its side and thought Joey Chitwood was driving......
  #279 (permalink)
Old 03-22-2018, 11:41 AM
Hopefully that is the last time it is ever on it's side!!!
  #280 (permalink)
Old 03-22-2018, 03:12 PM
Original Wilmot Breeden hood latches with correct round bezels have been fitted. Checklist is getting shorter...
Tags
acton, mickmate
