| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
07-27-2005, 08:18 AM
OR
Scratch builders- steering column?
What is the best steering column for my set up?
Obviously, I'm not trying to build a completely accurate replica of an original, including the fact I'm using a small block. So, which steering column would be best for my purposes?
I've seen reference to the Volkswagen units, as well as Ididit columns and a couple others. What are you guys using and what are the pros and cons?
Also, what steering wheel will work with these units and how are they attached?
Thanks, Bob
07-27-2005, 08:50 AM
AZ
The Factory Five uses the upper part of a Mustang steering shaft. It's a telescopic shaft and runs through two bearings to the coupler. There is a hub made that adapts a MotaLita wheel to the Mustang shaft.
Alba gu brąth
07-29-2005, 07:42 PM
NH
Hey Bob
you must have seen this steering
Cheers Nick
07-29-2005, 08:19 PM
OR
Nick,
I saw the thread- thanks,
Do you happen to know what year column is used? MGA or MGB?
Thanks, Bob
07-29-2005, 08:20 PM
Cobra Make, Engine: Modified DRB 2000, 302 Windsor
I used a steering Column out of an 1986 Mitsubishi Mirage (I know, its japanese!!). And I bought a steering wheel from FFR, and had my own adapter boss custom made by a machinist friend.
07-29-2005, 09:08 PM
W.A
Cobra Make, Engine: Lucus shell, Arrow chassis, efi 5L HO, 5 spd supra, Diff 3.73:1, Rear tyres 275x60-15
1993 ford laser was the perfect length for me, came with two unijoints and the correct spline for my application, made my own boss and has steering lock.
Simmo
Black Rubber Needs To Be Layed
07-31-2005, 08:48 AM
OR
I found a guy close by who has a couple 68/69 MGB steering columns for sale, along with a bunch of other stuff- including steering racks.
Will this year of column work, and what is a fair price to offer him for a column? If anyone else is looking for one, I'll pick up both of them if you're interested.
If nothing else, what length column am I looking for so I know when I see one?
Thanks, Bob
07-31-2005, 10:19 AM
Cobra Make, Engine: original a/c. shell valley 427. daytona coupe
Bob it is an MGA not an mgb if my memory serves me correct. The last one we built was with solid 3/4 stock, bearing at either end with an aluminum tube for the column. all parts were borgeson except the aluminum tube and bearings.They do have a web site we were able to weld a quick release at the steering wheel end and use borgeson adapters and splined shafts at the other all the way to a manual mustang rack. On the originals it uses an mg rack and the a column doesnt have the key and directional stuff at the other {early style} is just a steal tube with bushings at either end and a 3/4 shaft with splines on the bottom and threads for a bolt at the wheel end. The directional is still the early volkswagon. I hope this helps with out being to long winded.
08-04-2005, 08:29 PM
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
The old VW column works very well....same switch some of the Cobras used and it is compact and easily mounted to the chassis. Parts are readily available and Borgeson sells ujoints ready to go.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
08-04-2005, 10:25 PM
OR
Darn it! And I just passed one up on ebay for $5! Oh well, the search continues
08-05-2005, 06:35 AM
NH
Hi Bob
That one was too new. I just found a local guy with a heap of old beetle treasure. If I can get out early today I'll get a couple for us.
Cheers Nick
08-05-2005, 07:05 AM
OR
The one I saw was last week and it was mid-60's or so? What years are we looking for?
Nick, if you find one for me pick it up and I'll send you a check ASAP.
I'll be out of town the next week or so on vacation- just send me an e-mail and I'll get back to you as soon as I can get to a computer.
Thanks a bunch- Bob
08-08-2005, 08:26 PM
I think 67 and earlier...just find one that does NOT have the ign switch on the column itself.
08-09-2005, 02:55 AM
NH
Thanks
I found one but it looks like the bottom end is under the gas tank. Does anyone know if the tank fits in a hole or does it have a floor under it?
08-09-2005, 07:06 PM
NH
You found a computer then........
Hey Bob, I'm told the tank exposes the bottom end of the column which will be helpful. I'll keep in touch on it but I think we're gonna find it's just a tube with two bearings and a shaft that we'll probably want to change to a FR or Borgeson or something.
Cheers Nick
08-13-2005, 08:48 PM
NH
Hey Bob
Check your CP (control panel)
08-14-2005, 12:37 AM
OR
Nick,
Reply sent (again). I'm starting to think there is something wrong with my PM function?
Also emailed a reply.
Thanks, Bob
