SUPPORT OUR SPONSOR
Like Tree12Likes
  #21 (permalink)
Old 01-02-2021, 07:02 PM
xb-60's Avatar
Originally Posted by eschaider View Post
...I made my own 10.5" dual disc clutch....
I'm impressed! Well done Ed
Cheers!
Glen
  #22 (permalink)
Old 01-03-2021, 02:11 AM
eschaider's Avatar
Thanks Glen.
The initial impetus was nothing more than the age old convergence of necessity and invention motherhood ...
Ed
  #23 (permalink)
Old 01-03-2021, 01:03 PM
ERA 626's Avatar
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
any one else here have a .625/7/8" set up with a McLeod RST? I currently now have a .750 I think that that is my problem... a new master cylinder is only $55...
  #24 (permalink)
Old 01-03-2021, 01:21 PM
eschaider's Avatar
Mike,
I presume your slave is the .625" diameter piston and the master cylinder is 0.750" diameter piston, which would produce a very stiff clutch release. Try putting a 0.875" diameter slave on the clutch and you should have a very nice feel to the clutch release.
Ed
  #25 (permalink)
Old 01-03-2021, 03:58 PM
ERA 626's Avatar
Mike,
Ed
no. My existing set up is a .750 master and a .875 slave... I will try going with a smaller master (.625) I am thinking this will solve my issue... right?
  #26 (permalink)
Old 01-03-2021, 04:05 PM
DanEC's Avatar
It will be lighter but longer pedal throw. If that isn't a concern or problem with clutch release then might help
ERA 782 Running
  #27 (permalink)
Old 01-03-2021, 04:17 PM
Gaz64's Avatar
Interesting, I see no dowels.
So are the 2 sets of studs a transition fit for each section, or a sloppy clearance fit?
Gary
  #28 (permalink)
Old 01-03-2021, 08:16 PM
eschaider's Avatar
My bad, I misread your post, Mike. Your current choices should work if your pedal ratio is close to correct. Increasing the leverage the clutch pedal has is similar to decreasing cylinder bore on the master cylinder but frequently quicker and less expensive.
ed
cycleguy55 likes this.
Display Modes
HTML code is On
