SUPPORT OUR SPONSOR
Old 01-28-2002, 08:05 PM
Cobra Make, Engine: FFR 1496 289 hi-po.
Default 9" rearend fluid capacity?
Subject says it all. Any ideas? Brian
Old 01-29-2002, 07:00 AM
Fill it with the appropriate gear lube until it comes up to the bottom of the fill hole. If I remember correctly it takes about 2 quarts.
Don't forget about friction modifier if you have a limited slip differential.
Jeff Taylor
Old 01-29-2002, 07:48 AM
Clois Harlan's Avatar
Default Rearend fluid
Jeff is right on the mark and be sure not to forget to use the limited slip lube (I think mine came in a tube and cost about
$7 or $8.
"Let's roll"
"Be part of Something Good
Old 01-29-2002, 04:36 PM
Thanks guys........... the problem I have is that the Ford setup I just put in does not have a fill hole in it . I have a fill hole on the top of the third member but not one that is at fill level. Its a Ford case ..... don't know why there is no fill hole. I'm using a Detroit soft-locker so I don't believe I need any additive. Correct? I put in 2.5 qts hopeing that is enuf. Brian
Old 01-29-2002, 05:11 PM
Default Fill plug.....
Brian,
Usually there is a fill plug on the gear case about halfway up on the side. It will have a square or sometimes hex head or socket type fitting. Remove and fill untill the gear oil starts to drain out, then put it back in and tighten. (May have to use a breaker bar to get it loose)
Display Modes
HTML code is On
