Old 09-22-2007, 09:19 PM
Default Hello...windshield angle
As a new member I wanted to say hello. I am in the early stages of a Cobra build, which of course raises a multitude of questions. For starters, does anyone know the proper angle (slope) to set the windshield?
Old 09-22-2007, 09:31 PM
fasterpatrick's Avatar
Cobra Make, Engine: scratch build self design 4.6l DOHC
Someware in the 40-45 degree range. I'm sure those in know will chime in with the exact dimmention. Patrick
Old 09-23-2007, 04:31 AM
mickmate's Avatar
Do a search on this subject. 45 degrees is the number for most applications. Some people like the more raked back look of a 289 Comp car. It also depends a lot on whether you'll be using side curtains or a top.
mickmate
http://www.actoncustom.com/
Old 09-23-2007, 06:49 AM
Dwight's Avatar
Smile
Have your Cobra on the ground, correct air pressure in tires, frame/ ride height adjusted,etc. sit in the seat and have someone to hold the windshield in place. Check to see if your head/ eyes are above or below the top windshield brace. Use a protactor to check the angle. I think 45 to 53 degrees is OK. If you have a top then the angle will have to match the top. Side curtains sometimes can be modified to fit correctly. We have put a FFR hardtop on a Hurricane but had to cut the side curtains at the front and add a piece to the bottom.
Dwight
Same top
Old 09-26-2007, 11:46 AM
Thanks for your help with the windshield guys. Greatly appreciated. The next question is... what is the original roll bar size? I have seen them from 1.5 inches up to 2 inches. Also, what is the measurement center to center? (where it enters the body)
Actually made a little progress with it in the last few days!!! Sadly, many more still needed...sigh.
Edatman.
Old 09-26-2007, 12:26 PM
mickmate's Avatar
More on that Roll Bars
mickmate
Old 09-26-2007, 12:30 PM
mickmate's Avatar
This is one of your best places to check windsheild rake http://www.erareplicas.com/427/profiles/index.htm
mickmate
Old 09-26-2007, 03:04 PM
Tony Ripepi's Avatar
Cobra Make, Engine: TBD
Here is one picture from the ERA site with the angle indicated....
Tony R
Old 09-26-2007, 04:01 PM
mickmate's Avatar
It should be pretty close, just note that's the 289 body (beautiful ain't it?)!!
mickmate
